XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » changing xenon. bulb
      08-01-2012, 01:08 AM   #1
mooney058
Drives: F25 (Sept 2012) 525i (gone)
how difficult it is to change a xenon bulb in F25? Have not got my car yet, but after year or so I am thinking of changing the bulbs myself. is it an easy DIY or does it require dismounting some of the equipment to have access to it?
mooney058 is offline
      08-01-2012, 02:07 AM   #2
ReturnZero
Drives: 2013 X3 35i M-Sport
Why would you want to change the bulb?
ReturnZero is offline   United_States
      08-01-2012, 02:13 AM   #3
mooney058
well, was thinking of a OSRAM XENARC SILVERSTAR to replace the standard bulbs and keep standard as a replacement if Xenarc fails. I am ussed to have some basic items in my car and replace it myself if need be (for example when I am traveling to skiing etc). I would then buy some good replacements bulbs only if you could do it yourself.
mooney058 is offline   Reply With Quote
      08-01-2012, 02:14 AM   #4
ReturnZero
Honestly the stock bulbs are very good and you won't be able to purchase anything better aftermarket. I would look for other goodies to work on.
      08-01-2012, 02:19 AM   #5
mooney058
like what?
      08-01-2012, 02:22 AM   #6
ReturnZero
I don't know, what are you interested in? You could build a cable and do some customization though coding, maybe look into LED bulbs to replace the normal bulbs, golf tee mod for the exhaust (depending on your model), other accessories you could get for it.
      08-01-2012, 04:17 AM   #7
mooney058
coding cable and coding would be most interesting, but I am affraid to screw things-up as I am not that IT capable. I would rather prefer to pay to someone who has already done it and knows how it all works (anyone from Belgium/Holand or western part of Germany did this?). Interior LED lights or outside styling lighting are not that relevant to me. But if I could further improve the performance of already good xenon lightning - why not, and I would keep standard bulbs for replacement purposes.
      08-01-2012, 04:17 AM   #8
Teemo Panda
* A BLUE PANDIAN SMURF * ♠
Teemo Panda's Avatar
Drives: BMW X3, X5
2013 BMW X3  [5.00]
why not you let BMW change it for you, since it is covered under warranty?
Im Kinda against DIYing the bulb because, when you get your fingerprints on the bulb, it would shorten its life. Plus buying your own bulb out of pocket.
I had experience changing my headlight assembly numerous non xenon with cheep aftermarket headlight with halo's, it is definitely a dangerous job that we risk getting electrocuted :X
anyways Good Luck thu~
Teemo Panda is offline   United_States
      08-01-2012, 08:34 AM   #9
nonagon
nonagon's Avatar
Drives: 2012 X3 M Sport Carbon Black
The stock xenons are pretty good IMO...wheels, tires upgrading, or a tune would probably be more useful mods and better ways to spend your money.
2012 X3 xDrive 35i | Carbon Black/Oyster | M Sport | Premium | Tech | Cold Weather I & II | DHP | Premium Audio | BMW Apps
nonagon is offline   United_States
      08-01-2012, 02:00 PM   #10
ReturnZero
I see, I guess what I was getting at was even if you replace the bulbs with aftermarket ones you won't really get any better performance out of them. OEM bulbs are some of the brightest available.
      08-01-2012, 02:47 PM   #11
Beyu
Beyu's Avatar
Drives: 135i
I'm not sure if the xenons follow the same method as the halogens for replacement but if you're feeling adventurous and are confident enough then give it a try.
