XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Squeaky Drivers Seat.
      10-13-2012, 03:31 PM   #1
saggo
Drives: X3 30d M Sport
Unhappy Squeaky Drivers Seat.
My X3's developed an annoying squeak order the drivers seat, on bumpy roads it drives me mad! The source of the squeak seems to be under my right ar*e cheek in the seat cushion or frame. Has anyone had this happen to their car? Mines got electric memory facility.
I'm considering taking in to the dealers though don't hold out much hope of them sorting it...would a squirt with the WD40 fix it?
X3 30d MSport in AW Red Brown Trim
Media Pack Vis Pack Cold Weather Pack Electric Seats Towbar Reverse Cam Internet Bluetooth with Telematics DAB Business Loudspeaker Mobile Apps
saggo is offline   United Kingdom
      10-14-2012, 02:58 PM   #2
philtrick123
Drives: TBA
Saggo- you've had a lot of grief for a new car.
Take this issue straight to the dealer. A new car shouldn't have issues like this. Pester the dealer until its fixed.
philtrick123 is offline   Reply With Quote
      10-14-2012, 03:08 PM   #3
saggo
Will do, I'm good at pestering...my problem is that I'm self employed and can't afford to spend days on end going back and forth to the dealers.
      10-14-2012, 03:18 PM   #4
gareth3685
Drives: 2.0D
I got this in exactly the same place although its more of a creak than a squeak.
I've booked it in to get this looked at.
gareth3685 is offline   Reply With Quote
      10-14-2012, 03:32 PM   #5
saggo
'Creak' is probably a more accurate description.
I'd appreciate it if you could let me know how you get on.
      10-14-2012, 06:00 PM   #6
philtrick123
Drives: TBA
Might be Electric Seat related, by budget didn't stretch that far. Manual adjustment for me.
+ get the dealer to give you a loan car during the investigation
      10-15-2012, 03:27 AM   #7
gareth3685
Drives: 2.0D
Don't think it is. I dont have either electric or sports seats like the original poster would have (being an Msport).
      10-15-2012, 03:45 AM   #8
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
I have electric sports seats and no creaks or squeaks under either arse cheek. Would get them to fix it if I were you
      10-15-2012, 09:25 AM   #9
jsbos
Drives: 2012 BMW X3 28i
Is your seat all the way down? If so, try adjusting the seat up a little to stop the creak sound.
jsbos is offline   United_States
      10-15-2012, 10:16 AM   #10
gareth3685
Drives: 2.0D
That's worth a try as a work-around but however it should not creak regardless of the height setting.
      10-16-2012, 12:23 AM   #11
cohwang
Drives: 2011 X3 28i
I had the same noise on the front passenger seat and the dealer replaced the seat frame for me.
cohwang is offline   Reply With Quote
      10-16-2012, 02:48 AM   #12
Chris55
Chris55's Avatar
Drives: 2013 X3 35d M Sport
I've had this problem with my 2 previous BMWs. Sometimes if the seat has not been moved/operated for awhile some of the lubricant might wear thin and then you have the squeaking and it's usually a hard thing to pinpoint.
What I do now (and it has always worked) is just move ALL the different parts of the seats back and forth a few times (recline, forward/backward, hight etc...) It might just get the lubricant moving to where it's needed.
Let us know.
Chris55 is offline   Switzerland
      10-16-2012, 03:03 PM   #13
saggo
I've tried the seat in various positions and it still creaks and groans, seems worse when the car interior is cold. Booked in for new windscreen and seat investigation next week - watch this space!
Can't believe it's taking over a week to get a windscreen in stock!
      10-16-2012, 03:22 PM   #14
sfax
sfax's Avatar
If this is a common problem, this theory might explain why I've not experienced it as I regularly switch with the wife and we have electric memory seats that move a lot each time we unlock with the other key.
      10-22-2012, 12:54 PM   #15
gareth3685
Drives: 2.0D
Mine went in to the dealership today to have this looked at (along with the rustling from the dashboard). Rather predictably the sound wasn't as apparent as it normally is when I took the technician out to replicate it but nevertheless it did creak enough times for him to work out where to look. Apparently they've fixed it butI haven't managed to collect it today. I'll update once I have.
Fingers crossed.
      10-22-2012, 01:39 PM   #16
E92LNGCGY
Drives: E92/F25
I had the same issue with my 2012. Took it to the dealer twice and they said they lubricated some components only resolved the problem temporarily. I was told by the service advisor that it maybe the plastic inside the seat rubbing and that give it sometime and it will go away. So far no more squeak. Hope it stays that way.
Looking to buy or sell property in Alberta? Drop me a line to see what I can do for you.
Urban Realty - Leslie Ng - 403-807-6248 or leslieng168@gmail.com
E92LNGCGY is offline   Reply With Quote
      10-23-2012, 01:32 PM   #17
gareth3685
Drives: 2.0D
OK car is back, seat is creaking less. I noticed it made a noise a couple of times on the way home but it was no way near as bad as before and not bad enough for me to take it back. Not much information from the dealer other than it was part of the seat trim that was causing the issue.
OK update, noise is back. Looks like I'll have to take it back to the dealership.
Really fed up with this car.
      10-26-2012, 03:55 PM   #18
beto_L.A.
beto_L.A.'s Avatar
Drives: 2012 F25 X3 28i Jet black
I have the same problem...Drivers seat makes noise took it to the Dealer and they lubricated the frame...it worked for a while...I did notice that during the hot weather here in So.Cal. The noise went away...now that we are in cold weather the noise came back..so I'll be taking my X3 for service of the brakes and the seat...
Current: 2012 F25 X328i, JET BLACK,Chestnut Brown,Sport Activity Package, Xenon Lights, 25% tint front Returned: '09 E90 328I sedan, space gray, saddle brown leather,Dark Burl Walnut wood trim, sport package, A/T, xenon lights, Ipod/USB adapter, 35% tint all around.
beto_L.A. is offline   United_States
      11-05-2012, 01:37 PM   #19
gareth3685
Drives: 2.0D
Update, got the car back today (2nd visit, has been there since Thursday) and they seem to have cured the seat squeak. They said they needed to replace a part (hence the extended visit) and it seems to have worked. Fingers crossed.
      11-06-2012, 03:06 PM   #20
MattUK
Captain Unsensible
Drives: 2011 X3 3.0D MSport
I had this new option added to my X3 today.. and god its annoying... fix the russel and its replaced with a creak
MattUK is offline   United Kingdom
      11-06-2012, 04:01 PM   #21
dchao
Drives: BMW X1 xDrive20d
Do you know what was the part they replaced?
dchao is offline   Reply With Quote
      11-06-2012, 04:13 PM   #22
gareth3685
Drives: 2.0D
No afraid not, wasn't given any paperwork. Did ask but the service guy seemed a bit vague but they did replace something.
Forum Jump
