XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 (F25) General Forum Creaking Moonroof
      02-27-2013, 05:28 AM   #1
halfalife
halfalife's Avatar
England
13
Drives: 3.0D Msport
Creaking Moonroof
Hi, car has done 5000 mile and the moonroof has started to creak....annoying !
I know its been mentioned on here, but has anyone had a dealer fix this problem ?
It would be good to know before I book my car in to get looked at.
      02-27-2013, 08:23 AM   #2
nyalpine90
CAPPO
nyalpine90's Avatar
Drives: '16 X4
2016 BMW X4  [5.00]
yes there's a solution, applied a felt tape around plastic center piece where it would make contact with glass
      02-27-2013, 09:31 AM   #3
halfalife
halfalife's Avatar
England
13
Drives: 3.0D Msport
Thanks for that. I have just found the thread, it seems quite a common problem.
      02-27-2013, 10:01 AM   #4
jman103099
Drives: 2011 E90 & 2011 F25
This is first my BMW, I'm not sure if I'll buy another !
You're not sure if you'll buy another... because of a creaking moonroof?
      02-27-2013, 10:57 AM   #5
nyalpine90
CAPPO
nyalpine90's Avatar
Drives: '16 X4
2016 BMW X4  [5.00]
im sure its been fix by now, its a common issue with new model
      02-27-2013, 02:17 PM   #6
Tangsta
Drives: AW F25
It would be good to know before I book my car in just to get fobbed off again !
After reading the other threads here, including some that had multiple unsuccessful trips to the dealer, I was convinced I'd have to bandaid my own with felt tape.
But, I brought it in to the dealer anyway and they fixed it right the first time.
It's a known issue and there's an internal documented troubleshooting process/fix. If you need, I can dig up my invoice tonight and see what it says.
Mine is a 2013 with roughly 9000 km.
      02-27-2013, 02:54 PM   #7
Mingstar88
Drives: BMW X3 35i
seems to happen when weather became cold, dealer fixed though
      02-27-2013, 03:03 PM   #8
plob
Drives: 650i GC
Mine is at the dealers at the moment - they are trying to fix this noise. I'd be grateful if you could let me know what it says on your invoice so I can tell them about it in case they try to tell me that they don't know what the problem is.
Thanks in advance
P
      02-27-2013, 03:29 PM   #9
halfalife
halfalife's Avatar
England
13
Drives: 3.0D Msport
Its not just the moonroof, I've had a few niggles that you just shouldn't get when you have paid 40K for a car. The car should be bomb proof (not literally), I guess I expected better.
I have attached some foam to the plastic to see if that fixes it, time will tell.
      02-28-2013, 12:47 AM   #10
Tangsta
Drives: AW F25
Thanks in advance
P
Not sure if this will mean anything to you or your dealer, but here's what it says on my invoice
Test plan AM5401-00060-Panorama Roof. Interference Noise. With ref to test plan remove headliner and check tightness of attachment screws. Find several loose. Retighten to correct torque and check alignment of cassette with special tools 54 1 100.
Reassemble headliner and test drive vehicle. Noise no longer present. Diag code D5410-MX000000-12-003
Hope this helps
      02-28-2013, 08:07 AM   #11
noka
Drives: 2013 x35i M-Sport
Great info! If people could post such details from work orders, I think it would benefit all forum members to provide references when researching fixes for various problems.
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired: '09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, '01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i,... '86 4000 CS Quattro... too many to list.
      02-28-2013, 11:48 AM   #12
PeteX3MWhite
Drives: 2013 X3 35 M SPort
I have this squeak / rattle. It is only noticeable with the sun shade open. When the car goes in for service I'll have them take a look. I think it will go away when it gets warmer out though, I'm not worried.
      03-01-2013, 05:22 PM   #13
Crash Test
Drives: 2013 BMW X3 35i
My creaking was so bad that after several attempts to fix it BMW agreed to replace the entire sunroof assembly under warranty. Nice and quiet now.
      03-02-2013, 10:01 AM   #14
Ashtangi
Drives: 13 X3 35i
I've got it too at only 6500km. It does seem to get worse with the colder temperatures.
If someone could post any information about the official "fix", may make the service experience a bit better - going to take it in soon.
Thanks!
2013 X3 35i | CB | Premium | Executive | Tech | M Sport
      03-02-2013, 11:33 AM   #15
noka
In this thread:
http://x3.xbimmers.com/forums/showthread.php?t=806891
FX3OK posted (on 02-Mar-2013):
Also had them check clatter/rattle from center beam on sunroof.
Cause: plastic divider hitting glass.
Solution: felt tape on divider.
Seems to have fixed rattle.
      03-02-2013, 01:19 PM   #16
FX3OK
FX3OK's Avatar
Drives: 2012 X3 28i
Just had my clattering moonroof looked at yesterday. Service repaired by applying felt tape strip between plastic and glass. Noise fixed (for now)
      03-29-2013, 10:56 AM   #17
halfalife
halfalife's Avatar
England
13
Drives: 3.0D Msport
Just an update, my car has been looked at and I was told there was a spring missing in the sunroof assembly. If that's true or not I don't know , but the noise has stopped so I'm happy.
3.0 Msport, Black, Msport Plus Pack, Media Pack, Interior Comfort Pack , LED's, VDC, B&O speakers, Heated rear / steering, Towbar, Extended storage, Servo Steering.
      03-29-2013, 11:13 AM   #18
noka
If true, this could be the real fix, as opposed to a felt tape workaround. Can you get details from your invoice or dealer service, specifically about the part number used? If not on the invoice, maybe the service dept would share the detail with you.
      04-02-2013, 01:04 PM   #19
nyalpine90
CAPPO
nyalpine90's Avatar
Drives: '16 X4
2016 BMW X4  [5.00]
so after few months, felt tape started coming off since weather is gettin warmer in mid 50s. I havent removed it but i will try another service center to replace sunroof or fix it
      04-02-2013, 11:20 PM   #20
jknj
Drives: 12 x3 in Deep Sea Blue
Had the issue. Dealer worked on it for 11/2 weeks, while I drove a loaner. No noise now. Said it was alignment of sunroof.
      04-03-2013, 08:21 AM   #21
nyalpine90
CAPPO
nyalpine90's Avatar
Drives: '16 X4
2016 BMW X4  [5.00]
i spoke to bmw na, they advise me to go to a differ service shop if i wasnt happy with the attempts to repair the issues so i set an appt with different shop
      04-30-2013, 09:55 AM   #22
Cropwell
Drives: X3 30d
Creaking Sunroof noise sorted!
Had creaking noises from the sunroof when going over bumps and going
round corners. The noise was more apparent in cold weather but basically there all the time.
Booked the car into the dealer for them to look at, they said on first visit that one of the seals was misaligned. This was not causing the problem but they said that they wanted to replace it in case it caused a problem later. Car had to be booked in following week for them to order seal. I think the creaking noise is known issue with the X3(see other postings on this thread) as they dis not quibble and told me they would have to take out the sunroof. In the end the car was in the workshop for a couple of days, partly as they admitted it was the first X3 roof done at the dealership.
But full credit to the dealer the car is now fine and they also sorted a rattle at the back.
Not sure what they did as had to pick up the car quickly from the dealer and as the work was done under warranty I got no invoice.
Having had several BMW's before all of which had bomb proof build quality it leads me to think that QC standards have dropped, not sure if this is due to it being built in USA (compared to German manufacture)?
Car is UK spec.
