XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 General Forum 3.0 M Sport Tyre Pressure Question
      04-25-2013, 02:04 PM   #1
MattUK
Captain Unsensible
MattUK's Avatar
Drives: 2016 M240i Coupe - Estoril
2016 BMW M240i  [0.00]
I know this topic has been done to death, and a lot of us hate run flats..
So.. I need correctly..
To make the ride slightly less hard, do you slightly OVER inflate the RF's or UNDER?
If so.. I am running the 19's, and would appreciate if other UK owners could share what good pressures they have found that give a more comfortable ride?
Thanks
      04-25-2013, 02:42 PM   #2
The X Men
Drives: 2013 X3 35i
Usually, one should under inflate the tires for a softer ride, but since you have 19" tires, I would not do that since the low profile tires and rims can get damage.
      04-25-2013, 02:56 PM   #3
3Bimmer
3Bimmer's Avatar
Drives: 2013 X3 35i
My service center has the annoying habit of setting the tire pressure to a ridiculously high setting each time the X3 is in for service. I've asked them not to, but they keep doing it. I now check my tire pressure after each service and set it where it is supposed to be. If your X3 has been serviced lately, check to see if the pressure has been changed. Be sure to reset your TPMS after making any changes.
      04-25-2013, 03:06 PM   #4
MattUK
Captain Unsensible
MattUK's Avatar
Thanks.. what settings / pressures do we recommend.. its just had a service, so no doubt this will have been done.
      04-25-2013, 03:43 PM   #5
mge92
SPEED RACER
mge92's Avatar
Drives: Range Rover Velar D300
I have mine set up at 33 in the fronts and 38 in the rear but once it heats up it is normally around 34.5 in the front and 39.5 in the rears.
      04-25-2013, 04:59 PM   #6
clivem2
Drives: F25 35D MSport
With my 18's I find the ride slightly better with 2 or 3 PSI over-inflated. I think there's less bounce, more control. 18's and 19's are not really that low profile compared to 3 series so I feel the effects are different to what you'd expect.
F25 35D | MSport | Space Grey | Saddle | Burr Walnut | VDC | Reversing Camera | Xenons | Panoramic Roof | Matt Aluminium Roof Rails & Window Trim
Dec 2014
      04-25-2013, 05:08 PM   #7
3Bimmer
3Bimmer's Avatar
Drives: 2013 X3 35i
Check the sticker on the lower right of the driver's side door jamb. The recommended pressures are listed based on load. tires, etc. For USA it is 32 front, 38 rear.
      04-25-2013, 05:40 PM   #8
richard in NC
Drives: 2009 Z4 35i
I think 32 is a bit low for the front but I've not settled on the exact best. I have discovered with RFT that at a little too low and the tire rests on the stiff RFT sidewall and the ride worsens. Adding a few PSI puts the proper curve to the tread edge and a better ride!
      04-25-2013, 06:44 PM   #9
clivem2
Given the different tyres fitted to the X3 at manufacture those PSI ratings can only be approximate, they cannot be optimal for all. It's down to individual judgement on what works best in your locality. I'm not suggesting a 50% difference but +/-10% or 15% is perfectly reasonable.
Dec 2014
      05-02-2013, 11:50 AM   #10
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
As per clivem2 i go 2-3 over on 19s. Ride is firm but control and feel is better
F25 xDrive20d SE __ professional multimedia package | dynamic package | climate package | 309s | xline | xenons | electric seats | folding mirrors | business speakers
      05-02-2013, 12:03 PM   #11
terrytnt
terrytnt's Avatar
Drives: 2012 X3 35i M/DHP Carbon Black
Interesting... after speaking with a competent BMW associate, his recommendation for X3 19in. is sticker guidelines - F-32, R-38
That's what I'm doing...
      05-02-2013, 04:01 PM   #12
sfax
sfax's Avatar
That's a brave recommendation
      05-06-2013, 08:38 AM   #13
Nahoa
After reviewing the manual that provides inflation settings for different set-ups, loads, and speeds, I've been running at 38/40 on Pirelli 19s. This works well for me with regard to road feel and cornering.