If you're serious about changing out your lights why not give the fog lamps a try first and swap out those ugly yellow ones. The instructions are on the following page of the headlights pic I have up. (pg. 222 paper manual, pg. 256 digital)
Beyu is offline   United_States
      08-01-2012, 09:28 PM   #12
welkerbrads
Drives: 08 alpine white 328i, 2011 X3
The lamps are easy to change. I changed my lamps to the silver star. They a some what brighter. You get a whiter light. The oem lamps have a yellow cast. They are very easy to change. There is a cover on the back of the lamp assembly. Just turn it and it come off. The lamps are held in by a spring. Just pull on the bulb assembly and it will come out. Unplug the lamp, plug in the new one and push the bulb into the lamp assembly. Done
welkerbrads is offline   Reply With Quote
      08-02-2012, 12:45 AM   #13
mooney058
thanks, will give it a try when my car finaly arrives in a month time
      08-02-2012, 07:47 AM   #14
n55x3
Drives: n55 x3
Make sure you guys are talking about the same thing. Halogen bulbs are typically all the same size so a swap is relatively easy. On the xenon front, I've seen different length bulbs so that is something to be aware of. Clearance may be an issue when looking to replace your HID (xenon) bulb in the projector housing. If the HID bulbs are of different size that can have an impact on how the projector focuses the light. I'd certainly measure the OEM xenon length before ordering any aftermarket HID bulbs.
And just for the fun of it, here is a shot of a halogen next to a HID bulb:
http://x3.xbimmers.com/forums/showpo...97&postcount=7
n55x3 is offline   Reply With Quote
      08-02-2012, 09:31 AM   #15
mooney058
yep, I know there are different types/fittings of xenon bulbs, I would only change if correct type is available - would never put an item into my car that was not intended/approved by the manufacturer. I have changed many halogen bulbs in my life, but have heard that on some cars access to xenon bulbs is not so easy (well my hands/palms are of an average size). On the other hand, most of motorways/highways are lit-up during the night in Belgium, I only noticed the need for more light in my ex E60 when driving late/early in Alps (but that is again 2-3 times a year).
      08-02-2012, 01:25 PM   #16
MattUK
Captain Unsensible
Drives: 2011 X3 3.0D MSport
My Xenons are far from yellow, and are in fact very bright white.. does the US have different lights?
MattUK is offline   United Kingdom
      08-02-2012, 02:02 PM   #17
n55x3
Drives: n55 x3
Traditionally BMW has gone with a color temp close 4300k which offers a mostly white light with a yellowish tint. Pure white is usually measured between 5000k and 6000k. ANything above 6000K starts getting blue and the higher the color temp the lower the actual light output is.
I've got aftermarket 5000k bulbs in my Legacy and when both the X3 and Legacy lights are on in the dark garage the X3 has a more yellowish tint to it while the 5000k bulbs are crystal white with the slightest tint of blue.
They both look good though.
      08-02-2012, 03:57 PM   #18
nonagon
nonagon's Avatar
The OEM xenons to me look white with a hint of blue. I read somewhere color temp is 5000K. I would not describe them as yellowish at all.
      08-02-2012, 09:03 PM   #19
welkerbrads
Sorry I miss read your forum. I do have halogen bulbs and not the xenon and they are easy to change.
      08-03-2012, 08:44 AM   #20
n55x3
Drives: n55 x3
I think color is pretty subjective as everyone views colors in slightly different tints and hues.
HIDs are becoming more and more popular and across all the manufacturers you'd be hard pressed to find an OEM HID that was above 4500k. Pretty much an industry standard. There's lots of good info out there, just google BMW OEM HID color. Some good comparisons in the various forums of OEM HIDs next to aftermarket 5000k HIDs. I also think it's really hard to tell the difference until you've got 2 cars, with HIDs warmed up, shining on a wall side by side. I'll see if I can snap a picture this weekend of them side by side. The BMWs alone look nice and white but the yellow really comes out when they are next to a 5000k bulb.
Regardless of color temps, the OEM xenons are top notch and provide adequate lighting, far better than that of conventional halogens.
HIDs will slowly diminish over the next few years in favor of adaptive LED setups. I've driven an A6 with LED lights and they were amazing. They really reach down the road to illuminate signs and such.
      08-03-2012, 05:52 PM   #21
SomeRandomer123
SomeRandomer123's Avatar
Drives: F30 328i Luxury - Sport Auto
As someone mentioned earlier, changing the Xenon bulbs is a dangerous job!
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT - Awesome! 28th May 2009 - 28th May 2012
Current: 2012 F30 328i Luxury 8AT - Loving it!
My 328i thread!http://www.f30post.com/forums/showthread.php?t=712673
SomeRandomer123 is offline   England
Forum Jump
