      01-04-2013, 06:40 AM   #1
philtrick123
Drives: TBA
X3 Jump Start/ Booster Cables- Any Issues
Hi,
I'm sure this must have been covered in a previous thread but can't find it.
Are there any issues with Jump Starting an X3 via booster cables to another car? I understand that Stop/Start cars uses dealer only replace batteries.
I'm paranoid about having a flat battery, after having a stressful 2 hours trying to get my last car (non BMW (as a result of knocking the trunk light switch during unloading)) jump started in an unhelpful French Ski resort.
Fortunately I had backed into the parking spot, otherwise a jump start would have been very difficult with cars parked either side of me.
I presume with the X3 I'm better going nose first into a parking bay, because the battery is in the boot (trunk).
Comments Please
      01-04-2013, 06:44 AM   #2
noka
Drives: 2013 x35i M-Sport
Originally Posted by philtrick123 View Post
Hi,
I presume with the X3 I'm better going nose first into a parking bay, because the battery is in the boot (trunk)...
I believe battery is in the (boot) trunk but jumper post is under the (bonnet) hood.
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired: '09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, '01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i,... '86 4000 CS Quattro... too many to list.
      01-04-2013, 07:10 AM   #3
boogysbmw
Noice
boogysbmw's Avatar
125
Drives: 2023 BMW iX 50drive
^ he's right. Jump post are located in the engine bay
2023 BMW iX xDrive50 - Blue Ridge Mountain Metallic / Oyster Perforated / Ultimate PKG 2 / Sport PKG
2023 BMW X1 xDrive28i - Portimao Blue Metallic / Black perforated /Shadowline/ M sport / premium package
      01-04-2013, 07:17 AM   #4
02420X3
Drives: 2011 X3 35i
Noka is correct. There are terminals under the hood for the specific purpose of jumpstarting your X3. In the US '13 owner's manual the location is described on page 245 in the section called Engine Compartment. In the attached photo, copied from the manual, #3 is the Negative Terminal and #4 is the Positive Terminal. Again, this is from the 2013 US manual. The location of the jumpstarting terminals may be different for other model years and/or in other countries.
      01-04-2013, 10:20 AM   #5
plymjack
Nuclear Chief of the Watch
plymjack's Avatar
Drives: X3 (F25) 2.0D, i3 BEV
Hi,
Can anyone explain this please?
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats
Canon 70D 500mm, 85mm, 40mm, 24mm
Sony QX10 & GoPro Hero 3
      01-04-2013, 10:34 AM   #6
02420X3
Drives: 2011 X3 35i
I was curious about that statement also.
What I do know is that all F25s, including those built before Auto Stop/Start was added, use an Absorbed Glass Mat (AGM) battery technology, rather than the more familiar Flooded Lead Acid technology. AGM batteries are available after-market, and I'm sure it's possible to find one with the right specifications. However, there's more to replacing the battery in an X3 than just replacing the battery. There's is also software that needs to be set up, including registering the new battery and resetting battery information in the X3, work that is best done by a BMW dealer.
      01-04-2013, 11:02 AM   #7
philtrick123
Drives: TBA
Thanks for the explanation- so the x3 batteries are available after market, but I presume the process to reset the X3 is not freely documented so an end user cannot replace the battery.
      01-04-2013, 11:12 AM   #8
3Bimmer
3Bimmer's Avatar
Drives: 2013 X3 35i
The X3, like all BMWs, has a battery rundown protection feature. If you leave a light or plugged in device on, the car will shut the power off after about 20 minutes. This prevents the battery from being completely depleted. Unless you have a more serious electrical failure, you should not be in danger of running the battery flat.
Having said that, it is always a good idea to know how to jump start your car and where the cable connection points are. A battery booster is also a good idea, especially when traveling.
      01-04-2013, 11:58 AM   #9
02420X3
Drives: 2011 X3 35i
There's also the matter of installing the battery so that it is properly vented.
The software changes/reset are made using BMW's ISTA diagnostic software.
