XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Coding made Easy: A step by step procedure
      10-22-2012, 01:28 PM   #243
chx437
Drives: BMW X3(F25)
A question for the coding experts here if you have you found any hints to:
- enable (or to disable) the rear lights when the main light switch is on "AUTOMATIC" and the DRLs are on ...in the first X3(F25) models upto 2012 the rear lights were on when DRLs were on but later after some SW update the rear lights were not any more on automatically
- disable (or to enable) the bulb monitoring for the flasher bulbs ...to prepare the change for flasher LED bulbs without additional parallel resistors
chx437 is offline   Reply With Quote
      10-23-2012, 03:10 AM   #244
saggo
Drives: X3 30d M Sport
Originally Posted by Colflqgg View Post
What codes did you change to make the headlights fade on and to change the delay on the wiper spray?
Thanks!
Regarding the welcome light function, you can choose which group of lights on your vehicle are utilised for this function and how the ECU turns them on / off. Choosing the exponential function rather than the logarithmic type will result in a more 'even' rate of increase / decrease in brightness over time.
FRM 3050 WL_FUNKTION_AL
Options are: nicht_aktiv / soft_on / hard_on / soft_on_LED
Default setting: nicht_aktiv / Werte=00
Welcome Lights - Low Beam Lights - 0 = Off; 1 = Soft (log); 2 = Hard (instant on); 3 = Soft (exp)
FRM 3050 WL_FUNKTION_FL
Welcome Lights - High Beam - 0 = Off; 1 = Soft (log); 2 = Hard (instant on); 3 = Soft (exp)
FRM 3050 WL_FUNKTION_KZL
Default setting: hard_on / Werte=02
Welcome Lights - License Plate Lights - 0 = Off; 1 = Soft (log); 2 = Hard (instant on); 3 = Soft (exp)
FRM 3050 WL_FUNKTION_NSW
Welcome Lights - Fog Lights - 0 = Off; 1 = Soft (log); 2 = Hard (instant on); 3 = Soft (exp)
FRM 3050 WL_FUNKTION_POL
Welcome Lights - Position Lights (Angel Eyes and Front Side LED's) - 0 = Off; 1 = Soft (log); 2 = Hard (instant on); 3 = Soft (exp)
FRM 3050 WL_FUNKTION_SSL
Welcome Lights - Tail Lights - 0 = Off; 1 = Soft (log); 2 = Hard (instant on); 3 = Soft (exp)
Wash before Wipe delay:
JBBFE, 3000 Wipe_Wash, WASHWITHOUTWIPE_TIME
Default value on my X3 is 200mSec
For info, the first graph below shows the exponential function and the second logarithmic, you can see that the exponential is more 'linear'...
X3 30d MSport in AW Red Brown Trim
Media Pack Vis Pack Cold Weather Pack Electric Seats Towbar Reverse Cam Internet Bluetooth with Telematics DAB Business Loudspeaker Mobile Apps
saggo is offline   United Kingdom
      10-23-2012, 04:13 PM   #245
mge.92
SPEED RACER
mge.92's Avatar
Drives: X3 28I M SPORT
How do I code a BMW exx when I have the latest software and it will only allow me to code fxx vehicles?
mge.92 is offline   United_States
      10-23-2012, 04:42 PM   #246
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
You need NCS Expert and SP-Daten to code Exx Chassis.
- 2011 535i M-Sport - AW/BLK/DW - /ZMP(w/ARS & AD)/ZPP/ZP2(w/ZPS & ZPT)/ZCV(w/SCAD)/6FL/6VC
- 2006 530i - SG/BLK/DW - /ZPP/ZCW/NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
shawnsheridan is offline   United_States
      10-23-2012, 04:52 PM   #247
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
Anyone know if the voltage can be displayed in the BC?
lbjgh is offline   Canada
      10-23-2012, 04:53 PM   #248
shawnsheridan
Only through CIC Hidden Menu.
- BMWCCA #446923
- flick
      10-23-2012, 05:33 PM   #249
02420X3
Drives: 2011 X3 35i
When I want to monitor voltage I use a plug-in Equus gauge in the cigarette lighter socket between the cupholders. $15 from Amazon US,
02420X3 is offline   Reply With Quote
      10-25-2012, 03:53 PM   #250
lbjgh
lbjgh's Avatar
Something I found interesting tonight... I can view the owners manual while the car is in motion now.
