XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Key Range- Keyless Ignition
      10-17-2012, 03:28 AM   #1
philtrick123
Drives: TBA
Hi,
This is more out of interest- how far is the key range for the X3 starting system? And does the car cut out if the key is removed when running?
The reason I ask the question- the other day I started the X3, then drove the car around to my garage, got out of the car with the key to unlock the garage.
I thought that the engine would stop because the key was no longer in the car, but it didn't.
I'm starting to think that once the car is running it doesn't check for key presence until you try to start it again.
So could I (in theory), start the car, put the keys in house and then drive off? Use this for Valet parking?
philtrick123 is offline
      10-17-2012, 04:49 AM   #2
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
You can work out the range by trying to press the stop/start button with the key held in various positions when the ignition is off. It has to be quite close (probably less than 1 meter) and you get a "no key present" error if it's too far away. There is no check after the ignition is started and no cut out if the key is removed - to my knowledge anyway. Re. valet parking, OK if you're happy for it to be left parked unlocked
      10-17-2012, 08:22 AM   #3
dandanio
The one that drives!
dandanio's Avatar
Drives: 11 x3 35i/09 Jetta TDI
Well, you are wrong with the concept.
In order to start the vehicle you NEED the key present in the cabin. But in order to have the engine running (after it is started), you DO NOT. You can throw the keys away through the window while driving and the car will run just fine, it is just, when you turn it off, it won't restart. As for the range, since it is an RFID communication, it is not a great range, within a cabin only.
dandanio is offline   United_States
      10-17-2012, 09:21 AM   #4
epiphone3
Drives: 2013 BMW X3 35i
The X3 gives a warning if you leave the engine running and get out of the car (far enough away, of course). Mine does it every time a go to get my mail. The engine keeps running. IF you try to start without the key basically in the car, it won't.
epiphone3 is offline   Reply With Quote
      10-17-2012, 10:30 AM   #5
pokerface
pokerface's Avatar
Drives: B8 A4 2.0T
its a safety issue. If there was a battery failure in the key you wouldn't want the car to shut off on you while you're driving ...
F25 X3 N20:
2010 B8 A4 2.0T quattro (current)/
2013 F25 X3 x28 N20 (babymobile)
pokerface is offline   Canada
      10-18-2012, 01:32 AM   #6
April1
Love All
April1's Avatar
Drives: X3 28i 2011
It's a keyless car for convenience but there is a button to start/ stop. Does any one have remote start/ stop?
      10-18-2012, 03:11 AM   #7
Chris55
Chris55's Avatar
Drives: 2013 X3 35d M Sport
I agree, it just makes sense.
Chris55 is offline   Switzerland
      10-18-2012, 07:11 AM   #8
philtrick123
Drives: TBA
Correct me if I'm wrong, but I would have thought that the element in the key that enables engine start is not battery powered. Again I'm guessing that the car uses NFC to check for a passive component in the key. The battery in the key is just for the door/ boot(trunk) unlock function.
Can anyone confirm
philtrick123 is offline   Reply With Quote
      10-18-2012, 07:15 AM   #9
dandanio
dandanio's Avatar
Can anyone confirm
There are TWO elements in the keyfob: one, active is responsible for enabling you to start the car with the keyfob in the cabin, and that one is battery powered, and the second one, very short range, that you need to hold to the steering column in the event of a battery failure.
      10-18-2012, 07:20 AM   #10
philtrick123
Drives: TBA
I'm amazed that there is an always on active component in the fob. I would have thought the small battery wouldn't last too long, or is it very low power.
      10-18-2012, 08:13 AM   #11
richy577
Pokerboy
Drives: BMW M Sport 2.0D
My guess would be it contains a RFID chip and therefore may not need a battery.
richy577 is offline   United Kingdom
      10-18-2012, 08:41 AM   #12
sfax
sfax's Avatar
I think it's only always active if you have a comfort access / keyless entry fob. Otherwise I assume non-powered RFID as suggested above
      10-18-2012, 09:45 AM   #13
philtrick123
Drives: TBA
Just tested- I opened the car from a distance, then removed the battery from the fob. The X3 would not start and eventually prompted me on the drivers display to hold the fob near to the emergency sensor on the steering column. Started ok once the batteryless fob was held close to the zone. Turned the engine off. Reinserted the battery and tried again, car fired up with the key in the cubby hole in front of the gear selector (as per usual).
So it looks like there is an active component (what is it?) in the fob for key in car start-up, and also a emergency non active chip for when the fob battery dies?
      10-18-2012, 09:54 AM   #14
dandanio
dandanio's Avatar
Told you. Above.
      10-18-2012, 10:41 AM   #15
philtrick123
Drives: TBA
Told you. Above.
Sorry to doubt you- sometimes I just need to prove it to myself
      10-19-2012, 01:06 AM   #16
slyfox
slyfox's Avatar
Drives: X3-20d (2013)
I have heard from a freind of mine of the following problem.
Husband and wife driving in the car. The husband (driver) who has the key in his pocket, stops and gets out at a car showroom (let's say). the wife (not interested) says that she is going to the shopping center a little further down the road. She then gets in the car and drives off.
Problem is she does not have the KEY!! She does realise this until she needs to lock or restart the car!!
Moral of the story is always give the driver the key..
It use to be so simple in the "old" days
slyfox is offline   Belgium
      10-19-2012, 01:38 AM   #17
sfax
sfax's Avatar
- I have one of those
However, we don't have this problem because we have memory seats and we would have switch profiles first which one would mean the wife would use her key to switch the seats before going shopping
Forum Jump
