XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Coding made Easy: A step by step procedure
      01-06-2013, 12:03 PM   #441
Wallo
Drives: X3 F25
Originally Posted by c3uo
Sorry, I've been testing running the software (no cable yet) and opening menus, etc. When you run Tool32 by double clicking the file and then hit F3 and then press F01.prg it just spins the circle and does not go any further..... However, if you run it as administrator it has no problem. I think it's a unique problem to Windows 7.
I'm trying to look through every parameter and all information before I get the cable and connect to my car. I'm pretty scared of f*^$ing something up.
Thanks!
Yes, that solves the problem. Running it as an administrator did it for me.
Btw, I am also very new to coding and followed all the instructions from this thread step by step. It worked perfectly!
Wallo is offline   Germany
      01-06-2013, 05:42 PM   #442
Wallo
Drives: X3 F25
EDIBAS was not able to load F01.PRG - it got stuck while opening the file. Anyways, I assume the fault condition is still existing due to the fact that the importer of the car changed the light settings according to German regulations. Some setting seems to make the system assume that the car has the automatic headlight adjustment built in, but in fact it does not.[/quote]
The failure continues. I do not have the automatic headlight adjustment installed, but it is somewhere activated, thus the failure message. I found a thread in the E90 forum that deals with this issue. They suggest to change CHECK_SMC_ERROR in the NFRM part to nicht_aktiv in order to turn off this check.
I cannot find NFRM in my F25, only FRM, but there is no entry CHECK_SMC_ERROR. Does anybody know where I would find that entry for the F25?
      01-06-2013, 05:52 PM   #443
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Try running Tool32 as an Administrator.
- 2011 535i M-Sport - AW/BLK/DW - /ZMP(w/ARS & AD)/ZPP/ZP2(w/ZPS & ZPT)/ZCV(w/SCAD)/6FL/6VC
- 2006 530i - SG/BLK/DW - /ZPP/ZCW/NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
shawnsheridan is online now   United_States
      01-06-2013, 08:25 PM   #444
xodium
Drives: X3
Originally Posted by xodium View Post
I'm getting an error when i click "connect" on E-sys:
Set PSdZ-Root using "C:\ESysData" failed! [C073]
I've searched the forum and it seems related to the psdzdata being corrupt. Could someone please give me the link to the psdzdata? I've already downloaded this via usenet. I don't want to download from there again as the files may have been corrupt. Thanks in advance....
Originally Posted by shawnsheridan View Post
You can't receive any PM's presumably because of your low Post count. Post up your email if you want the link.
Got it working now. the psdzdata folder was the culprit... Thanks again
xodium is offline   United_States
      01-06-2013, 09:02 PM   #445
noka
Drives: 2013 x35i M-Sport
In anticipation of doing some coding after my X3 arrives, what's the best OS to use (XP/SP3 or Win7/SP1, and if the latter, 32 or 64 bit)?
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired: '09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, '01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i,... '86 4000 CS Quattro... too many to list.
noka is offline   United_States
      01-06-2013, 09:12 PM   #446
xodium
Drives: X3
XP I guess is the best. I used 32 Bit Win 7/SP1. I set up esys to run as administrator. I didn't check if it will run in normal mode though...
      01-06-2013, 09:14 PM   #447
shawnsheridan
Ideally it would be XP 32-Bit, but it will run on Win7 32-Bit or 64-Bit too without any problems.
- BMWCCA #446923
- flick
      01-06-2013, 09:15 PM   #448
noka
Thanks for the quick reply. I have an spare/older Dell laptop with XP/SP3. I'll try that one.
      01-06-2013, 10:10 PM   #449
pmacd55
pmacd55's Avatar
Drives: 2013 F25
2013 BMW X3  [0.00]
2011 328 xi  [0.00]
Coded mine with Win 7 64 bit... no probs
pmacd55 is offline   Reply With Quote
      01-07-2013, 11:06 AM   #450
Longbow64
_______
Longbow64's Avatar
Drives: 09 E90 M3, 13 X3 35i MSport
I was able to code my F25 X3 without issue with a Win 7 64 bit laptop as well. I was not able to code my E90 M3 with NCSEXPER with the same laptop.
'09 E90 M3 SG | VF620 SC | BPM Sport coding | AA Catless Exhaust | KW V3 | BMW Performance Wheel | Alpine 8K Eyes | 355M Style Wheels | Recaro Child Seat
'13 X3 DSB with M Sport | H&R Springs | Gloss black grill | Coded by me
Longbow64 is offline   Reply With Quote
      01-07-2013, 11:09 AM   #451
shawnsheridan
No, but you can if you upgrade to BMW Standard Tools 212, which adds support for 64 Bit NCS Expert.
- BMWCCA #446923
- flick
      01-07-2013, 12:20 PM   #452
groovyone789
Drives: 2013 BMW X3 28i
Got everything coded the other night. Thanks to Shawnsheridan and April1 for their help. I can also confirm it works on a super old VAIO netbook running Vista.
groovyone789 is offline   Reply With Quote
      01-07-2013, 12:49 PM   #453
shawnsheridan
- BMWCCA #446923
- flick
      01-07-2013, 07:30 PM   #454
pmacd55
pmacd55's Avatar
Drives: 2013 F25
2013 BMW X3  [0.00]
2011 328 xi  [0.00]
Vista LOL.... if it works with that it'll work with anything !!
      01-07-2013, 07:57 PM   #455
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
hey, don't slag Vista... I just installed it on an old laptop for my son over the weekend and it's working fine. It only took about 2GB of updates.
lbjgh is offline   Canada
      01-07-2013, 09:41 PM   #456
pmacd55
pmacd55's Avatar
Drives: 2013 F25
2013 BMW X3  [0.00]
2011 328 xi  [0.00]
Well I guess it's better than Microsoft Bob, if you go back that far !
      01-08-2013, 05:53 PM   #457
Wallo
Drives: X3 F25
Traffic info in nav
Hi again, I managed to get traffic information (TP) into the configuration for the German setup, it also interrupts CDs when they broadcast traffic on the radio, but it is not transferred to the nav system. Does anybody know what else I need to change?
      01-08-2013, 09:44 PM   #458
noka
The reading is dynamic
I assume the display is just green (OK) or red (low) for the default TPMS display and that a warning is also generated. After coding, to include temperature and pressure readings (shown below in pic from older post by Longbow64), does a low tire still turn red and is there still a warning generated?
      01-08-2013, 10:18 PM   #459
shawnsheridan
It functions as it always did, only with the addition of Pressure and Temperature readings.
- BMWCCA #446923
- flick
      01-09-2013, 05:36 PM   #460
lbjgh
lbjgh's Avatar
Hey guys, I got a new laptop with win8 and now the save icon is greyed out so I can't save the changes to the FDL during the coding process.
Is there a work around for this?
      01-09-2013, 05:48 PM   #461
shawnsheridan
You installed the EST Token correctly?
- BMWCCA #446923
- flick
      01-09-2013, 05:52 PM   #462
lbjgh
lbjgh's Avatar
Yep, I used april1 instructions and it worked fine on an old winxp laptop.
I was able to connect to the car, read FA and SVT ok.
I'll go through the instructions again to double check I didn't miss anything.
Forum Jump
