11-12-2013, 11:00 PM | #1 |
Rep 1,732
X3 is pretty quick
Had some fun running with the previous gen (2009 ish) Cayenne S which I believe has the 4.8 V8 with 385 hp. Considering the X3 has only 300 hp I was surprised to be very evenly matched with the Cayenne. I know the X3 is quick but did not expect it to stay with the Cayenne.
11-15-2013, 01:59 PM | #4 |
Rep 221
Even a new Cayenne is is listed at 400 HP and a 0-60 time of 5.6 seconds according to Porsche which is .1 second slower than BMW's 5.5 seconds for the X3 35i.
2012 X3 35i | Deep Sea Blue | Oyster |
Packages | Sports | Cold Weather | Cold Weather 2 | Premium | Technology | Premium Sound |
11-15-2013, 03:09 PM | #5 |
Rep 876
There aren't many SUVs that the 35i X3 can't hang with. It's an impressive machine to say the least. I do think the 300HO claim is under rated along with the 0-60 times.
11-15-2013, 03:31 PM | #6 |
Rep 1,732
Agreed. It must have more than 300hp. Probably around 320-330hp. I just wish there were more after market products for the X3. I would like to get a good tune.
11-16-2013, 12:00 PM | #7 | |
Rep 1,170
Drives: 2020 F97 X3M
Audi SQ5 specs : SQ5 Technical Specifications 3.0 TFSI® Warranty | Maintenance Warranty - 4-Year/50,000 mile Audi New Vehicle Limited Warranty Maintenance - 12-Month/5,000 mile (whichever occurs first) NO CHARGE first scheduled maintenance Steering Type - Electromechanical power steering system Ratio - 15.9:1 Turning diameter (curb-to-curb) (ft) - 38.1 Body Material - Fully galvanized steel unibody with aluminum hood and tailgate and multistep anti-corrosion protection Exterior measurements Wheelbase (in) - 110.5 Length (in) - 183.0 Height (in) - 65.3 Overall width with mirrors (in) - 82.2 Overall width without mirrors (in) - 75.2 Track front (in) - 64.2 Track rear (in) - 64.0 Curb weight (lb) - 4,409 Drag coefficient (Cw) - .36 Suspension Front - Five-link front suspension with SQ5 sport calibration Rear - Trapezoidal-link rear suspension with SQ5 sport calibration EPA estimates | Capacities City - 16 mpg5 Highway - 23 mpg5 Combined - 19 mpg5 Engine oil (qt) - 7.2 Fuel (gal) - 19.8 Recommended fuel - Premium Emissions rating - ULEV II Transmission | Drivetrain Transmission - Eight-speed Tiptronic® automatic transmission with Audi quattro® all-wheel drive Gear ratios: 1st - 4.714 Gear ratios: 2nd - 3.143 Gear ratios: 3rd - 2.106 Gear ratios: 4th - 1.667 Gear ratios: 5th - 1.285 Gear ratios: 6th - 1.000 Gear ratios: 7th - 0.839 Gear ratios: 8th - 0.667 Gear ratios: Reverse - 3.317 Gear ratios: Final Drive - 3.760 Brakes Front (in) - 15.0 (ventilated disc) Rear (in) - 13.0 (ventilated disc) Interior measurements Head room with sunroof (in, front) - 39.4 Head room with sunroof (in, rear) - 39.0 Head room (in, front) - 38.1 Head room (in, rear) - 37.7 Leg room (in, front) - 41.0 Leg room (in, rear) - 37.4 Shoulder room (in, front) - 57.7 Shoulder room (in, rear) - 56.4 Cargo volume (cu ft, cu ft, rear seatbacks up/folded) - 29.1/57.3 Seating capacity - 5 Electrical System Battery - 12 Volts - 80 amp Alternator - 14 Volts - 150 amp Engineering | Performance Engine type - Six-cylinder Displacement (cc)/Bore and stroke (mm) - 2,995/84.5 x 89.0 Horsepower (@ rpm) - 354 @ 6,000-6,500 Torque (lb-ft @ rpm) - 346 @ 4,000-4,500 Engine block - Aluminum alloy Cylinder head - Aluminum alloy Valvetrain - 24-valve DOHC Induction/Fuel injection - Supercharged/FSI® Acceleration (0-60 mph) - 5.1 sec. Top track speed - 155 mph6 Disclaimers
2011 MINI CooperS BRGII/Lounge Green/Sport/Prem/Connect/Black Xenon/Black Conical Spokes/ACS springs/ACS exhaust/Alta Shorty/Yokohama Advan Sport A/S
2012 M3 AW/FR NDH2/2MK/ZPP/ZCP/ZCW/752/6NR/OEM CF splitters/OEM CF Mirror caps (retired) 2012 X3 35i Titanium Silver/Black ZAP/ZPP/TECH/APPS/Breyton GTS (retired) 2018 X3 M40i BSM/Oyster/ZPP/ZPX/HK/S6CPA/718M(retired) Last edited by car_fan; 11-16-2013 at 12:11 PM.. |
11-21-2013, 11:34 AM | #8 |
Rep 876
Here is what gets me about the new SQ5, while it might have a slight performance increase over a regular 35i X3 the SQ5 returns very poor MPG. We've seen over 28 MPG on road trips, I don't think the SQ5 will return similar results (19/23). Plus the Sq% is going to be much more expensive than 35i X3.
11-28-2013, 08:30 PM | #9 | |
Rep 1,170
2012 M3 AW/FR NDH2/2MK/ZPP/ZCP/ZCW/752/6NR/OEM CF splitters/OEM CF Mirror caps (retired) 2012 X3 35i Titanium Silver/Black ZAP/ZPP/TECH/APPS/Breyton GTS (retired) 2018 X3 M40i BSM/Oyster/ZPP/ZPX/HK/S6CPA/718M(retired) |
