XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Lurching Fixed- Wasn't Software Update
      09-20-2012, 11:18 AM   #1
geordie
Drives: 2011 X3 35i
So despite multiple software flashes at BMW service (Including the 'lurching update') I still had brutal lurching on my '11 X3 35i.
I was about to drive it into the river. Then my wife decided to try putting in 93 octane Chevron gas instead of just 91. Wouldn't you know it, the lurching is 100% GONE.
So, as usual the answer is just fixed by spending more money
Thought this might be helpful if some of you were still experiencing lurching after the software updates.
Power is also WAY higher.
geordie is offline
      09-20-2012, 11:24 AM   #2
Mingstar88
Drives: BMW X3 35i Carbon Black MSport
which 91? we are using 91 vpower shell, am tempting to try 94 petro for winter
Mingstar88 is offline   Canada
      09-20-2012, 11:31 AM   #3
nyalpine90
nyalpine90's Avatar
Drives: '12 X3 28i AW
2012 X3  [4.50]
Send a message via MSN to nyalpine90
doesnt it say premium gas unleaded on gas door?
nyalpine90 is offline   Colombia
      09-20-2012, 12:45 PM   #4
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
nop, it says MINIMUM 89 octane.
lbjgh is offline   Canada
      09-20-2012, 01:48 PM   #5
Mingstar88
on my 35i it says 91
on 28i loaner i drove it was 89
      09-20-2012, 02:05 PM   #6
geordie
Drives: 2011 X3 35i
In Canada, the 35i says use 91 octane (which is considered "premium" gas here). 87 is considered "regular".
So 93 octane that I'm saying helps with the lurching would be above the spec of 91 BMW says the turbo needs.
geordie is offline   Reply With Quote
      09-20-2012, 02:09 PM   #7
lbjgh
lbjgh's Avatar
Maybe my Canadian car is unique.
      09-20-2012, 02:41 PM   #8
somf
Drives: Q5 retired ... 2013 3.5 MSport
My Canadian MY2013 35i M-Sport delivered in Sept 2012 also says 89 octane just like lbjgh
somf is offline   Canada
      09-20-2012, 03:02 PM   #9
E92LNGCGY
Drives: E92/F25
I tried Husky 94 octane and didn't do a thing. What other gas stations offer 94?
Looking to buy or sell property in Alberta? Drop me a line to see what I can do for you.
Urban Realty - Leslie Ng - 403-807-6248 or leslieng168@gmail.com
E92LNGCGY is offline   Reply With Quote
      09-20-2012, 03:20 PM   #10
epiphone3
Drives: 2013 BMW X3 35i
PetroCanada now sell 94 octane in Calgary at several locations. However, any PetroCanada that carries the 94 octane now has up-to 10% ethanol in all grades (like Husky). Higher Octane number but the fuel has lower energy content due to the ethanol.
epiphone3 is offline   Reply With Quote
      09-20-2012, 03:24 PM   #11
E92LNGCGY
Drives: E92/F25
No wonder when I tried Husky 94 it didn't have the kick at higher RPM. I used to put 94 in the 325 and I can feel a difference.
      09-20-2012, 06:17 PM   #12
lbjgh
lbjgh's Avatar
Higher octane just means the fuel is less susceptible to predetonation.
Just like epiphone3 said some of the highest octane fuels contain ethanol to prevent predetonation.
I use the lowest grade fuel on my motorcycle. and aim for 91 octane for the car.
      09-20-2012, 06:17 PM   #13
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
Octane Booster Additive anyone?
Radioactive is offline   United_States
      09-20-2012, 06:52 PM   #14
twistediron
Drives: Bmw X3 35i M Sport
ridiculously expensive and barely effective. dyno tab is cheap, but they claim a 2 tab setup gives you 17 points (4 bucks) so 4 bucks a tank gives you 92.7 octane instead of 91. long way to go to match race gas
twistediron is offline   Canada
      09-20-2012, 07:33 PM   #15
vanheiser
Drives: X3 35i
Mine also show what lbjgh picture shows on my 2013 35i M-Sport. I kept filling in 91 from Esso Canada. But starting to wander if its possible to just use 89. Not really keen on trying though.
vanheiser is offline   Reply With Quote
      09-21-2012, 08:13 AM   #16
epiphone3
If you read the manual, BMW states in it that 89 AKI is the minimum that you can use and that you may here knocking from the engine (especially in high temperatures). They claim the knocking won't damage the engine but my perspective is that you probably didn't buy a premium vehicle with a highly tuned power plant to run it with a knocking engine.
My 2 cents is as follows: for the miniscule differnce in cost per tank of fuel between 89 and 91, why take on all the risk that comes with running the lower grade fuel. Fuel's cheap, pistons are expensive.
      09-21-2012, 08:25 AM   #17
nyalpine90
nyalpine90's Avatar
2012 X3  [4.50]
i always put premium gas BP or Sunoco 91 or 93
i think sunoco offers 93 bp offers 91 not sure though
      09-21-2012, 01:00 PM   #18
gareth12468
Drives: 2011 X3 xDrive 28i
2011 BMW X3  [0.00]
I've tried PetroCan 94 and all I can say it's not worth the money.....
gareth12468 is offline   Canada
      09-21-2012, 01:36 PM   #19
lbjgh
lbjgh's Avatar
Probably because you are pumping ethanol into your car which has less energy.
This is a good read: http://www.thestar.com/wheels/articl...rmance-engines
      09-27-2012, 12:09 PM   #20
geordie
Drives: 2011 X3 35i
My 35i 2011 Canadian version says 91 minimum:
      09-27-2012, 02:02 PM   #21
lbjgh
lbjgh's Avatar
I wonder if vehicles on the left coast are labelled differently due to the possibly that the car will be operated at higher altitudes??
Anyway, below is the info from the manual.
      09-28-2012, 12:27 AM   #22
paul386
Drives: 2011 X3 35i Jet Black
Increased power is just a figment of your imagination.
So is the lurching for that matter. If the lurching stopped its because you are driving more aggressively.
paul386 is offline   Reply With Quote
Forum Jump
