XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » still need idle for a while to cool the turbo?
      01-25-2013, 04:37 PM   #1
heverlee
Drives: X3
Hi
Just wonder for 2013 X3, should it be left idle for a while after drive to let the coolant/oill to cool the turbo? I heard this was one major cause of turbo reliability in older ones like the VW 1.8T engine.
thanks
heverlee is offline
      01-25-2013, 05:05 PM   #2
noka
Drives: 2013 x35i M-Sport
Originally Posted by heverlee View Post
Hi
thanks
I don't think it's necessary, especially during cold weather, if you haven't run it really hard but was just driving 'normally'.
Btw, I used to own a GTI with the 1.8T. Bulletproof and never a problem for many miles.
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired: '09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, '01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i,... '86 4000 CS Quattro... too many to list.
noka is offline   United_States
      01-25-2013, 05:43 PM   #3
epiphone3
Drives: 2013 BMW X3 35i
The water pump is electric and the car runs it as required even after you've shut it down.
My belief is that this should help things. One thing, however, is I don't think the water is used to cool the turbo so it may not help at all.
epiphone3 is offline   Reply With Quote
      01-25-2013, 06:21 PM   #4
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
hmm, what is this new fangled start/stop thing you guys talk about?
I suppose that would do more harm having a hot turbo cooking the oil while shut down for 30sec then restarted.
lbjgh is offline   Canada
      01-25-2013, 07:48 PM   #5
heverlee
Drives: X3
this is really a good point.
heverlee is offline   Reply With Quote
      01-26-2013, 12:00 PM   #6
woodchuck1
Drives: 2013 X3 X-drive 35i
I asked the dealer about that. He said that with synthetic oil and modern turbo design and materials, the old turbocharger cool-down requirements are a thing of the past.
woodchuck1 is offline   United_States
      01-26-2013, 01:35 PM   #7
raleedy
Drives: E92 328i MY 2008 (ED 11/14/07)
Hi
thanks
Yes, they've intentionally designed the car so it'll self-destruct if operated normally.
raleedy is offline   United_States
      01-26-2013, 02:06 PM   #8
Nahoa
Nahoa is offline   United_States
      01-27-2013, 05:15 AM   #9
jsmonet
Drives: 2012 135
All modern factory-turbo cars use water-cooled turbos.
Synthetic oil's one big difference from Dino is it cokes instead of sludging. Without the water cooling you would still need to idle or get a turbo timer.
If you have been beating on it, let it idle a minute(ish) before turning off I guess. It isn't that big of a deal
2012 135i. dinan stg3 | ohlins dfv | assorted rice | hardest parker evAr
jsmonet is offline   Reply With Quote
      01-27-2013, 12:11 PM   #10
The X Men
Drives: 2012 535xi 2013 X3 35i
I believe the water pump cools the turbo even after the car is shut off and the oil is only used to lubricate the turbo bearings.
The X Men is offline   Reply With Quote
      01-27-2013, 05:19 PM   #11
FOACAD
Airborne!
FOACAD's Avatar
Drives: 2012 AW/CR 135i Msport
Needing to let the turbo "cool down" isnt a big deal anymore like has been said.
It used to be a huge issue and was the reason why turbo timers were all the rage when people started boosting every car out there.
I have a big turbo MK4 GTI and after beating on it nice and good I do let it cool down before turning it off.
My 135i though? Nah, its good. Beat on it then idle maybe a minute once i get parked then off it goes, same will be the case for my X3 when it comes in a couple months.
FOACAD is offline   Reply With Quote
      01-27-2013, 06:40 PM   #12
Teemo Panda
* A BLUE PANDIAN SMURF * ♠
Teemo Panda's Avatar
Drives: BMW X3, X5
2013 BMW X3  [5.00]
the n20 engine cool down is already fast as it is.
Teemo Panda is offline   United_States
      01-27-2013, 07:46 PM   #13
Jurisprudent
Jurisprudent's Avatar
Drives: '13 X3 35i
I had a 1.8T Passat and did this routinely to protect it. I don't bother with the N55. The Passat had some absurdly small oil capacity, as I recall. That, coupled with the use of non-synthetic oil (at least initially), didn't help.
Jurisprudent is offline   Reply With Quote
Forum Jump
