XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Problem with F25 X335i, help!
      11-23-2012, 02:32 PM   #1
nrrm1127
nrrm1127's Avatar
Drives: 2011 E90 328i SG/SB
Send a message via AIM to nrrm1127 Send a message via Skype™ to nrrm1127
Unhappy Problem with F25 X335i, help!
This morning I get a sudden warning stating, "xDrive and DSC Malfunction" anybody have any ideas on this? On another note, I also picked up a set of used snow wheels and tires (Breyton Race GTS and Bridgestone Blizzak LM-60) equipped with TPMS. Wheels were originally on a 335 sedan and are OEM 335 fitment (225/40/18 front and 255/35/18 rear). Getting an error that says TPMS malfunction. It was working fine for 3 days until this started happening. This TPMS error has been happening for about a week and then all of a sudden this morning I get the xDrive/DSC error. Any help would be greatly appreciated, thanks!
- R
1997 Aston Martin DB7 - Merlot Red
1999 Dinan S3-M3 Convertible - Titanium Silver
2008 Mini Cooper S Convertible Sidewalk
2011 F25 X3 xDrive35i - loaded w/19's
2011 BMW 328i - Space Gray on Saddle Brown
nrrm1127 is offline   United_States
      11-23-2012, 04:17 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
You are using the tire sizes you mention as OEM on the sedan?
I suggest that is your problem, completely messing with the wheel speeds. Watch you don't cause issues with the transfer box as well, as XDrive is very sensitive to tire sizing front to rear.
HighlandPete
HighlandPete is offline   Reply With Quote
      11-23-2012, 10:55 PM   #3
X Three
Drives: 2011 BMW X3 xDrive28i
Transmission Malfunction
About the "xDrive and DSC Malfunction" issue - I am currently trying to get my X3 fixed for a transmission malfunction.
As I was driving (20-30 mph) the car appeared to disengage the transmission then there were a couple of sharp jolts, almost like the transmission shifted abruptly. It was very noticeable and the car was very unresponsive. I immediately pulled the car off the road. During that time the error message "Transmission malfunction" was displayed, following that message another message appeared "DSC and xDrive Malfunction". I turned the car off and then restarted, and it appeared to be functioning/driving/shifting normally. This was the second time this issue occured, the first, however, I did not get any error messages and only the sharp jolts from the transmission and I did not need to restart the car.
I would recommend taking your car in to get checked, I ignored it the first time, thinking it was nothing serious. I took it in to get diagnosed, and your error message may be a different issue, but it appears that if you get any of these messages the car is going into a "safe mode" for some reason. In my case there seems to some kind of transmission fluid temperature sensor issue, I still have to bring it back, and will update here when I get the final fix, if any. . .
X Three is offline   Reply With Quote
      11-23-2012, 11:05 PM   #4
gareth12468
Drives: 2011 X3 xDrive 28i
2011 BMW X3  [0.00]
My 28i has the same issue as yours 5 times. The dealership and BMW Canada finally have to replaced the mechatronic unit and reprogram my car.
Here're the errors I have.....
http://x3.xbimmers.com/forums/showpo...&postcount=197
gareth12468 is offline   Canada
      11-23-2012, 11:21 PM   #5
X Three
Thanks Gareth for the info, I had basically seen the same sequence of error messages. I'll have to mention your fix the next time I bring the car in. I noticed that there are several other related posts circulating around with others experiencing the same malfunction errors, and figured it might have something to do with the mechatronic unit.
      11-24-2012, 01:28 AM   #6
brissim
Drives: X3 30d (2011 F25)
I realise this has probably got nothing to do with your error messages, and from my location I'm obviously not familiar with your local laws, but I am surprised it is legal fitment to use wheels/tires with such a large variation from the F25 OEM tire size (~10% difference in overall diameter).
Tony
brissim is offline   Reply With Quote
      11-24-2012, 03:54 AM   #7
brissim
And one further thought - what is the load rating on those tires you have on? Given the F25 X3 is 500+ lb heavier than a 335 sedan (ie 20% heavier) I'd doubt the tires from an 335 sedan would have a high enough load rating for an F25 X3.
Tony
      11-24-2012, 04:19 PM   #8
nrrm1127
nrrm1127's Avatar
Tony -
Load rating is fine these have an XL load rating, which is designed for heavier vehicles (these Blizzaks come as an XL standard). Car has exhibited no weird behavior with all of the error messages. Leads me to think the DSC module is at fault.
gareth - what's the mechatronic unit?
Car is going in for service Monday afternoon, should know something by Tuesday/Wednesday. Will keep all of you posted. If anyone has suggestions, please continue to write them here. Thanks!
