XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 General Forum 35i LED turnsignals and brakelights retrofit
      10-08-2012, 12:03 PM   #1
droftrah
Drives: '18 G01 X3 M40i
The fact that BMW put xenon hid headlights, led headlight rings, and led taillights on my x3 is nice and as expected. But what were they thinking putting standard incandescent turnsignals and brake lights!!! I know there are led bulbs out there that fit in the standard slots and I want to get them. Anyone know what bulbs will work on the F25??
      10-08-2012, 12:37 PM   #2
StepfordBMW
Captain Amazing
Drives: 2013 X3 28i
and standard brake lights! GRRR
2013 X3 28i DSB/Mojave/FW
SA, CONV, CW I, PREM, PREM SND, TECH, HUD
      10-08-2012, 01:51 PM   #3
singh073
Drives: 2015 M4 Coupe
I'm interested to know as well. LED Madness...
      10-09-2012, 07:16 AM   #4
vanheiser
Indonesia
Drives: F30 330i LCI
I changed my signal light to a Canbus Error free 7507. It work fine and I think it look great and not to mention it was really easy to change the bulb. Takes about 3mins to get them both changed.
Here's the link of the bulb I got: Link
      10-09-2012, 07:23 AM   #5
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
To be honest, I don't get the fascination with LED turn signals. They're secondary to brake signals. The performance advantage is more relevant with LED brake lamps I think.
2017 F80 M3 STOCK
F25 X3 N20:
2013 F25 X3 x28 N20 tunerwerks
      10-09-2012, 07:40 AM   #6
StepfordBMW
Captain Amazing
Drives: 2013 X3 28i
You're right- turn signals is just more of an aesthetic. But going all LED, keeps a great homogenous look. Take a look at the rear of a 5, 6 or 7.
      10-09-2012, 07:46 AM   #7
StepfordBMW
Captain Amazing
Drives: 2013 X3 28i
      10-09-2012, 08:24 AM   #8
chx437
Drives: BMW X3(F25)
Here are some hints on the LED turning signal lights and brake lights for the X3(F25). My experience is from Europe but I suppose the rear lights are quite similar in US model. The product example links below direct to a good German web store specialized for LED bulbs but the same LED products are hopefully available from other sources as well.
Rear turning signal:
So the rear turning signal (blinker) bulb is originally clear PY21W (21W normal incandescent lamp) with BA15S base. There is a rather strong amber filter (diffusor) in front of the bulb, so the replacing LED bulb has to be quite effcient. My alternative for the rear blinker bulb is here: amber colored 9W LED for BA15S base with 5 watt CREE on the tip and 4 times 1 W LEDs on the sides:
http://www.benzinfabrik.de/de/led-bl...s-p21w-orange/
Front turning signal:
In front at least in the European model the turning signal bulb is originally amber PY21W (also 21W incandescent lamp) with BAU15S base. Note that the base for the clear and the amber PY21W bulbs are different: for the amber bulb the base has asymmetric positions for the small nodules on the sides. My alternative here is amber colored 9W LED for BAU15S base with 5 watt CREE on the tip and 4 times 1 W LEDs on the sides:
http://www.benzinfabrik.de/de/led-bl...-py21w-orange/
Parallel resistors needed for LED blinker bulbs:
With the blinker bulbs my X3(F25) has very strict in-built control: the bulb has to pass through at last 1.5 – 1.6 A current to be validated Ok by the car control computer. If the current is less, then an error message is shown on the display (and the blinker on/off cycle time gets faster). So with the LED blinker bulbs, which use less current, I have to add parallel power resistors (10 ohms/25W, one for each LED bulb) to keep the control computer happy. I couldn’t place these relatively big resistors into the rear light housing but instead I placed them on the sides in the trunk. I first have to dig out the cabling in the trunk sides going towards the rear light housing and especially toward the blinker bulbs and then connecting the resistors parallel to those wires. I fastened the resistors into small aluminum plates (for cooling) and then I installed the plates (with the resistor) into the trunk sides (under the side covers), where there actually were plenty of room for these small additions.
In front the turning signal bulb is installed on a small “disc” which can be removed as one peace with the bulb from the back of the headlight housing (inside the motor room). There is no place either in the headlight housing for the needed parallel resistors so I had to get wires through those small plastic discs and then I installed the power resistors (fixed into cooling plates) on the sides of the engine room.
Brake light:
The original brake light bulb is again a clear P21W with BA15S base. My LED alternative for that is a red LED bulb with 4 LEDs (1 W each):
http://www.benzinfabrik.de/de/led-fu...a15s-p21w-rot/
Brake lights bulbs are easier to install: at least in my car the control system was gentler for the brake bulbs and no additional resistors were needed when using the LEDs
One additional note:
The above referred LEDs are not accepted in the in the official vehicle inspections (at least not in most European countries) so one has to take this into consideration when planning such modifications.
      11-21-2012, 07:07 PM   #9
droftrah
Will these work in the tails and rear signals. I have the amber version of these in the front and they work great, only slightly dimmer than stock at some angles. I was able to fit the amber PY21W fronts in the P21W rear and it is noticeably dimmer. If I get these in red will it be brighter or not?
http://www.ebay.com/itm/1-pair-8W-Ca...2880ba&vxp=mtr
      11-21-2012, 08:54 PM   #10
ReturnZero
Drives: 2013 X3 35i M-Sport
Check out this thread, we all did the same thing:
http://x3.xbimmers.com/forums/showthread.php?t=764176
Tags
led, leds, lights, turn signal
