XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 (F25) General Forum Coding made Easy: A step by step procedure
      04-16-2013, 05:18 PM   #595
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by leoleakey View Post
I can not find one the website 6VC only 6NH
So no Bluetooth music for me?
Unfortunately not. But you should still read your car SVT with E-Sys just to verify there is no CMB_MEDIA module. Since you do not have 609 NAV I don't expect you to have one, but it does not hurt to check.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      04-16-2013, 05:19 PM   #596
shawnsheridan
Originally Posted by sfiermon View Post
How do I get the software?
PM sent.
      04-18-2013, 12:18 PM   #597
robe033
Drives: X3 35d Sport 2014
Is it possible to update idrive software ??
      04-19-2013, 02:07 AM   #598
leoleakey
Drives: X3
Should I change the 6NH to 6NK first?
Or I should try to find CMB_MEDIA before change the vo?
Thanks
      04-19-2013, 07:25 AM   #599
shawnsheridan
Thanks
Before. You don't need to change anything.
      04-20-2013, 06:20 AM   #600
leoleakey
Drives: X3
this is what I have
      04-20-2013, 06:36 AM   #601
leoleakey
Drives: X3
Hi Shawn,
I changed HU_CIC / ACOUSTICAL_LOCK_CONFIRM to aktiv, and able to see the option in idrive.But can not choose it.
What should I try now?
Thanks
      04-20-2013, 07:20 AM   #602
shawnsheridan
this is what I have...
Ok. So now you know for sure that you have no CMB_MEDIA.
      04-20-2013, 07:22 AM   #603
shawnsheridan
Hi Shawn,
Thanks
Probably because your car does not have factory alarm system (DWA), so the lock / unlock chirps will not work.
      04-20-2013, 07:42 AM   #604
leoleakey
Drives: X3
Hi Shawn,
Thanks
thanks
      04-21-2013, 05:49 PM   #605
mge92
SPEED RACER
mge92's Avatar
Drives: Range Rover Velar D300
Any new coding options for the f25?
      04-21-2013, 08:26 PM   #606
leoleakey
Drives: X3
Do not know if this is the right place to ask
Album cover need to have CMB_MEDIA too , isn't?
Cheers
      04-21-2013, 08:27 PM   #607
shawnsheridan
Cheers
Yes, that is correct.
      04-22-2013, 10:32 PM   #608
scottjays
Starfleet inner circle
scottjays's Avatar
Drives: 2016 X5 35i X Line
I have been lurking this thread. I wish I had more courage to try coding my '14 X3...is anyone in the South FL area willing to hand hold or even accept $$ assistance with coding?
2016 BMW X5 35i X Line Space Gray, Mocha Nappa Int, PureWood. Driver Assistance, Premium, Dynamic Handling, Light Pack LED, HarmanKardonSound Lux Seating w/ MultiContour, Dynamic Damper, Cermanic Ctrls, ACC StopGo. MODS: M Sport Steering Wheel w/Paddles Coded.
      04-23-2013, 11:35 AM   #609
erkbiz
Drives: 2013 x3
Please un-confuse me - what files do I need?
Hello,
I own a 2013 X3. I recently downloaded a set of files that included E-sys application and psdzdata 47.5. I got this in this bundle: BMW_E-Sys_3.18.4_47.5
I have been reading many different posts on coding and have seen reference to a psdzdata file 4.85, (I think), and now I am seeing something about a 4.9.
Can someone please tell me exactly what I need to begin coding? The first thing I want to do is to code a digital mph display to my instrument panel.
- Will the 47.5 be sufficient?
- If I need a later version can someone tell me how to get it?
- Will a later version run with E-Sys version 3.18.4?
Thanks in advance for your assistance.
ERK
2013 X3 28i
      04-23-2013, 12:07 PM   #610
erkbiz
Drives: 2013 x3
Hello,
ERK
2013 X3 28i
      04-23-2013, 09:37 PM   #611
shawnsheridan
Originally Posted by erkbiz View Post
Hello,
ERK
2013 X3 28i
47.5 is from July 2012, 9 months ago. It is almost certainly too old to Code your MY 2013 F25.
To know with certainty what you need, the I-Level of the car must be determined. You can do this though using the E-Sys 3.18.4 and 47.5 PSdZData you already have as follows:
http://www.f30post.com/forums/showpo...postcount=1403
If your I-Step (current) is <= F025-12-07-507, you can code your car with what you have.
If your I-Step (current) is >= F025-12-07-507 & <= F025-12-07-509, you need 48.3 PSdZData to code your car.
If your I-Step (current) is >= F025-13-03-501, you need 49.x PSdZData to AND E-Sys 3.22.5 to code your car, the later of which requires a new Patch / Token.
If you just want to play it safe, then go with E-Sys 3.22.5 and 49.x PSdZData as you can't go wrong since it is fully backwards compatible.
      04-27-2013, 09:30 PM   #612
leoleakey
Drives: X3
Possible to code the car default to ECO mode?
      05-07-2013, 03:48 PM   #613
roadkillrob
Drives: 08 335i,16 X5 35i,12 C63 AMG
Just wanted to give a big thanks to shawnsheridan for helping me out with e-sys. I have been coding for a while with INPA on my E93 and X5, but ordered a new X3 in early April and got a lot of good advice and help from Shawn. Picked up the X3 Saturday and started coding Sunday, realized I needed 49.3 data file, so again Shawn helped me out.
E-sys is much easier to setup and use than INPA and now my wife is happy that everything works as it should (and like I coded on the X5).
So far added:
M3 speedo
Close hatch with fob and dash button
Fold mirrors from the fob
Open and close all windows and sunroof with FOB
auto unlock doors when engine is turned off
went to set auto start stop to remember last setting, but was already set to that in my 2014
removed nav and camera warning screens
I added caller ID, entertainment options and blinkers to HUD, have not tested to see if they work yet.
set the windows to continue to roll down when doors are opened - untested
tonight going to try to add the M Performance Logo instead of BMW logo on the instrument cluster - apparently this is a bit hit or miss model to model if it works or not - probably depends if the logo file is loaded into the cluster or not.
If you haven't done any coding yet, highly recommended and reasonably easy to setup and use!
Rob
2008 E93 335i, MHD, HPF IC, Injen Intake, AR DPs, Xhp TCU Flash
2016 X5 M-sport 35i JB Stage 1
2013 Mercedes C63 AMG, ROW airboxes, power pipe, Eurocharged V7 540 HP
      05-07-2013, 06:02 PM   #614
shawnsheridan
So far added:
M3 speedo
Rob
      05-07-2013, 06:18 PM   #615
sfiermon
Drives: 2011 BMW 535xi
I have a 2014 x3. Who do I need to email to get this started? What files do I need??
      05-10-2013, 09:29 AM   #616
UsualSuspect
Lieutenant General ***
UsualSuspect's Avatar
Drives: this way and that way...
Can someone point me in the right direction of the software?
Everyone has a photographic memory, some just don't have film.
