XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Coding made Easy: A step by step procedure
      11-07-2012, 10:30 AM   #265
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Originally Posted by chx437 View Post
New with E-Sys and some beginners problems:
- when installed the software all went Ok
- ZGW_Search detects the ENET cable Ok and gets e.g. the VIN
But when starting the E-Sys it cannot connetc to the car:
"Detection of programming target failed. [C032]
MCDError Severity: 2051, Error Code: 53315, Description:
internal error, Vendor Code: 28, Vendor Description:
could not parse Db project [2130759747] - SYSTEM_ERROR"
I tried two laptops (both running Win7 x64) but the same error from both.
One additional detail: E-Sys never asked any PIN ...is this normal?
Anyone had similar experience ...any hint how to get forward?
Here's the error msg with all the detailed text:
It seems you have not installed the psdzdata files correctly.
      11-07-2012, 10:46 AM   #266
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Originally Posted by pacecapt View Post
How do I load my vehicle coding (CAF/.ncd) files into E-Sys in order to edit or view them when not connected to my vehicle? I have gone through the E-Sys "Editors and Viewers" Tab documentation but it seems to have missed a step. I am able to copy and move the .ncd files but I can't seem to load them as it keeps asking me for an FA and that folder is empty. I have not been able to connect the dots between page 2 and 3 of that Tab.
To view your cafd files when not connected to car, you should save your SVT during the last connection to car. Following are the steps:
Connect to the car
As usual read FA and SVT
Now save FA and SVT to a location of your choice but outside E-Sys.
In the process save all the cafd files too
Disconnect ESys
You are now ready for off line reading.
Start ESys
Don't press connect button
Press load to load saved FA (this may be optional)
Press load to load SVT
Right click on any green cafd file marker and New>FDL
Point to the right saved cafd file
Now follow your steps
      11-07-2012, 11:57 AM   #267
chx437
Drives: BMW X3(F25)
Thanks April!
Perhaps you can give some further quidance based on following info:
My psdzdata folder "c:\ESysSData\psdzdata" contains all files extracted by WinRAR from the original psdzdata 47.4 rar -packages (using all the 23 downloaded *.rar files). In the "psdzdata\mainseries" subfolder there are some additional folders & files generated during the installation.
The data files in psdzdata were just extracted by WinRAR and there was no any other processing before using them, is this ok ?
The "status" of the other subfoldres in the ESysData -folder is:
CAF - no files here
EST - two files here, e.g. Code Away.est
Etc - no files here
FA - on sample xml file here
FP - no files here
Logs - several log files
ODX - no files here
Rules - three .jar files
SWE - no files here
SVT - no files here
SWT - no files here
TAL - no files here
...and My car is X3(F25) built on 9/2011.
chx437 is offline   Reply With Quote
      11-08-2012, 09:03 AM   #268
pacecapt
Drives: 2011 528i & 2013 X3 28i
2011 BMW 528i  [0.00]
2013 BMW X3 28i  [0.00]
Connect to the car
Disconnect ESys
Start ESys
Thanks, that is what I did not do. I had only saved my cadf files and not the FA nor the SVT. Thanks for the the assist.
pacecapt is offline   United_States
      11-08-2012, 09:17 AM   #269
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
If you want to look at your car's read ECU coding data (CAFD .ncd files), you only need to launch E-Sys, go to the Editors & Viewers, open the FDL-Editor, put your PIN in, and then navigate to your CAF folder (C:\ESysData\CAF) and select the desired CAFD file's corresponding read coding data .ncd file.
If you want to look at an unread CAFD file, launch the CAF-Viewer, and then navigate to your CAFD folder (C:\ESysData\psdzdata\swe\cafd) and select the desired CAFD.
- 2011 535i M-Sport - AW/BLK/DW - /ZMP(w/ARS & AD)/ZPP/ZP2(w/ZPS & ZPT)/ZCV(w/SCAD)/6FL/6VC
- 2006 530i - SG/BLK/DW - /ZPP/ZCW/NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
shawnsheridan is online now   United_States
      11-08-2012, 09:47 AM   #270
pacecapt
I have tried both your way and April1 and I get an error message "No EST file chosen". I have associated the cadf files to the SVT but still can't get any further.
      11-08-2012, 10:31 AM   #271
shawnsheridan
Copy "e-sys est" folder from "\\BMW E-Sys\E-Sys Program\e-sys est" to "C:\ESysData\e-sys est"
Launch E-Sys, and Under Options, Settings:
On the EST Tab, set the Developer-Soft-Token EST Path to "C:\ESysData\e-sys est\Code Away.est"
Also, while there, make sure that on the PROGRAM TAB, you set the Directories - Data Path to C:\ESysData
- BMWCCA #446923
- flick
      11-08-2012, 10:57 AM   #272
pacecapt
I figured it out I had not pointed the software to the codeaway file in the EST Folder.
