XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Service and oil change and brake pads
      06-04-2012, 02:55 AM   #1
Rodion
Drives: X3 (F25)
I couldn't find old thread about these issues, but would be nice to compare what OBC tells when the next service is due and about brake pads.
Our car has now 5 000km (3 125 miles) on the clock and OBC says:
Service due 29 000km (18 125 miles), or 12/2013 latest. No oil changes done so far.
Front brake pads are estimated to last 60 000km (37 500 miles)
Rear brake pads are estimated to last 50 000km (31 250 miles)
Rodion is offline   Finland
      06-04-2012, 05:17 AM   #2
Nahoa
I'm at 23000 mi and the rear brakes are due.
Nahoa is offline   United_States
      06-04-2012, 07:30 AM   #3
dfcoelho
dfcoelho's Avatar
Drives: 2011 X3(F25) Xdrive 2.0D
Mine has just replaced the rear brake pads with 16000kms!!!
I said to the guy in the workshop that it seemed premature (even by looking at the pad it had a lot of material still to wear) but he said that it had a "sensor". When i picked up the car the info about rear brake pad wear was reseted to 19000kms left.
It seems to me that is has nothing to do with sensors (although I believe there must be some terminal wear indication as usual in all cars), but rather an estimate about what it should last...
Cutting short on the story, the old pads seemed to have almost half of the material remaining on them comparing to new ones (bear in mind that I could only see the outer brake pad, the inner one is not visible without taking the wheel off).
Next time no pad changing before time!!!
dfcoelho is offline   Reply With Quote
      06-04-2012, 08:41 AM   #4
vojak
vojak's Avatar
Drives: F25 35d M Sport
I wouldnt be replacing them until the wear sensor has come on and then this would appear as an alert in the OBC.
Thats why they have this feature.
vojak is offline   United Kingdom
      06-04-2012, 09:16 PM   #5
Nahoa
Watching the rear brake pad service warning count down makes me think it does have a sensor. The last 900 mi didn't drop by day and didn't follow my mileage. Went from 230 mi remaining to zero over a 25 mi commute.
      06-28-2012, 09:13 AM   #6
jdg857
jdg857's Avatar
Drives: 2011 X3 XDrive 28i
My SA told me the other day that annual oil changes are in the maintenance plan regardless of mileage. He also said most people don't know this. The service date for my X3 was August 31st, 2011, and he said that any time during the month of August, 2012 I can have the oil changed at their expense.
jdg857 is offline   Reply With Quote
      06-28-2012, 04:16 PM   #7
rmeir
Drives: x3
my understanding is that bimmers have soft pads which would require changing more frequently
rmeir is offline   Reply With Quote
      07-17-2012, 07:11 AM   #8
Rodion
Drives: X3 (F25)
Probably different here in EU? At least for my diesel, service interval is 2 years / 30 000km, which ever comes first OR when the car OBD informes it's time to service.
Now mine says first service is due 12/2013 OR within 22 000km (12 000km on the clock now).
      07-17-2012, 08:02 AM   #9
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
I too have noticed that the rear brakes indicator shows my rear brakes will be used up before the front brakes.
I have to wonder if the OBC is estimating the wear based on the various driving parameters, i.e. speed, braking force, cornering??
Some of our cars have performance control which uses the rear brakes to assist in vectoring power to the outside wheel while cornering... I am sure this is expediting brake wear.
lbjgh is offline   Canada
      10-04-2012, 06:22 AM   #10
Rodion
Drives: X3 (F25)
Update
Our car has now 16 000km(10 000 miles) on the clock and OBC says:
Service due 18 000km (12 000 miles), or 12/2013 latest. No oil changes done so far.
Front brake pads are estimated to last 110 000km (68 500 miles)
Rear brake pads are estimated to last 80 000km (50 000 miles)
No services so far!
Forum Jump
