XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Winter Wheels for Canadians
      11-14-2012, 09:01 PM   #1
c3uo
Drives: 3 Series
Just picked up 17" winter wheels from Costco for my M-Sport X3.
M3 replica wheels. I plan to add M stickers and use my OEM centre caps.
Hopefully they'll look good. Waiting for Pyspeed TPMS delivery and then will mount tires.
c3uo is offline
      11-14-2012, 09:58 PM   #2
BMWX3MDD
Drives: 2013 X3 M
Canadian version shouldn't need the TPMS sensor.. as I put on my winter wheels and do not require that.
BTW nice rims, how much did you get it for and from which costco, if you don't mind be to ask..
BMWX3MDD is offline   Reply With Quote
      11-14-2012, 10:03 PM   #3
pokerface
pokerface's Avatar
Drives: B8 A4 2.0T
looks like: http://tires.pmctire.com/ent/catalog...ult/?q=ABW770C
olor Hyper Silver Diameter 17
SKU ABW770C Number of Nuts/Bolts 5
Manufacturer Macpek Offset 35
Bolt Circle 120 Width & Diameter 17X8
Bolt Pattern 5x120 Width 8
Centerbore Size 72.6
http://www.wheelsmacpek.com/entreprise.html
F25 X3 N20:
2010 B8 A4 2.0T quattro (current)/
2013 F25 X3 x28 N20 (babymobile)
pokerface is offline   Canada
      11-14-2012, 10:25 PM   #4
c3uo
Drives: 3 Series
Yes they're Macpek wheels. $116.99 each at Costco. Ordered in from my local NB Costco. they Should be available at any via order. Not sure of quality, but like Costco return policy if I have a problem.
I have a US import X3, so TPMS is required.
c3uo is offline   Reply With Quote
      11-16-2012, 10:08 PM   #5
BMWX3MDD
Drives: 2013 X3 M
Oh, no wonder you will need the TPMS.. I m at Ottawa, and costco don't sell alloy wheels.. careful with the front caliper after I installed the wheels and notice the front wheels are quite close to the caliper, I would say only about 2-3mm left..
post on some pictures after.. the wheels are quite nice..
      11-17-2012, 05:52 PM   #6
UncleJohn
Drives: 2013 BMW X3 xDrive28i
where did u pick up your winter tires? im in Ottawa as well, just curious as i am still shopping around. i was even thinking of running on my all-seasons since they only have 1k on them but that might be rough for the winter they are forecasting...
UncleJohn is offline   Reply With Quote
      11-19-2012, 08:53 AM   #7
BMWX3MDD
Drives: 2013 X3 M
Actually I puchased mine at Toronto last month, as they are better price..I was thinking to go with costco, cause the road hazzard policy. but they don't carry the wheels. So I went to one of the shop at T.O. and bought a set of 17" replica wheels and pirelli tires..
But I think I should get 18" instead casue mine is M package 17" seems a bit small..
      11-19-2012, 09:40 AM   #8
BMWX3MDD
Drives: 2013 X3 M
thinking to just sell it out and get the 18" instead.
      11-21-2012, 05:27 PM   #9
jlr_1304
jlr_1304's Avatar
Drives: none
I have the 18" version of these rims + 245/65/R18 run flat tires.
They are available in montreal, near the PET airport.
jlr_1304 is offline   Canada
      11-21-2012, 11:03 PM   #10
BeeMdblU
BeeMdblU's Avatar
Drives: Audi A4, CLK55, F25 35M
the tires are 245/50/18
BeeMdblU is offline   Reply With Quote
      12-13-2012, 03:53 PM   #11
TechGuy335
Drives: 2012 335i
Do the OEM center caps fit?
Hi guys,
Just joined the site, this is my first post.
I just bought the same M3 replica wheels (18") for my 2012 335i. Mine are actually the Macpek ones (very similar to c3uo's wheels in the pic above) that you can see at this link:
http://winter-tires.pmctire.com/enw/...-35-72-92.tire
I'm still waiting to get these installed but I'm curious if the OEM center caps on my 335i will fit on these rims? I'm also thinking of buying some generic BMW center caps to use on these wheels.
TechGuy335 is offline   Reply With Quote
      12-13-2012, 09:57 PM   #12
c3uo
Drives: 3 Series
The OEM BMW Centrecaps fit from my X3. Sorry I have no pictures on the X3 with tires, but here's a picture prior to getting the tires mounted:
      12-13-2012, 10:05 PM   #13
BMWX3MDD
Drives: 2013 X3 M
very nice!!!!
did you find that the caliper at the front are quite close to the rims??
      12-17-2012, 07:47 AM   #14
slyfox
slyfox's Avatar
Drives: X3-20d (2013)
This begs the question....
How are you getting to the tyre center, in that condition.
slyfox is offline   Belgium
Forum Jump
