XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Coding made Easy: A step by step procedure
      08-09-2012, 08:32 PM   #89
BeeMdblU
BeeMdblU's Avatar
Drives: Audi A4, CLK55, F25 35M
Originally Posted by shawnsheridan View Post
Ahh...the Egg Yolk...I'm not sure on that one. Personally, I would leave them enabled, and just replace the bulbs with Solaris Electrum InvisiBulbs, ULTRABRIGHT edition, which are clear when off, and amber when illuminated:
http://www.bimmian.com/Solaris-Invis...om-Bimmian.com
Here they are for the F25:
http://www.bimmian.com/SOL/25
Solaris UltraBright Halogen Bulbs (Amber or Super White) $15 - $20 / pair
Solaris LED Bulbs (Without Resistors - Amber or 6000k White) $20 - $30 / pair
Solaris LED Bulbs (With Resistors - Amber or 6000k White) $30 - $40 / pair
that's already done, I just need the amber to be off with headlights on
BeeMdblU is offline   Reply With Quote
      08-09-2012, 08:35 PM   #90
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Ok. I thought they were only illuminated when the turn signal was on.
- 2011 535i M-Sport - AW/BLK/DW - /ZMP(w/ARS & AD)/ZPP/ZP2(w/ZPS & ZPT)/ZCV(w/SCAD)/6FL/6VC
- 2006 530i - SG/BLK/DW - /ZPP/ZCW/NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
shawnsheridan is offline   United_States
      08-10-2012, 07:00 AM   #91
Bigmanny35
Drives: Black 2011 35i
Any coders or cables in Pittsburgh? I need to get the auto door locks worked out.
Mike
Bigmanny35 is offline   Reply With Quote
      08-10-2012, 07:58 AM   #92
BMWs
Drives: 2012 X3 35i
Yep yep! Can PM me.
BMWs is offline   United_States
      08-10-2012, 08:04 AM   #93
Hornet_Rider
Drives: X3 35i 2011 M-Sport
So what are we coding exactly? Just the I-Drive interface?
Hornet_Rider is offline   Canada
      08-10-2012, 08:56 AM   #94
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Very interesting question.
BMW has organized the complete car into sections, features and add ons. Each of them is called a module. Physical interconnection between a module and the vehicle are pre-defined by BMW. To make the entire car system workable and to take care of future additions and deletions, a system of rules are defined and to add the flexibility to the operation, each module is provided by certain configurable parameters. What we are doing in coding is accessing these modules parameters and adjusting their values.
We have very limited information about the functioning of all the parameters but many have tried to study them by experimenting them and then the successful combination of parameters with their values for a function are listed in so called cheet sheets. Coders can look at the sheet and determine what function they want to achieve and can look at the changed values. Making these parametric changes to CIC logic is called coding.
      08-10-2012, 09:35 AM   #95
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
Very good explanation. Decipher the black box by feeding it a range of values and observing what happens. More like system testing really
      08-10-2012, 09:53 AM   #96
April1
Love All
April1's Avatar
Drives: X3 28i 2011
For a layman, yes it is like a system testing. But as we pick only relevant parameters to achieve a functionality, it can be perceived as component integration testing.
      08-10-2012, 10:10 AM   #97
sfax
sfax's Avatar
If only you could mock the dependencies and remove the need to practice on a real car...
      08-10-2012, 10:48 AM   #98
April1
Love All
April1's Avatar
Drives: X3 28i 2011
I wish we had the simulator.
      08-14-2012, 01:07 AM   #99
April1
Love All
April1's Avatar
Drives: X3 28i 2011
There are different sources of E-Sys and data files and many could not use automatic installer. To help them, I included a simple manual installation procedure.
Hope this would help.
