XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Auto gearbox jerking(shaking) on low rpm
      09-29-2012, 05:58 AM   #1
macphin
Drives: 325i
Is anyone had same issue, when you start driving on 1200-1500 rpm car or transmission shakes, in the moment when I start acceleration, but very very slowly.
macphin is offline
      09-29-2012, 06:55 AM   #2
Nahoa
If by shake, you might mean what I'd describe as a lurch (speeding-slowing), then yes. I've experienced this since the "lag" software update.
Nahoa is offline   United_States
      09-29-2012, 07:24 AM   #3
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
I think I know what you are talking about because I did notice that a couple times when my car was fairly new, i.e. first month of ownership.
There has been no further evidence of it so I chalked it up to the adaptive transmission learning how I drive.
lbjgh is online now   Canada
      09-29-2012, 09:35 AM   #4
RichardBR
Drives: 2012 BMW X3 30D Msport DSB
I got it too. I have the 30d engine and it's very noticeable both in comfort and sport. My car was built February 2012. I first noticed this after 3500km. Now after 17000km it's worse than ever.
Had the dealer look at it a few weeks ago but they said they wouldn't upgrade to the latest software because BMW found a bug in it. The did not know anything more about when a fix is due.
RichardBR is offline   Norway
      09-29-2012, 11:07 PM   #5
DonC
Drives: 2013 X3 3.5i M sport, etc
No issues in my 3.5i
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars
2005 S2000
2007 TL-S
DonC is offline   United_States
      09-30-2012, 10:44 AM   #6
matteowade
Drives: 2013 BMW X3 28i
I have experienced a jerking or pulsating on acceleration in that RPM range on my 2013 28i.
I asked the dealer about it and they said they couldn't reproduce it and it was likely due to the gas I was using. Of course.
I don't think its the transmission though. Because I've gone into manual and experienced it too.
Interestingly, I haven't experienced it since the weather here has cooled off. Seems like I will have the issue occasionally if the temp outside is above 85F or so.
matteowade is offline   United_States
      10-01-2012, 01:30 PM   #7
sivakumarbalu
sivakumarbalu's Avatar
Drives: 2012 F25 N52T
I mainly use public transit for work, so I take out the car once in 2 or 3 days.
Jerking (sometimes you feel like engine is going to stall like popping a clutch in manual transmission) happens when I start driving the car immediately after ignition. If I leave the engine idling for couple of minutes and start driving then I don't notice the shakes.
I assumed that car was parked for more than 2 days so the lurching happens...as someone mentioned it's been happening since s/w updated for throttle delay. I only use 93 octane.
sivakumarbalu is offline   United_States
      10-04-2012, 08:59 AM   #8
macluhak
Drives: X3 30d
I've had this for some time now.
However I was lucky enough to be able to reproduce with a service manager driving the car.
They've tried to "fix" the car three times now. Not counting the first occasion when they brushed me off, blaming the DPF regeneration. The thing is I used to drive an X1 2.0d before the X3, never had any jerking or shuddering (manual box). Except for when the wife refused to use the stick...
Anyhow, just received a phonecall from my service manager. I'm scheduled for a complete software update on 22 October. This software was promised end of August. According to my service manager, this software will for sure solve my problems.
I'll keep you posted on the progress.
macluhak is offline   Germany
      10-05-2012, 08:20 AM   #9
macphin
Drives: 325i
Thanks, I guess it's a software related issue. Will be waiting for new software, and if somebody could write in this thread when the new software will be released, so I can check with my dealer.
macphin is offline   Reply With Quote
      10-15-2012, 02:49 PM   #10
kolien
Drives: BMW X3 3.0d (F25)
I have a 3.0D x3, 2012. I have recently had my engine software updated. It was changed on September 18 after experiencing jerkiness at low rpms. Much improved afterwards but still some very subtle jerkiness from time to time and not every day. Dealer suspected EGR problems and changed valve parameters in the EGR in addition to changing a air mass sensor.
What sw version do you refer to?
kolien is offline   Norway
      10-15-2012, 04:15 PM   #11
RichardBR
Don't know the SW version. They showed me an internal e-mail about it. Will certainly call them and ask if there are new software.
211hk or 258?
      10-16-2012, 08:38 AM   #12
kolien
211hk or 258?
211HK, production date 2011-12-01
I will see if I can get the SW version also.
      10-16-2012, 09:39 AM   #13
gareth12468
Drives: 2011 X3 xDrive 28i
2011 BMW X3  [0.00]
Mine have the same thing happen before the engine warmed up every day after the software update.
gareth12468 is offline   Canada
      10-23-2012, 04:16 AM   #14
dathrilla
Drives: X3 20d on order
I have this issue too, 30d '12.
dathrilla is offline   Reply With Quote
      10-23-2012, 04:29 AM   #15
philtrick123
Drives: TBA
Can someone describe this issue in more detail. I'm interested to see if I can reproduce the problem on my 30d se.
philtrick123 is offline   Reply With Quote
      10-30-2012, 02:37 AM   #16
RichardBR
Jerking is gone after changing from summer to winter setup. I swithed to winter setup 8 days ago, and I can almost say the issue is gone. It's very strange. I have the 369M staggered 19" wheels on my summer setup, and have standard 17" 305 wheels on winter.
If the problem is the staggered 369M's, why would BMW deliver these?
Could it be the tyres? Have the factory default PZero's on the 369M's and have Nokian Hakkapelitta on the 305's.
Or is it just a coincidense?
      10-30-2012, 06:33 AM   #17
HighlandPete
Drives: BMW F11 535i Touring
To me, that appears to indicate a slight drivetrain 'bunching' issue on the staggered tyres.
Slight variations in tyre pressures and tread depth could be involved, and a staggered setup with a small RC difference, could just push the limits to make the drivetrain very sensitive.
Are others with the issues on staggered wheel setups?
HighlandPete
HighlandPete is offline   Reply With Quote
      10-30-2012, 05:21 PM   #18
lbjgh
lbjgh's Avatar
Interesting development. My car is a square setup (same width front/rear) so maybe bmw did find an issue with the staggered setup.
      10-31-2012, 08:44 AM   #19
RichardBR
It was just a coincidense about the tires. Today, the jerking was back in full. Probably just a few days break because of the cold weather...
Which makes me think that it is outside temperature related?
On cold days (below 0C) = No jerking
Above 0C = Jerking
Any thoughts?
Richard
      11-02-2012, 03:48 AM   #20
macluhak
Drives: X3 30d
Jerking temp related
On my 30d the judder seems to be related to engine temp. I find that judder may occur when the engine temp needle started registering increased temp and up to about 75-80 degrees C.
And yes, I posted earlier on possible solution with software update. Unfortunately the software did not solve my problem completely. The judder is still there, just less violent, and for sure less frequent.
I'll be talking to my service rep. Don't expect much from them though.
Forum Jump
