XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Coding made Easy: A step by step procedure
      07-19-2012, 04:56 PM   #67
jdg857
jdg857's Avatar
Drives: 2011 X3 XDrive 28i
Originally Posted by April1 View Post
MSWINSCK assembly is a 32 bit dll and will not run on 64 bit system. I gave you a utility to get it registered on 32 bits system . Some have expressed that utility worked for them.
I was able to get it running by right clicking and selecting the compatibility mode so it would run under windows XP.
jdg857 is offline   Reply With Quote
      07-19-2012, 07:20 PM   #68
April1
Love All
April1's Avatar
Drives: X3 28i 2011
I will use your experience and update step by step instructions. Thx
      07-20-2012, 08:18 AM   #69
BMWs
Drives: 2012 X3 35i
So I finally got program install (manually) and did the basic codes on F25 cheat sheet plus removed seat belt chime. Didn't have time to explore more. Is this the thread we want to post coding wish lists and findings or should we start a new F25 coding thread for that and leave this for installation issues?
BMWs is offline   United_States
      07-20-2012, 10:47 AM   #70
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Many expressed to me that they could use the Setup utility and install the entire package in few minutes whereas you had problems in using the utility. The Setup utility assumes a folder structure and if it does not find in that order, it keeps on complaining. I would add the folder structure in the step by step instructions but would like to hear from you about the issues faced by you and what was actually wrong.
      07-20-2012, 10:56 AM   #71
BMWs
Drives: 2012 X3 35i
I'm having trouble running the setup bat file. This is the file structure April1 told me to use:
BMWInstall will have 2 sub folders and two files:
2_46.3 psdzdata
E-Sys_3.18.4
EDIABAS.INI
Setup_3.18.4.v2.bat
2_46.3 psdzdata folder will have 7 sub folders
E-Sys_3.18.4 will have two sub folders and a file:
EST
E-sys 3.18.4 (IS THIS THE .EXE FILE OR FOLDER?)
E-Sys 3.18.nfo
Also where does the EDIABAS folder go? Any help would be appreciated!
This was my folder structure. Kept giving me error on missing folder E-sys_3.18.4. I renamed and still same error. I then downloaded from different source the E-Sys files with correctly named folder and still same error. I tried on 2 different computers also. Not a big deal, installing manually is easy enough. Your cable worked great so thanks for that!
      07-20-2012, 11:26 AM   #72
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Thanks for the info.
Good that it warned you of a missing folder and didn't proceed rather than installing it incorrectly.
Intension was to use the just downloaded files without making any modifications but it seems different sources have different structures. I may have to add a pictorial check point before one starts installing the software as plain text does not give a realistic view. See above, though I said it contains two folders and a file, a question was asked if it is a folder or a file. It's my duty to make it more clearer for users and I will do it now. Thanks BMWs.
I wish we had a low cost storage server available to us, where we could have made a complete bundle for people to download and click and go.
      07-20-2012, 11:32 AM   #73
BMWs
Drives: 2012 X3 35i
I think the pictorial view would help. I was still not clear of the 2nd sub-folder that was suppose to be in the E-Sys_3.18.4 folder. Anything that will get more people to start coding would help the community find more cool options!
      07-20-2012, 03:32 PM   #74
BMWLVX
Drives: X3 2.0d
I found this one on another bmw forum and the one I initially followed to get up and running. Pictorial guide
BMWLVX is offline   Reply With Quote
      07-20-2012, 03:50 PM   #75
mgoblue62
Drives: 2012 X3 28i
I vote for a new thread! This one is great for installation and getting started issues. Hope we can have it made sticky (moderator?).
mgoblue62 is offline   United_States
      07-20-2012, 04:07 PM   #76
BMWs
Drives: 2012 X3 35i
Here is the new thread...
http://x3.xbimmers.com/forums/showthread.php?t=720975
      08-03-2012, 09:57 AM   #77
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Many members have shown interest in going in for simple coding and asked me if I can make an ENET cable for them. Yes if you do not want to make your own cable for any reason, I can definitely help you.
Some have asked if I can provide a complete bundle to them including SW, yes that is possible but this is an expensive proposition as I need to buy a 32GB USB flash drive to load the SW. Yes, if you do not want to struggle to get all pieces together, I can definitely help.