      08-16-2012, 11:21 AM   #100
jaydaman93
Drives: 2011 bmw x3 28i
Guys does coding void the warranty, if so do i need to change back the settings before i bring it in for a service? Is there a way to just load all of the backed up settings at once?
jaydaman93 is offline   Reply With Quote
      08-17-2012, 07:37 AM   #101
April1
Love All
April1's Avatar
Drives: X3 28i 2011
It is a debatable question. You would lose the warranty if it can be proved that a change of setting is the cause of the degradation of a part. Example: change of settings to door openi
Gs, closing, tail gate closing, suppressing warnings, DVD in motion, displaying tyre pressures etc won't stress car parts beyond normal operations.
If you have saved your original cafd files, you can always go back to original settings. In such case, don't read the cafd file values from the car, use the original saved cafd files. There are other ways too but I prefer this over others as I know exactly what change I m reverting to and not leaving system to set the default values on its own.
      08-18-2012, 01:35 AM   #102
April1
Love All
April1's Avatar
Drives: X3 28i 2011
It is noticed that some members have downloaded psdz data files 2.46.6. For them to install the SW with data files, a new Setup_3.18_46.6.bat file has been added to the first post.
      08-18-2012, 08:56 AM   #103
Marathon Man
Drives: 2013 X3
When April1 says "It is noticed" he means that I had a problem doing it and he solved it for me and for everyone else, too. Much thanks to April1.
Marathon Man is offline   Reply With Quote
      08-18-2012, 11:22 AM   #104
April1
Love All
April1's Avatar
Drives: X3 28i 2011
We definitely love to resolve genuine problems but this case was a classic case. We were close but far from the solution for marathon man. It was Shawn who kept on motivating me even at his late night and that resulted into a work around for marathon man.
But never-the-less we would suggest members to keep using data files 2.46.3 until we get a new release and find that it is backward compatible too. It is found that data files 2.46.6 and 2.47.1 do not support all the modules of our cars. Either we have to wait for the new release and/ or understand the changes in depth. If I have understood the German numbering system correctly, series 47 may not be fully compatible with series 46 but there would be work arounds to use series 47, I might be wrong
      08-18-2012, 08:19 PM   #105
April1
Love All
April1's Avatar
Drives: X3 28i 2011
In case its desired to uninstall E-Sys with plugged data files, run "Unistall_ESYS with data.bat" file after removing the extension pdf. File is attached to the first post.
      08-19-2012, 10:08 AM   #106
X3vader
Drives: 2013 BMW X3
2013 BMW X3  [0.00]
April, would you by any chance know how to adjust the low beam, high beam, fog light brightness?? my car has halogens not xenons. Thx in advance!
X3vader is offline   United_States
      08-28-2012, 01:20 AM   #107
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Setup batch file for psdz data 47.4 uploaded.
      08-28-2012, 04:14 AM   #108
Randeyman
Drives: 2013 X3 28i
April1
I would LOVE to know HOW to place (copy/overwrite/etc) the original "saved" CAFD files (now on my laptop) back into the car, so that it would be like it originally came. I have not seen that information anywhere in these (or other) threads. Everyone says "make a backup copy of them and save them in a safe place" in case you need to return the car to original programmed specs. I certainly did that - I just don't know how to put them back into the car IF I need to.
Any help/advice/directions on that?
THANKS!
Randeyman is offline   Reply With Quote
      08-28-2012, 06:53 AM   #109
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Originally Posted by Randeyman View Post
April1
THANKS!
Steps are very similar to what you do during coding. When you right click on any cafd file and select Read Coding Data, it reads data from car. So in place of selecting read coding data, select New and point to the saved cafd file matching the exact same name in your saved folder and proceed with the regular steps of saving and activating FA and code FDL. In this process you will push the saved cafd data back to car.
This is very logical and easy to visualize. You need to use cafd files which were changed in your coding earlier, forget about others which were not touched at all.
There are other ways too but I prefer the above as it is very logical and we know exactly what we are doing.
      08-28-2012, 08:54 AM   #110
DasBavaria
Drives: X3 28i
Hey April1,
I should be getting my X3 in approx. 3 weeks now and I wanted to get in to coding a few of the variables in my car as well. Do you still have any of the ENET Cables? Or a reputable source that I may be able to buy them off of?
Thanks.
DasBavaria is offline   Canada
Forum Jump