      11-17-2012, 05:15 AM   #273
ricksters
Drives: 2013 X3 28i
Anyone coding in the Pittsburgh area?
ricksters is online now   United_States
      11-18-2012, 12:39 AM   #274
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Thanks April!
CAF - no files here
Etc - no files here
FP - no files here
ODX - no files here
SWE - no files here
SVT - no files here
SWT - no files here
TAL - no files here
Sorry for late reply.
psdzdata folder should have following sub-folders:
extLibs
kiswb
mainseries
mapping
security
swe
temp
please check that there is a dist folder in each of the odx folder of sub-folders of odx of each series.
Other folders and contents are corect as stated by you.
      11-18-2012, 02:49 AM   #275
shawnsheridan
extLibs
kiswb
mainseries
mapping
security
swe
temp
The Temp folder is not needed and may or may not exist depending on the PSdZData version and who packaged it. I think it may actually be created by E-Sys after running it, as I have the folder now, but it was not in the original downloaded 47.5 PSdZData.
- BMWCCA #446923
- flick
      11-18-2012, 03:07 AM   #276
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Yes ESYS creates the temp folder, so it can be ignored.
      11-29-2012, 04:54 PM   #277
X3Bimmer
Drives: '13 X3 35i
I'm up and going on coding to get the X3 just they way we like it...
Many thanks to April1 for his time and support.
Cheers
X3Bimmer is offline   Reply With Quote
      11-29-2012, 09:51 PM   #278
BeeMdblU
BeeMdblU's Avatar
Drives: Audi A4, CLK55, F25 35M
Cheers
report back what you did
BeeMdblU is offline   Reply With Quote
      11-30-2012, 03:59 PM   #279
BBender
Drives: X3
Does anyone knows how to enable display % of battery's charge?
BBender is offline   Reply With Quote
      11-30-2012, 05:57 PM   #280
X3Bimmer
Drives: '13 X3 35i
Cheers
Coded thus far:
close trunk/tailgate with key fob and with driverside button
DVD in Motion
disabled iDrive and camera disclaimer
temp and pressure to TPMS screen
show gear (S1-S7) in sport mode
pressure and temp readings in TPMS
unlock doors when engine stops
close mirros+windows+moon roof through key fob and comfort access
fog lights w/high beams
digital speed displayed in BC
set auto stop/start to last setting by default
Also coded weatherband
      12-01-2012, 01:15 PM   #281
BBender
Drives: X3
"show gear (S1-S7) in sport mode"
how this is made?
      12-01-2012, 04:16 PM   #282
shawnsheridan
how this is made?
EGS module, set both of these to aktiv:
Sportschalter
Sportschalter_alt
- BMWCCA #446923
- flick
      12-01-2012, 05:57 PM   #283
pmacd55
pmacd55's Avatar
Drives: 2013 F25
2013 BMW X3  [0.00]
2011 328 xi  [0.00]
Finally got a chance to do some coding ... reminds me a little of changing registry settings in windows anyways got:
DVD in Motion
Disabled iDrive and camera disclaimer
More tommorrow.
Big thanks to April1 got his coding kit and works perfect right out of the box !
pmacd55 is offline   Reply With Quote
      12-02-2012, 08:52 PM   #284
boogysbmw
I love my X3
boogysbmw's Avatar
Drives: 2013 BMW X3 28i
Hey guys, I just tried coding and I am missing modules such as HU_CIC and CMD_Media??
Any ideas why? I was able to code BKOMBI and gain access to the MPH on the BC
Any immediate help would be gratefully appreciated
2013 X3 28i Alpine White/ Black Nevada Leather/premium pkg/convenience/sport/DHP/Cold weather 1/Premium sound/Parking sensors/Alpine PDX-M12 AMP powering one Alpine SWR 12D4
boogysbmw is offline   United_States
      12-02-2012, 09:03 PM   #285
shawnsheridan
Your Head Unit is HU_CHAMP instead of HU_CIC because you do not have 609 Navigation. You do not have CMB_MEDIA, because you do not have 6VC Combox. And as you already discovered your KOMBI is BKOMBI for basic Instrument Cluster.
- BMWCCA #446923
- flick
      12-02-2012, 09:08 PM   #286
boogysbmw
I love my X3
boogysbmw's Avatar
that sucks! so i can't unlock half of these cool new features!!! very sad day indeed wasted money on a cable for nothing
Forum Jump
