FORUMS
- 5
| XBimmers | BMW X3 Forum » F25 2.0d tuning chip installation |
| 06-05-2012, 09:51 PM | #3 | |
![]() Drives: 2012 F25 N52T Join Date: Jan 2012
| 06-06-2012, 08:41 AM | #4 | |
| 06-06-2012, 08:48 AM | #5 |
Also very keen to hear how it goes... 99euros makes it look like a bargain so is there a catch?
Dont
and ![]() BMW X3 (F25) xDrive20d SE . . Alpine White. . Oyster Leather . . 8 Speed Servotronic. .RFTs. . High Beam Assist. . Electric Seats . . DAB Radio. .USB/Bluetooth |
| 06-06-2012, 11:07 AM | #6 | |
![]() Drives: 2011 X3 (F25) x-drive 2.0D Join Date: Apr 2011
| 06-06-2012, 12:16 PM | #7 | |
| 06-06-2012, 01:20 PM | #8 | |
| 07-24-2012, 02:57 AM | #9 | |
| 07-24-2012, 03:31 AM | #10 |
Just to let everyone know (since I started this thread) that I gave up. I would say it is not possible to install the chip on F25 in do-it-yourself fashion. It seems you need serios tools and skill to install it + you need to undo it every time you take your car to service, which makes it unpractical.
So F25 with a common rail tuning chip is a no go. |
| 07-24-2012, 04:13 AM | #11 | |
| 07-24-2012, 04:13 AM | #12 |
To be fair to tuningkit I ordered one of these for my 207SW and they emailed me and said it took 3 hours to fit. (It was to be a test before I fitted one to my X3).
I asked about the X3 fit and they said it was a quick job, so I would check with them and them before you give up.
Dont
| 07-24-2012, 04:25 AM | #13 |
Ok, I may have exaggerated a bit regarding tolls and skills. The point is that I was not able to reach the common rail plug after 1 hour of tinkering with the engine in two tries. It is complicated enough to make it unpractical to remove and re-add when I have to service the car. Not to mention that it needs to go out instantly if I have an accident since it is forbidden by law here to modify your car engine.
I did ask tuningkit about this and they offered a refund. I don't know if this is their policy or if they are aware of F25 difficulties. |
| 07-24-2012, 04:34 AM | #14 |
For the X3, now that I know how much force to use to remove parts, I would say it should take around 20-30 mins at an easy pace to get it installed and tied up with cable ties. When you're removing the filter cartridge tray, don't overlook a type of cable holder connector on the right side of it that slides off the tray. I still need to figure out that bloody common rail connector!
| 07-24-2012, 11:43 AM | #15 | |
Captain Unsensible
| 07-24-2012, 01:33 PM | #16 | |
![]() The connector to remove is the at the front of the common rail, correct? |
| 07-25-2012, 02:07 PM | #17 |
So I finally managed to remove the connector from the front of the common rail. Oh sweet Jesus. I need new fingers. It's a bitch to get off. I ended up having to use the foam coated handle of a small pair of pliers to keep it fully pressed in while I pulled it free. Keep a good hold of any object you use around the engine bay as you don't want it falling in. Anyway, my RaceChip is all hooked up now. First impressions are that Normal now kinda feels like Sport and Sport is a bit spritelier. I was still looking for a bit more pull from 3rd and 4th gears so I'm waiting to hear back from RaceChip for the best settings to use to achieve that.
| 07-25-2012, 04:01 PM | #19 |
![]() BMW X3 (F25) xDrive20d SE . . titanium silver . . titanium front grille . . 309s . . xline . . xenons . . black leather . . alu trim . . professional multimedia package . . dynamic package . . climate package . . electric seats . . folding mirrors . . servotronic steering . . DAB radio . . business speakers . . sun protection glass . . split rear seats . . |
| 07-25-2012, 04:11 PM | #20 | |
Warranty is slightly different. Take it off before you take it in for a service or repair and you'll probably get away with it but they could refuse to cover you for warranty repair work if they could prove that the repair was needed as a result of the car being chipped. I don't think they just blindly refuse all warranty work if they suspect the car is chipped.
| 07-25-2012, 04:18 PM | #21 |
Captain Unsensible
Insurance depends on how much power increase you get. I forget the exact number, but if it is under for example a 20% increase, then they do not need to know. I checked. Most of the ones in the UK seem to all tune upto that amount to avoid you having to do it.
Personally, I would not install a chip / box without informing insurance or at least checking. |
| 07-26-2012, 02:17 AM | #22 | |
Dont
| Bookmarks |
