      04-06-2013, 08:16 PM   #1
NYCX3
Drives: 2013 BMW X3 28i
Steering pulling to right
Anyone else experience this with their X3? When I got the car brand new, the steering wheel was straight on a straight road, however, recently, I noticed it's pulling slightly to the right, no matter what road, crown or no crown. Never had this issue with my 2006 X3, that thing was a tank.
So I took it into BMW dealership, and alignment was done, however, the issue remains. I'm posting a photo of my alignment specs in case anyone can spot something that the alignment guy missed.
I circled some things I thought looked "off".
Any ideas what this pull can be caused by?
      05-06-2013, 10:26 PM   #2
TreeSkier
Drives: 2022 X5 45e
I have had a pulling issue (to the right) and unbalanced steering feel since day one. I've had the car in several times, at around 12,000 mi they replaced the left side spindle which seemed to solve the issue for a while and then it came back. At 23,000 mi, with new tires and an alignment, it is pulling again. The shop agrees there is an issue and has replaced the right side spindle and the car is still pulling. They are now waiting for guidance from BMW as to what to do next. Apparently, the spindles can be replaced to tweak the alignment. I'll let you know what they find. I'm just happy they are acknowledging there is an issue and are working on it.
      05-07-2013, 05:19 AM   #3
BMWLVX
Drives: X3 2.0d
I have this also. If I enable Sports mode it feels worse. I've learned to live with it as I don't trust BMW to make things better if I give them the opportunity
So, question about my wife's X3…
      05-13-2013, 02:39 PM   #4
saulgoodman
saulgoodman's Avatar
Drives: 2012 F25 N52T
2015 BMW 328XI  [0.00]
Looks like F10 5-series also have same issue and there is post about fixing that.
http://f10.5post.com/forums/showthread.php?t=835328
check out the picture of the work-order.
      05-15-2013, 01:15 AM   #5
lhsa
Drives: kia
my 2011 X3 had the same problem. Came home new straight, but within a few thousand miles started pulling. At 12000 miles the drive was downright scary at highway speeds so I took it in for service.
The SA said the front tires were unevenly worn and needed to be replaced, but if that didn't fix the problem, there was a bulletin about spring perch replacement. The new spring perches fixed the problem and now handling is great again. I thought it was the steering rack, but it seems fine.
Unfortunately to get to the fix, I was forced to buy a replacement set of goodyear runflats for the front tires i was hoping to get nonrunflats, but that would preclude me from getting the spring perches replaced under warranty. Anyway, I'm happy its all done and I just need to wear out the tires so I can get better ones...i'm only too happy to oblige by burning rubber
      05-15-2013, 07:57 AM   #6
jman103099
Drives: 2011 E90 & 2011 F25
Any idea what the bulletin number is? Or do you have a copy?
      08-05-2013, 10:13 PM   #7
electricjet
electricjet's Avatar
Drives: 2011 E90 & F25
Exclamation
greetings .. SIB 32-06-12 .. known issue ..
attached a copy of the work order
DRIVE IT LIKE YOU STOLE IT
      10-06-2013, 10:01 AM   #8
walendvay
Drives: '11 F25 28i; '13 E84 35i
Did this SIB help the pull to the right?
      10-08-2013, 09:39 AM   #9
walendvay
anyone? Going into the shop thursday and am curious if I should lean hard on the dealer implementing this SIB.
      10-09-2013, 10:30 AM   #10
B3412
B3412's Avatar
Drives: BMW X3
Pulling to right
I have had the service bulletin completed (SIB 32-06-12) but it has not helped with my vehicle pulling to the right. They did find that my right strut was leaking fluid during the inspection. I would insist on the dealer completing the SIB. When I took my vehicle into the shop they said that my vehicle didn't have any SIB then I showed them the SIB from this site then magically they found the bulletin (Good Luck).
      10-11-2013, 05:01 AM   #11
RhoXS
Drives: 2002 Z3 3.0i + 2016 X3 28i
Over the past 45 years I have periodically run into this problem on various vehicles. Without exception, after it is aligned, and all possible mechanical issues have been ruled out, it ends up being caused by something the tire shops call a "radial pull".
Swapping the front tires sometimes solves the problem. Replacing the tires always, without exception, solved the problem for me. The amount of or lack of obvious tire wear does not seem to matter.
I understand the radial belts sometimes slip or slightly move out of position. This changes the rolling resistance compared to the other tire. Therefore there is a slight pull. I do not know if this is an accurate explanation but I have heard that said a number of times.
      10-20-2013, 12:43 AM   #12
NYCX3
Thanks, will consider your suggestion. Once I get everything fixed I selling the car and not looking in BMW direction anymore. They are making defective and overpriced cars (at least the X3s) with horrible customer care and lousy dealer service.
My car is 1 year old and apart from the defective springs, the speakers are cracking, interior is creeking, idrive is a mess of confusion, and throttle is laggy. I dont want to even think what other issues will pop up when the car gets older.
      10-23-2013, 12:47 PM   #13
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
I'm right there with you.
      10-24-2013, 09:02 AM   #14
NYCX3
After much searching and calling around, I finally got the # to BMW Germany Headquarters, I recommend whoever is having a problem solving their issue in USA, to try Germany. Here are two useful contacts:
1. tel: 011 +49 89-1250-16000
2. email: customer.service@bmw.com (this is the international customer relations email, for all countries... and should be used when US Customer Relations fail, as they often do).
      10-25-2013, 01:09 PM   #15
walendvay
had this SIB done on our '11 X3. The handling feels brand new! centered feel, no drift. All fixed.
Tags
alignment, pulling to right
