XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Shell V- Power shown to make 5 more HP than regular gas
      10-25-2012, 09:20 AM   #1
tango131
Drives: Boxster S; 2013 X3 28i
Apologies if this was covered before, but I was watching yesterday’s episode of 5th Gear on BBC America (the one where they test the Toyota/Scion FT-86, Kia Sportage, and Tiff races a Lambo in the Lambo Cup), and saw a very interesting report on whether premium gasoline (petrol) produces more power than regular gas, at least for UK gas.
They tested shell v- power 98 ROM = 93 premium in the US, BP ultimate 97 RON ~ 91/92 premium in the US and 2 “regular” non premium gasolines. They tested the gas on a 2.0 turbo GTI and a dyno (rolling road for you Brits) and had rigs to switch between gas types w/o contaminating or having left over gas in the tank. The results were that the Shell v- premium made about 5 HP more on the dyno to the wheels. I find that a significant result just by using good gas. See a screen shot pic of results. I have no idea if the gas sold in the US would have a similar formulation, but I would hope so. Esso (Exxon/Mobile in the US) premuim gas also had close to a 5 HP advantage over regular gas.
Back when I had a turbo Subaru I could swear that I felt the car ran stronger on shell V-power, but had no proof. I’ve been using v-power since. I theorize that premium gas has a greater effect on turbocharged cars as the cars computer can slightly adjust timing and boost to make more power. As our X3’s are all turbo now (and the X35 since 2011), I figured to pass this along. I know I’ll continue to use shell v-power 93 (US RM/2) on all my cars.
2013 X3 28i, AW, Chestnut, Sienna, ZAP, ZCV, ZCW, ZDH, ZPP, rear view, park distance, cargo net (Wife's) (Pics and story)
2010 Porsche Boxster S (Mine)
tango131 is offline
      10-25-2012, 03:03 PM   #2
rmeir
Drives: x3
all i know is mine runs better on shell and i get better mileage
rmeir is offline   Reply With Quote
      10-25-2012, 03:07 PM   #3
paul386
Drives: 2011 X3 35i Jet Black
There are so many things at play here that it would be super difficult to actually determine what is causing the power change. In the United States of course, we all have to subsidize the farmers and burn low energy / high pollution / high price ethanol.
The one thing I do know for certain. Octane rating does not change the energy content in the fuel.
paul386 is offline   Reply With Quote
      10-25-2012, 05:24 PM   #4
HighlandPete
Drives: BMW F11 535i Touring
Our engines have knock sensors, so the higher octane fuels will allow for more advanced timing and therefore (in most cases) more efficient power development.
Most BMW engines are rated on the higher octane fuels, for output and fuel economy. Certainly my N55 535i engine is, as is stated in the UK BMW brochure.
Older brochures used to say something like the following (for the UK market). "The 6-cylinder and 8-cylinder petrol engines are designed for RON 98 fuel. They may be run on fuel down to RON 91 with a slight decrease in engine power and an increase in fuel consumption".
HighlandPete
HighlandPete is offline   Reply With Quote
      10-25-2012, 09:41 PM   #5
carlili4190
Drives: 07 Nissan 350Z, 11 BMW X3
+1
carlili4190 is offline   Reply With Quote
      10-25-2012, 11:19 PM   #6
car_fan
car_fan's Avatar
Drives: 2012 F12 650cic / 2012 E92 M3
As a matter of habit I always run Shell V-power and have done so for years.
2012 650cic Space Gray/Vermillon Red/Blk.Top(retired)
2011 MINI CooperS BRGII/Lounge Green/Sport/Prem/Connect/Black Xenon/Black Conical Spokes/ACS springs/ACS exhaust/Alta Shorty
2012 M3 AW/FR NDH2/2MK/ZPP/ZCP/ZCW/752/6NR/OEM CF splitters/OEM CF Mirror caps
2012 X3 35i Titanium Silver/Black ZAP/ZPP/TECH/APPS/Breyton GTS/Continental Extreme DW
car_fan is offline   Reply With Quote
      10-26-2012, 03:10 AM   #7
HighlandPete
The test, here in the UK, was switching fuel only. Can't see what else is coming into play except the fuel itself, and the ECU adapting to the knock rate. OK, the fuel additive package could be different, as it often is across brands, but the HP change is from switching fuel and octane rating. All fuels would have been to the same British Standard.
One of our tuning companies (Thorney MotorSport) also ran some extensive dyno tests on different fuels. A tuned BMW M3 CSL showed a 40HP gain running on RON 99, compared to the standard RON 95 fuel. Other less tuned engines (with knock control) also showed consistent improvements in HP, as the octane rating was increased.
HighlandPete
      10-26-2012, 01:13 PM   #8
tango131
HighlandPete
exactly. they only changed the gasoline and listed the average dyno (rolling road) reading of 3 separate pulls per type of gasoline.
fifth gear won't let us in the US view the vidoes on their website. perhaps someone fromthe UK can post the episode video.
tango131 is offline   Reply With Quote
      10-26-2012, 03:00 PM   #9
HighlandPete
Seems since Fifth Gear has be pulled from TV, even over here we have issues accessing their episodes/videos.
Does this link?
HighlandPete
      10-26-2012, 03:12 PM   #10
tango131
Pete, that video works, but it is not the episode I saw a few days ago, which used a new white GTI 2.0 turbo
      10-26-2012, 04:20 PM   #11
HighlandPete
Try this one.
HighlandPete
      10-26-2012, 04:52 PM   #12
tango131
that is it indeed. thank you
Forum Jump
