FORUMS
- 5
| XBimmers | BMW X3 Forum » Geneva 2013: Alpina XD3 Biturbo Revealed. Alpina's First SUV/SAV |
| 03-05-2013, 08:46 AM | #1 |
Administrator
BIMMERPOST NEWSGeneva 2013: Alpina XD3 Biturbo Revealed. Alpina's First SUV/SAV A rare thing happened today at the Geneva auto show. We actually managed to be surprised by the debut of a new model that had not been first teased or previewed online by its manufacturer; a rare thing these days where manufacturers typically tease, preview or reveal new models online prior to its real life debut. Kudos to Alpina for bucking the trend and keeping a tight lid on the debut of the Alpina XD3 Bi-Turbo! Follow our full 2013 Geneva show coverage updates at BIMMERPOST.com On to the details: DRIVE The drivetrain of the XD3 Bi-Turbo utilises the excellent attributes of the BMW full aluminium 3 litre straight six cylinder engine with modern common-rail direct injection and two turbochargers with variable turbine geometry. With the aim of further maximising the potential of this engine and using the freedom that small series production allows, ALPINA engineers have worked extensively on optimising the air intake flows. The new air intake ducts have substantially larger diameters and feature optimised radii which lead to a 30% reduction in loss of pressure. This effective means of ‘de-restricting‘ the air flow between the air intake and the air filter housing allows the engine to breathe more freely, resulting in improved performance and a more lively character. In combination with the realisation of appropriate turbo charging and injection pressures this leads to a maximum output of 350hp (257kW) at 4000rpm and 700Nm torque between 1500 and 3000rpm. The performance and effectiveness of the entire cooling system has a direct influence on the stability and output of turbo charged engines - as a result, the cooling system in the new XD3 Bi-Turbo is of central importance. A large volume intercooler (+38%), with an optimised inlet and outlet design, feeds the engine with air. Two additional separate water coolers, which are situated in front of the wheelhouse and lie perfectly within the air flow from the front spoiler, ensure that all cooling mediums (via oil/water-heat exchangers) are kept at optimum temperatures, even during maximum thermodynamic loads. The operating parameters and components of the cooling system are managed by a cooling system control unit which features an intelligent operation of the electric cooling fan to directly influence performance under full loads. An exhaust manifold made from high-strength material allows for higher exhaust gas temperatures (+50 ̊C) which result from the increased power output. From the middle silencer backwards the exhaust system is carried out in stainless steel and finishes with two double-ended tailpipes which carry discrete ALPINA and Akrapovič lettering. Sound engineering and the reduction of silencer volumes has resulted in a for diesel engines surprisingly throaty exhaust sound, especially at higher rpms. The character of the engine overall is unusually lively for a diesel engine, revving freely past 4500rpm. Despite the engine‘s high specific power output of 117hp per litre, the XD3 Bi-Turbo achieves class-leading efficiency figures: 6.8l/100km (41.5mpg) and 180g/km CO2 (Combined, measured according to ECE norm). TRANSMISSION Adapted and tested in co-operation with ZF, the advanced SWITCH-TRONIC 8-Speed Sport-Automatic transmission features specific hardware modifications demanded by the high torque, these include special mechatronic components and an adapted torque converter. ALPINA engineers have spent many development and test hours working on the software to ensure that the transmission provides unparalleled levels of both comfort and performance. The blend of eight speeds and high levels of torque makes for super comfortable gear changes with no noticeable interruption to the delivery of power. In Automatic (D) Shift Mode the XD3 Bi-Turbo excels at cruising along at speeds in high gears at minimum rpm, this benefits both consumption and comfort. Using the Sport (S) Shift Mode the transmission becomes noticeably crisper and unmistakably immediate, gear changes become quicker and take place at higher shift points. The ALPINA SWITCH-TRONIC buttons, which are ergonomically and unobtrusively positioned on the back of the steering wheel, activate the Manual (M) Shift Mode which allows the driver to take complete control of the transmission. The system also allows for multi-simultaneous down-shifts in milliseconds, hereby the transmission will skip several gears depending on engine loads and rpm. In this manner the 8-Speed Sport-Automatic transmission with ALPINA SWITCH-TRONIC reveals itself as extremely multifaceted, providing the right shift characteristic for any and all situations. In combination with the Sport setting of the Drive Performance Control which further sharpens suspension and transmission, the new XD3 Bi-Turbo will sprint from 0 to 100km/h in only 4,9s and reach a segment leading top speed of 253km/h (157mph). CHASSIS To fulfil the seemingly contradictory demands for comfort, everyday usability and dynamic handling, the XD3 Bi-Turbo is equipped with electronically-adjustable dampers. This system is tied into other system parameters controlling steering assistance, torque cushioning and the Dynamic Stability Control system. Featuring Drive Performance Control with Normal, Sport and Sport+ settings, the XD3 Bi-Turbo can transition effortlessly from cultivated luxury