XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » My recent canadian service
      10-11-2012, 08:20 PM   #1
bazan
Drives: 2013 X3 28i
Question My recent canadian service
Hi,
I recently took my 2013 28i X3 into service due to a low coolant light warning (14k km). So I thought I would ask the advisor to do the following:
- Update ASS so to store "last use" setting --> Advisor respond saying specifically BMW has instructed them not to do update for X3. so negative nothing can be done
- I have seen warning "Chassis Stabalization Malfunction" twice, so I asked the advisor to see if they can pull history and see whats wrong ---> advisor said they ran a check and everything is ok (the ran a maintenance scope/reset CBS... that's what it said on invoice)
- Asked if the sport mode can be program to last use ---> respond no.... this is probably the only one I agree
As side question to the forum here:
- I believe there is no close trunk from key fob is this right?
- The parktronics seems to sometimes work and sometimes don't. Sometimes it will not show distance after I parked . Is this because it only activates itself at low speed.... and yes I sometimes park fast with head in .
- Also does the headlight suppose to swivel.... never seen that happen... think my C300 is more obvious
Thanks in advance ... I am located in Toronto.
bazan is offline
      10-11-2012, 08:55 PM   #2
gareth12468
Drives: 2011 X3 xDrive 28i
2011 BMW X3  [0.00]
Next time if you see "Chassis Stabalization Malfunction" error, you should drive your xar directly to the dealership and show them the error...... I have those errors couple of times and they finally fixed that after I drove to them directly without shutting down the car.....
gareth12468 is offline   Canada
      10-11-2012, 09:53 PM   #3
dandanio
The one that drives!
dandanio's Avatar
Drives: 11 x3 35i/09 Jetta TDI
Just a matter of coding. Mine works for opening and closing.
That is weird, mine always works. How fast to you back up? 20 mph?
Swivels. Side to side (when turning your steering wheel) and up and down (on startup). But only on Xenons.
dandanio is offline   United_States
      10-12-2012, 04:51 AM   #4
slyfox
slyfox's Avatar
Drives: X3-20d (2013)
I believe that the Up/Down is a standard function on the Xenos.
BUT
The Swivel (side to side) with the steering wheel is normally as an option. (maybe included in a pack or something)
slyfox is offline   Belgium
      10-12-2012, 06:44 AM   #5
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
The Canadian x3 only get auto leveling not side to side like other markets. I'm looking into a coding solution to this 'made for Canada' oversight.
BUT
lbjgh is offline   Canada
      10-13-2012, 02:11 PM   #6
bazan
Drives: 2013 X3 28i
SIB 12 15 12 This is the bulletin for autostart/stop so this is not allowed to applied to the X3? how about the throttle lag one (that applies only to pre2013 model only?)
On a side note , I wish they are more explicit in terms of what's incl in the canadian version... I thought swivel is always standard with the package...
bazan is offline   Reply With Quote
      10-15-2012, 11:39 AM   #7
bichoo
Drives: BMW X3 28i
its only standard on the 35i in canada.
i agree, its not obvious
bichoo is offline   Reply With Quote
      10-15-2012, 11:50 AM   #8
lbjgh
lbjgh's Avatar
minor correction. In the Canadian market the 35i does come with auto levelling but not swivelling headlights.
Forum Jump
