XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Coding made Easy: A step by step procedure
      01-12-2013, 03:57 PM   #485
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Use this procedure:
Enabling the .NET Framework 3.5 in Control Panel
You can enable the .NET Framework 3.5 yourself through Control Panel. In Control Panel, choose Programs and Features, choose Turn Windows features on or off, and then select the Microsoft .NET Framework 3.5.1 check box. This option requires an Internet connection.
      01-12-2013, 04:09 PM   #486
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Originally Posted by lbjgh View Post
Shawn, as noka pointed out I was using the instructions that worked previously. The screen shot was my attempted work-around.
noka, The instructions worked fine the first time I installed on an older system.
@ april1, I enabled .net framework ver. 4.5 (win8 option) and I'm currently reinstalling the software.
I'll provide updates shortly...
Ok. I give up. I don't have Win8 to test it with, but it is hard to understand why it would behave any differently.
I can see where the older .NET Framework is perhaps needed to run it, but I don't think it will make any difference with this configuration issue.
I don't know if it is an option for Win8, but if it is, you can use XP Mode and install it into the XP Virtual Machine.
- 2011 535i M-Sport - AW/BLK/DW - /ZMP(w/ARS & AD)/ZPP/ZP2(w/ZPS & ZPT)/ZCV(w/SCAD)/6FL/6VC
- 2006 530i - SG/BLK/DW - /ZPP/ZCW/NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
shawnsheridan is offline   United_States
      01-12-2013, 04:15 PM   #487
April1
Love All
April1's Avatar
Drives: X3 28i 2011
ESys 3.18 uses the old .Net framework and when it was reported that certain buttons are not enabled, the first thing that flashed to my mind was if the win 8 is still supporting it. I made a quick check and found that win 8 only supports net framework 4.5 but provides an option to add older framework through control panel.
      01-12-2013, 04:17 PM   #488
shawnsheridan
Ok. Hopefully 3.5 Framework is the solution.
- BMWCCA #446923
- flick
      01-12-2013, 06:28 PM   #489
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
SOL!
lbjgh is offline   Canada
      01-13-2013, 03:45 AM   #490
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Two points:
1. Try to use Expert Mode on left pane with Code button selected
2. Why "Werte" is showing 00 whereas Values from ECU shows 01, didnt you save first on the right corner?
      01-13-2013, 10:06 AM   #491
shawnsheridan
Two points:
Yes, I would test this on regular FDL Code Change first, before trying a Werte Value change.
- BMWCCA #446923
- flick
      01-13-2013, 10:24 AM   #492
lbjgh
lbjgh's Avatar
I've got something in the works... Update this pm.
      01-13-2013, 10:30 AM   #493
shawnsheridan
Something other than what I sent you to try, or is that what you are referring to?
- BMWCCA #446923
- flick
      01-13-2013, 12:20 PM   #494
lbjgh
lbjgh's Avatar
It's what you sent.
April1
I did... I just went back in to show the save icon greyed out still.
I was changing that value but ain't able to save the value...
      01-13-2013, 01:54 PM   #495
groovyone789
Drives: 2013 BMW X3 28i
I think he meant, did you apply the value by pressing CTRL-ENTER and then saving?
groovyone789 is offline   Reply With Quote
      01-14-2013, 12:48 AM   #496
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Forgot to mention that you need to reinstall E-Sys after installing dot net framework 3.5.1
      01-14-2013, 07:57 AM   #497
lbjgh
lbjgh's Avatar
I was in contact with April1 offline and E-Sys is now working on my win8 laptop. I did reinstall the software after enabling .net 3.5.1 which seems to have done the trick (this is after several installs/uninstalls and tweaking).
One other thing I did was, I left the default data location post software installation then set the token location under the EST tab.
      01-16-2013, 11:28 AM   #498
69clementinast
Drives: BMW F25 X3 2.8i
April1, could you send me an email? I want to talk about getting a cable and flashdrive with software etc.
thayermoeller at gmail dot com
Thanks!
69clementinast is offline   Reply With Quote
      01-18-2013, 12:22 AM   #499
69clementinast
windows 7 on vmware
So, I just received my cable and flash drive from April 1 (overnight delivery a huge plus). Quick question, I have a work computer that is a windows desktop but want to run on my apple macbook with vmware. I've read in a few places that some of the software may or may not work with the 64bit version of windows 7. That said it isn't clear if it is esys or some other piece of software that won't work. Does anyone know if I need to get the 32 bit version or can i use the 64? Don't want to get the less efficient version if i can avoid it. Thanks!
      01-18-2013, 07:32 AM   #500
shawnsheridan
E-Sys works fine on 64-Bit. There is a companion utility application named ZGW_SEARCH.exe that is informational only, which will show you the IP Connection to the car. Version 1 of it must be run in XP Compatibility Mode. Version 2 of it can run natively on 64-Bit. Or, since it is non-functional, you don't need to run it at all.
- BMWCCA #446923
- flick
      01-18-2013, 07:59 AM   #501
noka
Drives: 2013 x35i M-Sport
From a performance standpoint, is it significant whether running e.g. XP/32, Win7/32, Win7/64, Win8? Does it really make much difference in time to update the car's parameters? I was thinking of using an old laptop with XP/SP3 but if it would be so much faster with Win7/64, I would try that instead.
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired: '09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, '01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i,... '86 4000 CS Quattro... too many to list.
noka is offline   United_States
      01-18-2013, 08:01 AM   #502
shawnsheridan
Originally Posted by noka View Post
From a performance standpoint, is it significant whether running e.g. XP/32, Win/32, Win/64, Win8? Does it really make much difference in time to update the car's parameters? I was thinking of using an old laptop with XP/SP3 but if it would be so much faster with Win7/64, I would try that instead.
No. I have it running both natively on my Win7 64-Bit machine, and virtualized inside XP Mode, and there is hardly a difference in execution.
- BMWCCA #446923
- flick
      01-27-2013, 07:10 PM   #503
ch35iM
Drives: 2013 X3 35i M Sport
When I go to connect to the car i have the vin number dispalyed in "Connection via vin" but there are no target selectors, any idea what is wrong?
ch35iM is offline   United_States
      01-27-2013, 07:23 PM   #504
shawnsheridan
Make sure the car is turned on.
Make sure that there is a "Dist" folder in each of the Chassis (F01/F10/F25) folders etc.:
e.g. "C:\ESysData\psdzdata\mainseries\F010\F010_12_03_5 1 1\odx\dist"
It should be empty, but the folder must exist:
Name:  E-Sys - Dist Folder.jpg
- BMWCCA #446923
- flick
      01-27-2013, 09:13 PM   #505
ch35iM
That did it, thanks. Those folders were missing for some reason
      02-02-2013, 01:10 PM   #506
BBender
Drives: X3
I need to code previously backed up FDL, how to do it correctly?
Connect > Read VO > Read SVT > Read coding data (from the required ECU) > then overwrite CAF file in ESYS CAF folder with originally backed up file > Activate FA > Code FDL?
BBender is offline   Reply With Quote
Forum Jump
