XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Hurricane Sandy Affects Tire Pressure Monitoring Systems
      10-30-2012, 11:37 AM   #1
morrisryanc
Wrap anything in bacon and it's instantly better.
morrisryanc's Avatar
Drives: '13 X3 28i M-Sport
Wife just called me from the road in our week-old '13 X3 M-Sport. She said all four TPMS (tire pressure monitor sensors) had gone off and the graphic warning was showing 4 tires in yellow. I knew it would be almost impossible for all tires to be low like that at the same time...so I turned to the forums.
My hunch was that since the tires are filled with air, they would be susceptible to pressure losses/gains as a result the drastic temperature change (it's been in the 60s (Fahrenheit) the last several days, but then Hurricane Sandy came and it dropped 25-degrees. Also, the barometric pressure went nuts as a result of the Class-1 hell-raiser.
I found a post from a 3-Series thread that was several years old and it stated that drastic temperature changes or massive changes in barometric pressure can affect the amount of pressure your tires keep. Phew.
The tires of our 1-Series are filled with nitrogen instead of air. I haven't driven it today, but I'm betting the TPMS doesn't go off, as nitrogen isn't affected by temp/pressure changes like regular old air.
Do you live in the area affected by the hurricane? Did you experience an "all four tires are low" warning this morning? Sound off!
2013 X3 28i ///M Sport | 2012 128i Cabrio | 2010 Mercedes C300 Sport | 2009 Yamaha R6 | 2006 MINI Cooper S (retired)
morrisryanc is offline   United_States
      10-30-2012, 12:21 PM   #2
cblounder
cblounder
Drives: 2009 BMW 135i CV
Had the same issue this moring with my X3 and 1er, I broke out my contikit and equalized all the pressures and reset the TPMS.
Current:
2013 X3 xDrive35i Titanium Silver
2009 135i CV Blue Water Metallic
Past:
2008 X5 4.8i, 2003 e46 330Ci
cblounder is offline   United_States
      10-30-2012, 12:34 PM   #3
3Bimmer
3Bimmer's Avatar
Drives: 2013 X3 35i
I experienced this on our first 'cold' night of the season. The temps had dropped down to a brisk 52. I started the car and all 4 wheels had low pressure. I pumped each tire up and reset the TPMS and it has been fine since. I always keep a close eye on tire pressure, so this will keep me on my toes!
3Bimmer is offline   United_States
      10-30-2012, 10:46 PM   #4
96_Impreza
96_Impreza's Avatar
Drives: 96 Impreza,07 Vette,11 X3 35i
Very roughly:
+/- 10 degrees F = +/- 1 psi
+/- 2500 ft elevation = +/- 1 psi
Tires lose about 1 psi month
Air is about 78% nitrogen
96_Impreza is offline   Reply With Quote
      10-31-2012, 01:21 PM   #5
dandanio
The one that drives!
dandanio's Avatar
Drives: 11 x3 35i/09 Jetta TDI
Nitrogen or not, it is still a gas, thus the ideal gas law still applies. Although has slightly better characteristics than air, but the keyword is SLIGHTLY, and as such, any and all nitrogen filling is a ripoff, IMHO. I usually fill my tires with a healthy mixture of mostly nitrogen (78%), some oxygen for a good measure (about 21%) and some other gases (argon, helium etc.) for a great taste!
dandanio is offline   United_States
      10-31-2012, 05:52 PM   #6
Marathon Man
Drives: 2013 X3
Dandanio is correct - air or nitrogen would have no noticable difference in response to changing temperature.
96_Impreza's approximation of 10 degree F temperature change = 1 psi pressure change is pretty good. So a 25 degree drop in temperature could drop your tire pressure 2.5 psi. This is likely the cause of the sudden alarm on 4 tires. The tires were probably already toward the low end of acceptable and the temperature change moved them low enough to alarm.
I would need to know more about how the TPMS works to comment on the affect of a hurricane (low atmospheric pressure) would be on the TPMS reading. But a normal pressure gauge actually measures the difference between the inside tire pressure versus atmospheric pressure. A drop in atmospheric pressure from a hurricane moving through would show a INCREASE in tire pressure. The pressure inside stays the same but the gauge reading would go up since the reference atmospheric pressure went down. Plus the most impact on pressure you would likely see is about 1 psi difference one way or the other unless you are checking your tires as a Cat 3 storm passes over you. I've been in a Cat 3 storm and I was NOT worrying about my tire pressure! Sandy, while a large storm with a huge impact on people, was only a Cat 1 storm.