I think it must be tied to dvd playback in motion.
It sure beats having to pull over and stop to check a feature especially if the passenger is doing the reading.
      10-25-2012, 03:54 PM   #251
lbjgh
lbjgh's Avatar
Something I found interesting tonight... I can view the owners manual while the car is in motion.
      10-25-2012, 11:05 PM   #252
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Yes you are right. I had noticed it too.
      10-26-2012, 08:47 AM   #253
gareth12468
Drives: 2011 X3 xDrive 28i
2011 BMW X3  [0.00]
I need to get the cable now.....
gareth12468 is offline   Canada
      10-28-2012, 05:07 PM   #254
tobert
Drives: 2013 X3 28i
Does anyone know how to code so the front orange turn signal lights do not come on when the parking lights are on (just the halo would illuminate)?
Also, does anyone know how when the headlights are set to auto, to make the fog light not illuminate when the turn signal is engaged?
tobert is offline   Reply With Quote
      10-28-2012, 05:15 PM   #255
shawnsheridan
I'm not sure if anyone ever confirmed it, but for the Side Markers, look for this or something similar:
FEM_BODY / 3063 LceLampMapping2 / MAPPING_SIDEMARKER_L_OUTPUT = off
FEM_BODY / 3063 LceLampMapping2 / MAPPING_SIDEMARKER_R_OUTPUT = off
Not sure about the Fog Lights.
- BMWCCA #446923
- flick
      11-05-2012, 04:59 PM   #256
chx437
Drives: BMW X3(F25)
Once again here's one needing info where to download psdzdata 47.4
...shawnheridian, april1 please
      11-05-2012, 05:18 PM   #257
saggo
Forgive my ignorance, how do you access this hidden menu?
      11-05-2012, 06:16 PM   #258
lbjgh
lbjgh's Avatar
I haven't tried this on my car but it may be worth a try:
      11-06-2012, 12:50 AM   #259
shawnsheridan
PM Sent.
- BMWCCA #446923
- flick
      11-06-2012, 12:54 AM   #260
shawnsheridan
  1. Hold down the odometer reset button and turn the ignition on by pushing start/stop button.
  2. Release the odometer reset button, and you should see a menu of 4 items on the dashboard. From here on, use the odo-reset button to advance to the next entry through a short press, and to select through a long press.
  3. Choose the one that says Unlock through the above, which will take you to a passkey screen. Your passkey is the sum of the last 5 digits of your VIN. Increment the two-digit number until you get to it, and with the long press of the odo button, select it.
- BMWCCA #446923
- flick
      11-06-2012, 01:04 AM   #261
chx437
Drives: BMW X3(F25)
PM Sent.
Thanks !!!
      11-06-2012, 07:09 AM   #262
saggo
Many Thanks - I'll play later!
      11-06-2012, 12:55 PM   #263
pacecapt
Drives: 2011 528i & 2013 X3 28i
2011 BMW 528i  [0.00]
2013 BMW X3 28i  [0.00]
How do I load my vehicle coding (CAF/.ncd) files into E-Sys in order to edit or view them when not connected to my vehicle? I have gone through the E-Sys "Editors and Viewers" Tab documentation but it seems to have missed a step. I am able to copy and move the .ncd files but I can't seem to load them as it keeps asking me for an FA and that folder is empty. I have not been able to connect the dots between page 2 and 3 of that Tab.
pacecapt is offline   United_States
      11-07-2012, 06:59 AM   #264
chx437
Drives: BMW X3(F25)
New with E-Sys and some beginners problems:
- when installed the software all went Ok
- ZGW_Search detects the ENET cable Ok and gets e.g. the VIN
But when starting the E-Sys it cannot connetc to the car:
"Detection of programming target failed. [C032]
MCDError Severity: 2051, Error Code: 53315, Description:
internal error, Vendor Code: 28, Vendor Description:
could not parse Db project [2130759747] - SYSTEM_ERROR"
I tried two laptops (both running Win7 x64) but the same error from both.
One additional detail: E-Sys never asked any PIN ...is this normal?
Anyone had similar experience ...any hint how to get forward?
Here's the error msg with all the detailed text:
Forum Jump
