06-25-2013, 02:54 PM | #1 |
Inspector Gadget
17
Rep 202
19" Tyre pressures
29 PSI all round (2 Bar)
Have I read this right - and is this what everyone with 245 (front) and 275 (rear) uses, 19" wheels?
MY14 X3 35d M-Sport. Born 19/04/13, Delivered 31/05/13. Alpine White, Red Brown Leather, Brushed Aluminium, 19" 369 Alloys, BMW Media - Professional, Visibility Package, Access Package, Electric Seats w/ Lumbar, Variable Damper Control, Panoramic Roof, Extended Storage, HUD & Black Panel Dash, DAB, Reversing Camera & Top View, Heated Steering Wheel, Heated Rear Seats, Apps, Internet, BMW Loudspeaker Professional... & More.
06-25-2013, 03:15 PM | #2 |
Rep 264
Yes - I was surprised how low these pressures seemed but am using them at the moment. Feels OK.
2022 BMW X5 M50i
MY 2020 Evoque P300 MY 2022 VW e - UP |
06-25-2013, 04:10 PM | #3 |
Rep 560
I think if the car is fully loaded, the pressures are 2.2 bar rear and 2.1 bar front? I inflated mine to those pressures initially, but the car didn't ride so well. I have dropped back to 2 bar all around and it is much better over bumps. I guess it is OK, but I too had thought that 2 bar seemed low.
06-25-2013, 05:15 PM | #4 |
Inspector Gadget
17
Rep 202
Excellent, as long as i've got it correct. I thought it seemed a bit low! I was expecting 36psi or so.
Cheers
06-26-2013, 01:29 AM | #5 |
Rep 264
I always used to run my X5 a little higher than standard on the rears at 2.4 instead of 2.2 as it seemed to help with the inside wear due to the camber setting. They were 315's on that. The camber does not appear to be so excessive on the X3 with 275's on the back.
2022 BMW X5 M50i
06-26-2013, 01:43 AM | #6 | |
Law Enforcer
25302
Rep 22,324
Drives: '22 Chalk Gray Porsche C2S
06-26-2013, 06:47 AM | #7 |
Rep 220
I use 36 front and 40 rear (I think) on 19" 245/45 and 275/40 (35d). I think that adding some pressure actually makes for a smoother and more controlled ride as it takes the load off the side-walls. You should also notice less tramlining.
Also increasing pressure on my previous 335d with runflats dramatically increased tire life and mileage. On my first set the fronts wore out within the year. BMW told me that the recommended air pressure was really not good and told me that I should always increase the pressure. My new front tires + old rear ones lasted an additional full 3 years. That's just my opinion. |
06-26-2013, 07:32 AM | #8 |
Rep 161
I agree with Chris55.
When I had my X3 F25 and 19" (255/40 all corners no run flat) I had mine at 36/40 and normally added up to 38/42 when controlling. Wear seemed far less, comfort did not supper, but the cars sportiness was much improved, and lastly it improved fuel economy) Today I run an X5 E70 with 19" (255 - 285 run flat), and here I also add more than BMW says in manual, same picture as with the X3 My opinion as well |
09-13-2019, 09:09 PM | #10 |
xdriv33
73
Rep 224
Drives: 17' BMW x3 F25 xDrive28i xLine
I go slightly above as well... my x3 runs on 36F/39R PSI.
