FORUMS
- 5
| XBimmers | BMW X3 Forum » Coding made Easy: A step by step procedure |
| 09-14-2012, 06:59 AM | #156 |
![]() Drives: 2011 535i M-Sport Join Date: Feb 2010
PM's sent.
![]() - 2011 535i M-Sport - AW/BLK/DW - /ZMP(w/ARS & AD)/ZPP/ZP2(w/ZPS & ZPT)/ZCV(w/SCAD)/6FL/6VC - 2006 530i - SG/BLK/DW - /ZPP/ZCW/NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
| 09-14-2012, 10:25 AM | #158 | |
| 09-14-2012, 10:34 AM | #160 | |
| 09-14-2012, 04:58 PM | #161 |
Has anyone in the UK managed to get the tire temp and pressure coding to work?
I have applied the change, but all I get is dashes.
F25 X3 xDrive 35d M Sport Alpine White, Black Nevada Leather, Speed limit info, TV, Prof. Nav & Speakers, HUD, M Sport steering wheel, Sport gearbox, BMW Apps, Internet, VDC, Comfort with Powered boot, Hi-speed synch, VSS, Top View, Electric tow-bar, Heated steering, Storage, DAB, Heated electric seats, Moonroof, Adaptive High beam assist Xenons, Servotronic, Performance control, etc. http://x3orevoque.co.uk
| 09-15-2012, 08:45 AM | #162 |
Please can i have the rapidshare link, just bought the enet cable from april1.
My email: fabio.lelli@gmail.com Thank you!!! |
| 09-15-2012, 08:54 AM | #163 | |
| 09-15-2012, 10:08 AM | #164 |
![]() Drives: 2013 X3 3.5i M sport, etc Join Date: Aug 2012
Just recieved my kit from April 1 and would like the rapidshare link also.
email is cosners@comcast.net
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars 2005 S2000 2007 TL-S |
| 09-15-2012, 02:52 PM | #165 |
Hi All,, I tried to program the Folding Mirror with FoB and Comfort Access, Both looks not working (waited 1hr) ? What I am looking to achieve is when I hit the mirror fold button before lock the car, it will auto unfold with open the door by Comfort Access or FOB. I did code the CAS and FRM entry and verified it show as "01". My Car is a Canada spec..
Any idea ? Thank You for help out ! |
| 09-15-2012, 03:33 PM | #166 | |
| 09-17-2012, 10:25 AM | #170 | |
I don't have the car with me right now so I can't test all the scenarios to make sure that is the way it works but I will try to check tonight. |
| 09-17-2012, 11:07 AM | #171 |
Hi Marathon,,, Thank for your reply...
My car was produced in July 2012 and with comfort access. I have successful coded Auto S/S to memorize the last setting... But for the Folding Mirror, it's not working.. I tried to keep pressing the Key Fob or Close button on the door handle for more than 10 Sec and nothing happen except lock the car... Only 1 thing, if I use the mechanical key to Lock the car and keep holding the lock position, all window close and mirror will fold to close position, and then if i use CA to unlock car with door handle, mirror will Auto-unfold. I reference to the 1st page cheat sheet for the coding : Close mirrors + windows + moon roof through key FOB CAS 3003 FH MASTER KOMFORTSCHLIESSUNG_FB aktiv / Werte=01 nicht_aktiv / Werte=00 FRM 3020 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN aktiv / Werte=01 nicht_aktiv / Werte=00 Close mirrors + windows + moon roof through Comfort Access CAS 3003 FH MASTER KOMFORTSCHLIESSUNG_PA aktiv / Werte=01 nicht_aktiv / Werte=00 FRM 3020 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN aktiv / Werte=01 nicht_aktiv / Werte=00 |
| 09-17-2012, 10:20 PM | #172 |
Hi All,, It's working !! I've searched around and found some tips from a F10 forum.. Somehow for Canadian cars, the default for Folding mirror FB and PA is "01"... so I just change both to "00" and it works... now if i hold the lock button on Key Fob or lock button on car handle via comfort access... the mirror will fold close and window will all roll up.
| 09-17-2012, 10:24 PM | #173 | |
Thanks for sharing the info... a couple more days and my cable should be here from April1.
| 09-18-2012, 03:42 PM | #174 |
Hi, I have a major need to change the max height of the electic tailgait to be between the current 4 and 5 setting. (or to put it another way, 4 is too low for general use and 5 is too high for the garage). Is that codeable ?
Max
X3 xDrive20d M Sport, Space Grey, Black Nevada, Auto, 18" 368M, Xenons, Servotronic, Bootlid powered, Sun glass, Mirrors folding, Extd Storage, Media Pro, Mobile Apps, DAB, Business Sound, BMW Service Inc.
| 09-19-2012, 06:00 AM | #175 |
Hello, I have some coding issues with my X3.
When I reverse down the ramp with my boat trailer, and opens the door, the automatic gear is set to parking position. It would be nice if it could remain in reverse position, even if the door is opened. The annoying disclaimer in the back camera would be nice to get rid of. Would like to see which gear that is used at the moment, not just the D or SD. Is it possible to activate ECO Pro? I have the Dynamic Damper Control option 223 Is it possible to activate DAB+ if you have BMW Navigation professional? Or is it a hardware issue? Can someone send the rapidshare links to PsdZData 47.4? I would really appreciate it. Thanks in advance Tommy |
| 09-19-2012, 07:49 AM | #176 | |||||
Thats a long list.
![]() Quote:
LEGAL_DISCLAIMER_TIME = kein_ld - Disables camera legal disclaimer shown on iDrive startup MACRO_CAM_LEGALDISCLAIMER = kein_ld - Disables camera legal disclaimer shown on PDC (Rear) and Sideview MACRO_NIVICAM_LDISCLAIMER = kein_ld - Disables camera legal disclaimer shown on Night Vision Quote:
Sportschalter = aktiv Sportschalter_alt = aktiv See my post here: http://www.bimmerfest.com/forums/sho...d.php?t=644032 Quote:
http://www.bimmerfest.com/forums/sho...d.php?t=642231 Quote:
At the Hardware Level, you need a CIC with Connection 9 and 10 as shown in the attached CIC picture: 9 = DAB antenna (L-Band) 10 = DAB antenna (III Band) And you need antenna connection(s) from there to the Shark Fin. PM Sent.
| Bookmarks |