- R
      12-04-2012, 04:10 PM   #9
nrrm1127
nrrm1127's Avatar
We have a solution everyone. Issue was down to the sidewall size on my tires. BMW Dealer put the OEM Style 309s back on and all error messages disappeared. Called up Tire Rack and was told I could keep the staggered Breyton's, but would have to run 245s all around (I don't want heavy duty snow tires like the Bridgestone Blizzak WS70 since the dry and wet, rain not snow, grip is diabolically dangerous). Had to go with a set of Pirelli Winter 240 Sottozero Serie II in 245/50/18 all the way around and I've been assured that will solve the issue (Tire Rack has been dead on every single time I've ordered from them and had product questions). To deal with the TPMS issue, I'm ordering a new set of TPMS sensors just to be on the safe side.
      12-04-2012, 04:54 PM   #10
colson79
Drives: 2012 X3 35i DSB
Why do people post such non-sense? Blizzak WS70 are "diabolically dangerous" on wet and dry pavement? What a load of crap. While they may not be the best tires for your situation, they are far from dangerous. Where are you getting this from anyway? I have read a lot of reviews of the WS70's and I haven't seen this before. Tire Rack, who you seem to trust seems pretty happy with the WS70's. http://blog.tirerack.com/blog/hunter...?affiliate=TX3
2012 X3 35i | Deep Sea Blue | Oyster |
Packages | Sports | Cold Weather | Cold Weather 2 | Premium | Technology | Premium Sound
colson79 is offline   Reply With Quote
      12-04-2012, 05:01 PM   #11
raleedy
Drives: E92 328i MY 2008 (ED 11/14/07)
This is coming from someone who put staggered wheel and tire sizes on his AWD truck and then wondered why he got error codes.
raleedy is offline   United_States
      12-04-2012, 06:23 PM   #12
tango131
Drives: Boxster S; 2013 X3 28i
the OP's post should be a cautionary tale. RTFM folks. with these modern cars, and especially with AWD cars, one can't just go strapping on wheels/tires all willy nilly. the cars ABS, traction control, etc. computers can adjust for about + or - 3 - 5% difference in rolling diameter without adjusting the settings. anythign else and you'll get codes.
2013 X3 28i, AW, Chestnut, Sienna, ZAP, ZCV, ZCW, ZDH, ZPP, rear view, park distance, cargo net (Wife's) (Pics and story)
2010 Porsche Boxster S (Mine)
tango131 is offline   Reply With Quote
      12-04-2012, 11:46 PM   #13
DonC
Drives: 2013 X3 3.5i M sport, etc
Agree - these are systems not seperate items - if you change one part it impacts the system. Tire size changes are one such item that can only be chaged within certian limits before the system says - time out.
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars
2005 S2000
2007 TL-S
DonC is offline   United_States
      12-05-2012, 06:33 AM   #14
Nahoa
Nahoa is offline   United_States
      12-05-2012, 09:34 AM   #15
nyalpine90
nyalpine90's Avatar
Drives: '12 X3 28i AW
2012 X3  [4.50]
Send a message via MSN to nyalpine90
TPMS ON F25 are different from E90 or E92 check that out
nyalpine90 is offline   Colombia
      12-05-2012, 02:20 PM   #16
nrrm1127
nrrm1127's Avatar
The dry and wet weather handling is not exactly great, having had a less than satisfactory experience with the WS60s. Look to each his own, but from my experience the LM Series tires are much more responsive for my winter needs. I'm getting this from personal experience (if that's alright with you).
      12-05-2012, 02:21 PM   #17
nrrm1127
nrrm1127's Avatar
And to everyone else, yes lesson learned. Should've known better thinking I could attempt to be more cost effective rather than just doing it right from the start.
      12-06-2012, 08:34 AM   #18
nyalpine90
nyalpine90's Avatar
2012 X3  [4.50]
where do you get your info, who said you cant put stagger wheels on awd?
FYI you can put staggered wheels on x3!
      12-06-2012, 10:57 AM   #19
colson79
"Not great" or not as good as the LM series for your needs is quite a bit different than "diabolically dangerous" as you posted earlier.
      12-06-2012, 11:38 AM   #20
tango131
yes, you can put staggered wheels on the x3.
what you can't do is put on wheels and tires with vastly different rolling diameters from stock, which is what the OP did.
      12-06-2012, 12:56 PM   #21
xDrive35i
Drives: 2011 X3 35i
Please search for the thread about this.
2001 Audi A6 Allroad 2.7T (C5); 2005 Audi A6 4.2 Quattro (C6); 2005 BMW X5 4.4i (E53); 2008 BMW 535xi Sports Wagon (E61); 2011 BMW X3 xDrive35i (F25); 2009 Audi A4 3.2 Quattro Prestige (B8)
xDrive35i is offline   United_States
Tags
dsc, malfunction, xdrive, xdrive35i
Forum Jump
