09-11-2018, 05:47 PM | #2443 | ||
________
4160
Rep 2,301
09-11-2018, 07:45 PM | #2444 | |
Rep 8,364
09-12-2018, 05:12 PM | #2446 |
Rep 84
i just have to get myself a cable, as there are a few functions i would like to code as default.
1) retract side mirrors, remote for tailgate, eco mode, and do not turn off engine. |
09-13-2018, 11:26 AM | #2447 | |
Mr
21
Rep 103
I just copied the error message here below: CAFD_00000DED_003_015_039 Fehler: CPS read from ECU "ECUId:HU_ENTRYNAV_0x63" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; LinkName: HU_ENTRYNAV_63_ETHERNET severity: ERROR [2130765072] I think the CAFD file is: CAFD_00000DED_003_015_039 I checked the PSDZdata and the CAFD file is there: cafd_00000ded.caf.003_015_039 One more thing. When I did the first coding sesion the system asked me to set time and date and the kilometers of the trip info sere set to zero. Also it appeared a message to take the car to the dealer. This message disappeared after setting time and date and to turn off the car. I noticed that the fuel compsumtion has turned high (according to cluster info 5km/l instead of 8-9 km/l that I got before coding). Thanks in advance |
09-13-2018, 11:28 AM | #2448 |
Mr
21
Rep 103
09-13-2018, 09:56 PM | #2449 | |
Rep 8,364
Is engine running? What Launcher Chassis and E-sys Connection target are you using? https://www.bimmerfest.com/forums/sh...d.php?t=983245 - See normal behavior. |
09-13-2018, 11:44 PM | #2450 | |
Mr
21
Rep 103
I think I have partially sorted out the problem: I followed a procedure ( i think it is yours Almaretto) of generating CAFD files from original FA and SVT Using my backup files (the ones i had before making any coding). So I used the CAFD for the HU_Entry Nav (using new FDL). I was able to access to the HU cadf files ( it was not possible before) and I did the coding I wanted ( sport display). After changing the parameters i did FDL coding and I got a warning but it worked. important to mention that when i read the SVT data the ECU HUEntryNav is not shown but I can change the FDL parameters using the backup SVT. Do you know what procedure should i follow to see the HUEntryNav ECU again? Thank tou very much for your support. |
09-13-2018, 11:48 PM | #2451 | |
Rep 8,364
Make sure engine is running and try Read ECU. Engine maintains battery voltage to avoid shutdown and corruption. |
09-14-2018, 12:13 AM | #2452 | |
Mr
21
Rep 103
Thank you very much |
09-14-2018, 09:58 AM | #2453 |
Mr
21
Rep 103
Hi experts, regarding the BMW X3 28i Xdrive (F25) 2017. Do you know what is the part number for the 6WB digital cluster?
I want to make this retrofit. |
10-07-2018, 06:31 PM | #2454 |
Rep 84
finally got my cable, however i noticed in thread you need windows 7. The only laptop i have is XP. Is there a way around this without having to update laptop to windows 7 ?
10-07-2018, 08:31 PM | #2455 | |
Rep 8,364
See if you can install E-sys and Launcher. |
10-16-2018, 10:30 AM | #2456 |
Rep 24
tms
10-16-2018, 10:38 AM | #2457 |
Rep 40,951
Drives: 2018 Alpina B6 650ix GC
I assume TMS replaces an existing TMS, in which case install TMS, Read and Activate FA, and VO Code TMS Module.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
10-16-2018, 04:39 PM | #2458 |
Rep 84
ok for people trying to get a Windows XP native PC installation up and running it is impossible. Even though 2.8.2 now supports "supports XP", it requires .NET 4.6.1, and won't install unless .NET version is done. However when you go to install .NET 4.6.1 or any later version it does a check, which blocks you from installing.
If you try to install any previous 2.8 version, it wont install on XP. Onto a windows 7 install which i hope i can get working. |
10-18-2018, 01:57 PM | #2459 |
Rep 84
ok finally got to coding today. Have done all the basics (backed up all files at each step as per Aprils information)
However i would like the coding information for the following: 1) driving lights to be on when headlights are on (low beam high beam or angel eyes) 2) default the car into eco mode |
10-18-2018, 09:42 PM | #2460 | |
Rep 8,364
2. So Code it. On cheat sheet and in cheat codes. |
________4160.00 |
10-20-2018, 01:02 PM | #2461 | |
Rep 84
option 2 i can't see on aprils cheat sheet attached on post 1 of thread. |
10-20-2018, 02:37 PM | #2462 | ||
________
4160
Rep 2,301
Those are called fog lights. And you have to activate them by pushing the button. When it's foggy, at night. And eco mode during startup is in the cheat sheet: ICM Module / IcmKod_B_InitEco https://docs.google.com/spreadsheets...0P6BSnMXo/edit |
11-30-2018, 12:38 PM | #2464 |
Rep 744
Does anyone know if you can actually code the electronic steering in the X3?
M3 E93
PORSCHE MACAN S: SOLD BMW X3 F25: SOLD AUDI S4: SOLD BMW E92 335: SOLD |
