XBimmers | BMW X3 Forum BMW X3 Forums | E83 (2003-2010) First Generation BMW X3 General Forum Rear diff/trans shudder at low speed turns?
      09-27-2013, 11:42 PM   #1
WULFFZA
WULFFZA's Avatar
Drives: 2011 335i MSport / 2012 X5 35d
Hi
Did some searches on the forum and for tsb's but no luck.
The gf has a 2008 X3 3.0 M-Sport with approx 80k miles. She puts fuel in and drives until lights come on, you know the type.
For quite a while now the car has exhibited an uncomfortable shudder/jerking together with a dry shaft jolt sound when lifting off the gas and turning at low speed, like when pulling around a parking garage.
My sense tells me, let's try a fluid change in the diff, it's done 80k miles...
Last visit to the dealer, they told her the tires were worn and that's what's causing noise. Umm, no, no new tires thanks.
They must have updated software because the car shifted so much better after that visit, fluid shifts and would coast downhill rather than grabbing a lower gear too soon like it had been doing.
It's back a the same dealer now and this time they're telling her it needs a software update for that noise and that it isn't covered under warranty (it's still under the extended warranty for a couple more months). I am not allowed to talk to them, because my talking tends to get loud.
Thoughts?
2011 E90 335i M-Sport 6MT Alpine white - saddle brown
2012 E70 X5 35d Sport Activity - Alpine white - black
2005 Toyota 4Runner 4WD Sport Edition Silver
      10-06-2013, 01:10 PM   #2
puchchu
Drives: X3 Si 3.0
Hi!
I had a similar noise problems from rear diff on my 2007 X3 si car at lower speeds. The dealer changed differential and transmission both under warranty but the problem never got solved completely.... He finally put it on tires (my tires were not BMW * rated). This issue is very well documented in this and other forum and I finally changed to * rated tires and it's a different car from that day.... the problem is completely gone... And let me tell you my earlier tires were very new (came along with my purchase) and the tire dealer was wondering why I was changing it!!!
BMW X3 diff is very sensitive to tire dimensions and all and I suggest use the * rated tires and you will have no issues....
      03-27-2014, 05:36 PM   #3
Tonybear1986
Drives: Bmw x3 3.0 d msport
I had exactly the same problem when i bought my x3 and it turned out the back tyres was a different size to the front
      01-08-2015, 01:21 PM   #4
tr03cobra
Drives: 06 330xi
Originally Posted by WULFFZA View Post
Hi
Thoughts?
Im having the same problem on 06 x3, i don't have on bmw approved tires. They are khumo ecsta. I goin to buy the oem approved tires and see if it fix the problem. Did you get it resolved yet?