to thorough-bred sportiness. Light steering, comfortable suspension, a smooth transmission and BMW’s excellent xDrive all-wheel drive system make it an ideal everyday partner – whatever the conditions. At the same time, the XD3 Bi-Turbo will dive into and accelerate out of corners with such ferocity and traction, that powerful sporting saloons will find hard to beat. The wheel and tyre set-up comprising 20” ALPINA CLASSIC wheels with MICHELIN Pilot Super Sport tyres measuring 255/40 ZR20 (101Y) EL, E / A / 71 dB front and 285/35 ZR20 (104Y) EL, E/A/ 73 dB rear is to a large extent responsible for the agile and sure-footed handling of the XD3 Bi-Turbo. The low-profile tyres, which forego run-flat technology for the sake of slow-speed damping, combine well with BMW’s Variable Sport Steering to achieve precise turn-in. This can be further enhanced by means of an optional 21” ALPINA CLASSIC wheel and tyre set-up. In order to travel safely, dynamically and at speed even in the winter months, a 20” ALPINA CLASSIC winter wheel and tyre set-up is available in the dimensions 255/40 R20 101W front and 285/35 R20 104W rear. DESIGN & EQUIPMENT ALPINA typical design cues and aerodynamic refinements integrate well into the overall design of the XD3 Bi-Turbo and give it purposeful appearance. The athletic front with ALPINA spoiler has a dynamic design and integrates functional air intakes for an optimum air flow to the coolers. The rear features ALPINA trademark slightly elliptical double-ended tailpipes which are integrated into an ALPINA rear valance which has been constructed to allow the use of an optional towbar. The comprehensive standard equipment level features Leather Upholstery, supportive Sport Seats, Xenon Headlights, Cruise Control and Park Distance Control. The hand- finished ALPINA LAVALINA sport steering wheel with Blue/Green stitching connects driver and car while the ALPINA instrument panel with black-panel LCD technology displays vital information, including a digital speed read-out and gear indicator. ALPINA door sills, floor mats and emblems in the seatbacks provide discreet hints to the XD3 Bi-Turbo’s provenance. Optional interior trim finished in Alcantara with contrasting stitching makes for a decidedly more sporty ambiance. Share this story |
| 03-05-2013, 09:28 AM | #2 |
* A BLUE PANDIAN SMURF * ♠
Drives: BMW X3, X5 Join Date: Jun 2011
Awesome!!!
I bet this Wont come to the us, and those UGLY WHEELS just kills the car's styling.
| 03-05-2013, 10:10 AM | #4 |
Architect
Drives: Golf Cart Join Date: Mar 2009
stunning car.
![]() BEFORE YOU BUY YOUR NEXT BMW, PM ME FIRST I CAN HOOK YOU UP! We are Performance Center|Euro Delivery|BMW Individual Specialist Need a quote?..Ryan /Checa Email link | T.805.482.8878 ask for Francesca www.stevethomasbmw.com | OUR PARTS STORE | Facebook-STBMW | Twitter-STBMW |
| 03-05-2013, 10:12 AM | #5 |
Hmm, all good other than that rather cheesy led backlit alu on the door/dash. That really does look cheap. Rest looks quite tasteful.
![]() BMW Z4 E89 sDrive35i Mods: Stubby! LED Halos! DVDInMotion! GolfT! SmartTop! BMW Performance 313 Alloys! http://www.detailingworld.co.uk/foru...d.php?t=265084 |
| 03-05-2013, 10:14 AM | #6 |
wow this is amazing!
YouTube Channel: http://www.youtube.com/user/07triump...ow=grid&view=0
| 03-05-2013, 10:31 AM | #7 |
Very shiny.
I don't care for Alpina wheels. They all look too fancy to me; I prefer a tough 5-spoke design. But that's just me. I sure wish the X3 were a little less cute. It's really a great car, but I would never consider one. Something about the front end proportion is wrong to my eyes, I can't put my finger on what it is. The X1 is better in that respect. So is the Q5, for that matter.
-Will
2005 545i Sport | 2001 X5 3.0 Sport (Retired) ![]() |
| 03-05-2013, 10:58 AM | #9 |
Hopefully it's the lighting but the front spliter looks like its a slightly different color than the rest of the car...
Sys Admin - Geek by day, Car enthusiast by night.
| 03-05-2013, 11:19 AM | #11 |
![]() ![]() ![]() Drives: E30 318is, E46 M3 Join Date: Mar 2006
I love it!
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara
| 03-05-2013, 12:18 PM | #13 |
Pygocentrus Piraya
haha...I said the same thing. It's a diesel...Still tho...
![]() Those rims on the X3 are just not right I agree the interior lighting is cheap looking OMG where is the X3M version plzzzzzzzzzz!!! I would take an X4M now too...hurry up BMW
kozzi
![]() 2011 BMW F25 35i Deep Sea Blue Metallic/Nevada Mojave/Brushed Aluminum/SAP/DHP/309 Run-Flats |
| 03-05-2013, 04:12 PM | #16 |
I love Alpina's, this is almost an exception, but I still quite like it.
I'm betting this exists after Alpina and BMW sat down and had a chat about the X3M.
3/15 to i8, and everything in between
(yep, even including the F07 and F20) |
| 03-05-2013, 05:09 PM | #17 |
![]() ![]() ![]() ![]() Drives: 07 E70 X5 4.8i Join Date: Jan 2006
Alpina XD3 Biturbo FTW!!!
________________________________________
![]() 07 X5 4.8i Black/Black (His) 08 535xiT Blue/Black (Hers) 08 E92 M3 Red/Tan (Sold) |
| 03-05-2013, 05:10 PM | #18 |
Amazing vehicle that we probably will never see on our side of the pond. I wish we could get the turbo diesel over here.
2011 X3 xDrive35i F25 (CPO) Space Grey/Black Leather, Packages: Premium, Cold Weather, BMW Apps, Sirius and Technology. BMW CCA Member (WindyCity Chapter). Former cars: 06 750i E65 (CPO) 07 E90 335i (bought used but had problematic iDrive so sold it to get 7-series)
| 03-05-2013, 06:59 PM | #21 |
Pygocentrus Piraya
kozzi
| Bookmarks |