PM me separately, don't load this thread with your queries.
      08-03-2012, 12:42 PM   #78
mge.92
SPEED RACER
mge.92's Avatar
Drives: X3 28I M SPORT
Hey April1
I have not recieved pm just yet nor my car till august 13th but i would definately be interested in an enet cable and a flash drive with the complete bundle.
let me know
mge.92 is offline   United_States
      08-03-2012, 11:06 PM   #79
Tangsta
Drives: AW F25
Got my cable today and was able to code a few things:
-A.S.S. off by default
-Close tailgate by remote and drivers side button
-Close windows, sunroof, fold mirrors by remote
-Removed idrive disclaimer
Will definitely code more as other functions are discovered.
Thanks for the writeup and the cable April1!
Tangsta is offline   Reply With Quote
      08-04-2012, 05:57 AM   #80
Nahoa
Originally Posted by rgx3 View Post
I just re-read the owners manual and on the settings screen for climate there are three check boxes. The first on says "activate parking ventilation". This one is greyed out and won't let me select it. The other two are, "activate timer 1", and , "activate timer 2". These I can select which checks the box and allows me to enter a time. The owners manual states that you can either switch it on using the first selection, or use the timers. I can only use the timers. Anybody else have the situation that I have? I'd actaully like to try out the feature to see if the car stays any cooler while parked in the sun. Thanks in advance.
Options are to set the timer(s) when the car is on so they'll activate later, or after turning off the car, select the upper check box to activate it immediately.
Nahoa is offline   United_States
      08-05-2012, 07:55 PM   #81
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Based on feedback from users, i added few modifications:
Cheat sheet simplified to help beginners. It includes few but interesting features good enough for a beginner.
Also added bmwInstall folder organization in case one wants to use automatic installer " Setup_3.18.4.v2.bat" given in attachment. Hope this adds better visibility.
      08-06-2012, 10:35 PM   #82
BeeMdblU
BeeMdblU's Avatar
Drives: Audi A4, CLK55, F25 35M
anyone figured out the code to turn off side markers in headlamps?
BeeMdblU is offline   Reply With Quote
      08-07-2012, 08:29 AM   #83
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
On the X3, are those the 3 LED's or the single amber bulb?
- 2011 535i M-Sport - AW/BLK/DW - /ZMP(w/ARS & AD)/ZPP/ZP2(w/ZPS & ZPT)/ZCV(w/SCAD)/6FL/6VC
- 2006 530i - SG/BLK/DW - /ZPP/ZCW/NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
shawnsheridan is offline   United_States
      08-07-2012, 10:36 AM   #84
Tangsta
Drives: AW F25
Looks good!
Maybe include a copy of or link to the F10 cheat sheet..? I ended up using that one because I found the formatting easier to read than the previous version of the F25 cheat sheet.
      08-07-2012, 09:05 PM   #85
BeeMdblU
BeeMdblU's Avatar
it's the single amber bulb
      08-07-2012, 09:18 PM   #86
shawnsheridan
Ahh...the Egg Yolk...I'm not sure on that one. Personally, I would leave them enabled, and just replace the bulbs with Solaris Electrum InvisiBulbs, ULTRABRIGHT edition, which are clear when off, and amber when illuminated:
http://www.bimmian.com/Solaris-Invis...om-Bimmian.com
Here they are for the F25:
http://www.bimmian.com/SOL/25
Solaris UltraBright Halogen Bulbs (Amber or Super White) $15 - $20 / pair
Solaris LED Bulbs (Without Resistors - Amber or 6000k White) $20 - $30 / pair
Solaris LED Bulbs (With Resistors - Amber or 6000k White) $30 - $40 / pair
      08-09-2012, 03:59 PM   #87
perfchris
Drives: 2012 x3
Software Removed !!!
Too bad the software links were removed.
I guess our forum administrators want us to stop coding.
Can anyone PM me links to the software for our F25 ?
Many Thanks
perfchris is offline   Reply With Quote
      08-09-2012, 04:16 PM   #88
shawnsheridan
Many Thanks
The heat is on, and all forums are removing direct software links, not just x3bimmers.com, and all the Admins want is to avoid being taken down.
- BMWCCA #446923
- flick
Forum Jump
