XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Questions for those who have performed a DIY oil change on the N20 engine
      06-21-2012, 04:33 PM   #1
Eurocar11
Drives: 2013 X3 2.8
For those folks who have already performed a DIY oil change on the N20 (4-cyl) X3 engine, these questions are for you.
1. Exactly how many quarts of oil does the N20 engine take?
2. What is the torque spec for the oil pan drain plug?
I do not want to re-ignite the debate about interval oil changes. I plan on doing my own interval oil change soon but could not locate the exact specs for drain plug torque or oil capacity.
Thanks for your help.
Eurocar11 is offline   United_States
      08-31-2012, 09:25 PM   #2
Masaki
Drives: X3 28i
I am looking for this information myself with not much luck. I found somewhere a mention about 7 quarts, some say 5. 7 seems a bit much for a 4 cyl engine..
Masaki is offline   Reply With Quote
      09-01-2012, 03:41 PM   #3
plymjack
plymjack's Avatar
Drives: X3 (F25) 2.0D SE Auto
Hi - It took 7 litres as per the book. Yes it seems a lot but that's what it wanted.
Quick and easy - once I found the oil filter "hidden" at the back of the engine bay under the air intake. I only did this one as a precautionary after 4000 miles. Will leave the rest to BMW service plan. It did look like it needed it too!
Dont and
BMW X3 (F25) xDrive20d SE . . Alpine White. . Oyster Leather . . 8 Speed Servotronic. .RFTs. . High Beam Assist. . Electric Seats . . DAB Radio. .USB/Bluetooth
plymjack is offline   United Kingdom
      09-02-2012, 07:43 PM   #4
Eurocar11
Drives: 2013 X3 2.8
Since I originally posted the question, I did more research on the web and solved the oil capacity question. The oil capacity is 5.8 liters or 6.1 U.S. quarts.
I did the initial oil change and checked the oil level via the I-Drive. Oil level was dead on.
Where did I find this information? A web site called Automobile-Catalog.com. Look for the link to "Specifications", then search for the car in question.
The 2013 BMW X3 is not listed on the site. However, knowing that the N20 engine is also in the X1, F30 and F10 models, I looked up the specs for those cars and that's where I discovered the information.
The torque spec for the oil drain plug is still a mystery. I just "guessed" that the torque would be the same as the oil filter housing (25 N-m or 18 ft/lbs). So far no leaks.
      09-03-2012, 09:53 PM   #5
Masaki
Drives: X3 28i
That website is a great find, thanks!
      09-04-2012, 03:58 AM   #6
plymjack
plymjack's Avatar
Just to say 6.1 U.S. quarts is not 5.8 litres but is 6.9 litres ...... (No its not see below Wrong!)
Dont and
      09-04-2012, 04:43 AM   #7
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
Originally Posted by plymjack View Post
Just to say 6.1 U.S. quarts is not 5.8 litres but is 6.9 litres (nearly 7 as I previously quoted).
I think you'll find it is 5.8L. 6.9L is 6.1 imperial quarts not US quarts. 1 US gal = 0.83 imperial gal
      09-04-2012, 10:58 AM   #8
plymjack
plymjack's Avatar
According to sources, the operating fluids capacities of this version of 2012 BMW X3 xDrive20i Steptronic are as follows:
Engine lubricant oil capacity:
5.8 liter / 6.1 U.S. qt / 5.1 imp. qt
Engine coolant capacity:
7.5 liter / 7.9 U.S. qt / 6.6 imp. qt
Fuel tank capacity:
67 liter / 17.7 U.S. gal / 14.7 imp. gal
So I will shut up again.....
Dont and
      03-09-2013, 07:03 PM   #9
wrp
Drives: 2013 X3 x28i
My local dealer says the oil change capacity is 5.1 quarts for the 2013 X3 with the 2.0L 4 cylinder turbo N20 engine. I just changed the oil with that amount and the level is at max.
wrp is offline   United_States
      03-16-2013, 12:45 PM   #10
pyratio
Drives: 2013 x3 2.8i
does anyone know which oil filter wrench fits on the X3 n20 engine? Is it a specialty tool or can we use an oil filter wrench from the local auto parts store? Thanks!
~p
pyratio is offline   Reply With Quote
      03-21-2013, 01:19 PM   #11
Masaki
Drives: X3 28i
~p
This is what I use:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Forum Jump
