      05-29-2012, 09:53 AM   #1
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
MY wifes WHite X3 with painted oem 19's
not the best pic . just put these on 275-40-19 in rear and 245-45-19 in front
[IMG][/IMG]
      05-29-2012, 10:24 AM   #2
C ///M
C ///M's Avatar
Drives: '04 M3 & '07 X3 M-Sport
I like it!
You know, i used to run the same tire sizes, but then I realized why bother run a setup to induce understeer. Next time you get tires, you should put the same size all around, then you can rotate your tires too for extra long life.
I moved to 275/40R19 all the way around. You just need to pickup 2 more rear wheels so the fitment is best. I was running 19x9.5s up front and 19x10s in the rear. When i picked up the new tires, I actually put the same size all around because the fronts wheels were wide enough and I hadn't yet grabbed the extra 2 19x10s.
Anyway, I like the look. You should pick up the BMW Performance black kidney grill if you haven't already to match the look.
      05-30-2012, 08:11 AM   #3
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
yes those are next. these cant be rotated due to different offset and width from front to back
      06-10-2012, 04:30 AM   #4
Blue Bottle
Blue Bottle's Avatar
Drives: X1 x Drive 2.0L D
white cars and black wheels look so cool...
      06-15-2012, 02:45 AM   #5
turbotoy4me
turbotoy4me's Avatar
Drives: 2020 X5 M50i
2015 Porsche Macan ...  [0.00]
2017 BMW i3  [0.00]
2020 BMW  [0.00]
Looks awesome!
      09-06-2012, 08:53 AM   #6
BimmedJosh
Drives: 2008 X3
The contrast of white on black is cool. They look good for being painted. I second the grill rec.
      10-03-2012, 10:27 AM   #7
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
I plastidipped the grill for now which looks good. Also FYI the 275-40-19 and 245-45-19 tires well the transfer case doesnt like that size so I have to switch out to oem tire size
      10-04-2012, 11:29 PM   #8
C ///M
C ///M's Avatar
Can you explain what happens with those sizes? I used to run 245/45R19 front and 275/40R19 rear before I switched to the 275/40's all around. The staggered setup worked great, I just wanted a more balanced setup (less understeer).
      10-05-2012, 08:19 AM   #9
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
well it seems the transfer case makes lots of noises on low speeds . when coming to a stop 20 mph to stop theres a vibration felt through the car . Also when hitting big bumps the transfer case motor kicks on for 15 secs or so and also taking off from stop heavy acceleration I get a big vibration thoughout car also. There is an SIB from BMW stating that wrong offsets, different wheels and tire sizes cause transfer case issues and will gradually trash the it . I put on on stock wheels and tires and all issues were resolved . Do you have any weird vibrations with the tire sizes you have . what wheels do you have and size and width
      10-05-2012, 09:03 AM   #10
C ///M
C ///M's Avatar
That's really weird. The wheels should have no effect, because its the overall tire diameter/circumference that will mess up the transfer case. The difference between those two sizes are within tolerances front to back.
Anyway, I was on 19x9.5 et45 and 19x10 et38 when I ran them. They were smooth as butter. Then I just put the same 275/40's on the 9.5 fronts before picking up 2 extra 10's. All option worked perfectly, so I really don't know what to tell you.
only thing I can think of (and it's a huge stretch) would be that you're rears were worn down very far while your fronts were new (causing enough of a size difference) or the tires had manufacturing defects of some kind...
I can guarantee that the staggered setup had zero problems with my transfer case. And I doubt there was any real difference between our model years that would relate to this issue (mine was a 2007 3.0si).. All that being said, I do like the 275/40R19's all around much better.
      11-08-2012, 03:35 PM   #11
713 tentosix
Drives: 2006 X3,2008 550i,carbon black
The 19's look the part on the X3, now since you've confirmed the 9.5's & 10's fit the front with no issues, i have a question.....? My options are 19x9.5 all around with the 23, 33, or 43 offset. I want a flush look with no suspension rubbing probs, so whats my best bet? We are stock 18 inch,35et. 2006 M sport. I want width w/a mean look
      11-08-2012, 09:47 PM   #12
08msportx3
08msportx3's Avatar
28
Drives: 08 x3
idk on that you will need to research more on the forums
      11-12-2012, 05:46 PM   #13
713 tentosix
are you on 19x10's now all the way around? would really appreciate some knowledge on the offset to run for no issues.....thanks
      01-13-2017, 03:18 AM   #14
nctu127
Drives: toyota
so adorable. goldenslot
      02-11-2017, 06:45 AM   #15
Bilou06
Bilou06's Avatar
Drives: Bmw X3 3.0D Sport
Nice car!!!
      03-02-2018, 10:27 PM   #16
TONLOVE69
Drives: volvo
Beautiful car, white car and black wheels.
สมัคร บาคาร่า
      03-13-2021, 10:30 PM   #17
Reddstars
Drives: 2017 BMW X3
Thumbs up
Looks clean