All of this assumes the tires don't change in volume too much with changing temperature and atmospheric pressure. I have no data on that!
Marathon Man is offline   Reply With Quote
      11-01-2012, 08:07 PM   #7
bluesmachine
Drives: 2011 X3 35i White / Chestnut
Funny - I live in western Massachusetts and although we had high winds and some rain, we did not really get slammed.
Still TPMS went off show all 4 tires in yellow. Tires were 30 in front and 34 in rear with none showing any flat signs.
I will go to gas station and fill them up and see whats up.
Weird.
bluesmachine is offline   United_States
      11-01-2012, 10:27 PM   #8
02420X3
Drives: 2011 X3 35i
Remember, it's not whether or not the tire pressures are within spec, it's whether or not the tire pressures are in the range that the TPMS considers normal since it was last reset. As temperatures fall at this time of year more people will see TPMS errors, especially those who have not been diligent about checking and correcting the air pressure of their tires over the last few months.
Sadly, at least in the US, when TPMS detects a problem it shows all four tires, not just the problem tire. (This may be changeable with coding. Perhaps April1 will comment on that.)
02420X3 is online now   Reply With Quote
      11-01-2012, 10:46 PM   #9
96_Impreza
96_Impreza's Avatar
Originally Posted by 02420X3 View Post
....Sadly, at least in the US, when TPMS detects a problem it shows all four tires, not just the problem tire. (This may be changeable with coding. Perhaps April1 will comment on that.)
Our '07 Chevy's TPMS displays digital psi for each tire but our '11 X3 35i displays four yellow or green tire icons.
      11-01-2012, 11:38 PM   #10
April1
Love All
April1's Avatar
Drives: X3 28i 2011
It's not correct, I had a problem with one tire and it pointed out the right one. Also through coding, you can always monitor the pressures of all tires before proceeding on for a long drive.
      11-02-2012, 07:29 AM   #11
plymjack
plymjack's Avatar
Drives: X3 (F25) 2.0D SE Auto
Its is the change in atmospheric pressure that is causing the problem. The centre of the storm is a very low pressure - 930mB normal pressure is around 980mB - this would cause the differential pressure between the tyres and atmosphere to change.
Dont and
BMW X3 (F25) xDrive20d SE . . Alpine White. . Oyster Leather . . 8 Speed Servotronic. .RFTs. . High Beam Assist. . Electric Seats . . DAB Radio. .USB/Bluetooth
plymjack is offline   United Kingdom
      11-02-2012, 08:37 AM   #12
cadman50
Drives: 2012 X3 35i
My tires were filled correctly to 32 front/38 rear and my TPMS was reset. I checked them the other day and they were all down 2lbs air. I didn't get any warnings. What is the amount of air loss that will set off the warning? Do you get a message displayed on the instrument screen that warns of air pressure loss or do I need to go into vehicle status to see if I have low air?
cadman50 is offline   United_States
      11-02-2012, 08:49 AM   #13
April1
Love All
April1's Avatar
Drives: X3 28i 2011
You get first a message on instrument console followed with a yellow triangle as a warning status.
      11-02-2012, 02:23 PM   #14
cadman50
Drives: 2012 X3 35i
Thanks. but how much air pressure loss will it take to set off the warning?
      11-02-2012, 02:34 PM   #15
rpiopio
rpiopio's Avatar
Drives: 2006 330i, 2011 X3 35i
2011 BMW X3  [0.00]
2006 330i  [0.00]
Wow. Weird coincidence. My wife called me this morning and all 4 tire pressure sensors also alerted her of low pressure. We're nowhere near the east coast. We're in the Bay Area. I checked all four and sent her on her way.
2006 330i: Titanium Silver, Black Leatherette, Navigation, European Delivery.
2011 X3 35i, Alpine White, Premium, Technology, Sport Package
rpiopio is offline   Reply With Quote
Forum Jump
