XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Winter tyres on existing wheels
      10-27-2012, 12:35 PM   #1
gaz26
Drives: Z4 sdrive35, X3, 1M
Does anyone just buy the tyres and put them on existing wheels. My local tyre dealer would swap them each season for £15 a wheel.
gaz26 is offline
      10-27-2012, 06:03 PM   #2
Nahoa
I did and have before. Put the Pirelli Sotto Zero IIs on the OEM wheels now that they're available in the proper size.
Nahoa is offline   United_States
      10-28-2012, 04:31 AM   #3
troggy1969
Drives: X3 3.0D SE Bluewater
I have changed tyres previously but wanted to keep my X3 wheels clean and away from winter salt so bought some previous generation X5 wheels off ebay for winter.
The local tyre fitting centre charged me £25 to change all 4 last year.
troggy1969 is offline   Reply With Quote
      10-28-2012, 05:09 AM   #4
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
BMW charge £30 to change all 4 wheels if you buy winter wheels and tyres from them. I put them in the back and then store them myself but I they charge £30 to store.
I thought I read somewhere that there are issues / difficulties with removing run flat tyres (i.e. they get weakened or damaged when they are removed) but I can't find the post now so that may be BS.
The other consideration is damage to alloys caused by switching the tyres every time
      10-28-2012, 06:44 AM   #5
cooldude00
Drives: x3 2.0d
i think they charge more than 30 quid to store as otherwise i would have gone for it.. think it was closer to 100..
it's here!!!
cooldude00 is offline   Reply With Quote
      10-28-2012, 07:00 AM   #6
sfax
sfax's Avatar
It's £30 but only if you buy the tyres from them:
A set of winter wheels and tyres, with their special rubber compound and grooves is available from £700 RRP per set* and means you'll have no problem stopping - or going - during the colder months. To make life easier for you, we'll even store your standard wheels and tyres for just £30 until it's time to switch them back again in spring.
http://www.bmw.co.uk/bmwuk/owner/win...tSource=topNav
      10-28-2012, 08:53 AM   #7
cooldude00
Drives: x3 2.0d
hmm... might just do that this year then... thanks!
it's here!!!
      10-28-2012, 11:25 AM   #8
HighlandPete
Drives: BMW F11 535i Touring
Both valid reasons, I certainly wouldn't want RFTs on and off the rims, (it can be quite brutal) simply for the fitting risks and costs.
Tyres have a very small cost penalty long term, as you are only using one set at a time and rubber will last longer. Rims have value secondhand, so that isn't really dead money either. But mounting, balance, etc., is around £10 per wheel (or more) in most tyre shops, so with two changes a year, around £80 to £120. That is dead money.
HighlandPete
HighlandPete is offline   Reply With Quote
      10-28-2012, 04:50 PM   #9
Nahoa
No storage option here. That influenced me quite a bit. The wheels with tires were a bear to move around.
      10-29-2012, 01:57 AM   #10
BMWLVX
Drives: X3 2.0d
Would people still have the same fear about their RFT on /off if it was just a summer tyre being replaced due to a flat? Same deal really. Can't see the issue myself. I've had my OEM also changed to winter tyres.
So, question about my wife's X3…
BMWLVX is offline   Reply With Quote
      10-29-2012, 08:23 AM   #11
Teemo Panda
* A BLUE PANDIAN SMURF * ♠
Teemo Panda's Avatar
Drives: BMW X3, X5
2013 BMW X3  [2.75]
The local tyre fitting centre charged me 25 to change all 4 last year.
That's a great idea, but you could always plasti dip your wheels which you could peel after the winter season is done. Saves you from buying a set of rims :P
Cost like 30$ in total :P
Teemo Panda is offline   United_States
      10-29-2012, 08:33 AM   #12
sfax
sfax's Avatar
It's not really the same though is it? If you replace an old or damaged tyre, you are replacing it with a brand new tyre that hasn't already been used and then forced off a wheel. The concern is over the damage done to a tyre that you intend to use again, when you take it off.
The alloys are also at more risk of being damaged too because every one has at least 2 changes every year, rather than say 1 change every 2 years
      10-30-2012, 06:50 AM   #13
BMWLVX
Drives: X3 2.0d
Surely tyre manufacturers would put some warning on the tyres telling people there is a risk of doing this. Right? Right???
Forum Jump
