XBimmers | BMW X3 Forum > BMW X3 Forums | E83 (2003-2010) > First Generation BMW X3 General Forum » 3.0d 160 Kw Engine Cover Removal / Rear 2 allens Keys
      04-24-2012, 04:44 AM   #1
ozzielad
Drives: X3
Hi all
Thank you for the info on this forum .
I have a 2007 3.0d X3 160 Kw which has a engine cover that has about ( I think ) 8 allens keys screws in it and 2 of which are located under (I think its the pollen filter behind the strut brace) how do you remove remove these last two screws ? do you have to remove the entire pollen filter and if so how do you do that ? are their any detailed instructions to do this ? I have a chip to install and need access under the engine cover I have attached a pic of the engine cover as well.
Cheers to all
ozzielad is offline
      04-25-2012, 06:14 AM   #2
deafwish
Drives: 2006 X3 3.0d
Do you have a proper Torx bit set?
I can't recall exactly where the rear bolts are, but I can easily remove my Aussie spec 3.0d's engine cover...
Where in Oz are you & what chip did you buy?
Daz.
deafwish is offline   Reply With Quote
      04-26-2012, 05:10 AM   #3
ozzielad
Drives: X3
Hi Daz
I am in NSW and got a http://www.ebay.com/itm/300625706864...84.m1439.l2649 I am in NSW
I couldnt justify paying 1500 for one here!!
Does your 3.0 litre look like mine ? same engine cover ? Torx they use allen keys 3/16"..
The back two bolts are under the pollen filter I cant see how to take then out easy. I believe mine has the updated engine cover I was told .. any clues would be appreciated if you know how to take out the pollen filter.
Cheers
ozzielad is offline   Reply With Quote
      04-26-2012, 07:08 AM   #4
deafwish
Ahh - Right you are!
I have 5 Allen head bolts on my engine cover & you can easily see the corrugated intake hose on the driver's side.
Your cover is different to my late 2006 model's!
p.s. No offence - But I think you're mad buying that dodgy looking Ebay chip!
For the love of god - have your car run up on a dyno post fitment to ensure a safe EGT!!!
      04-27-2012, 02:03 AM   #5
ozzielad
Drives: X3
Hi
Yes I may do that I think .. did you know most of the chips are the same and only the cable is different it seems .. this is common with every one ..
Also I believe in OZ anyway the 2006 and 2007 are very different.. The suspension and running gear is different and they went from a 150 kw to a 160 kw engine ..
Thanks for your time.
Cheers
      04-29-2012, 05:52 AM   #6
x3oiler
Drives: X3 3.0 Diesel
+1 on "For the love of god"
Rather than hijack the thread I kicked off another thread on this.
X3 3.0d 2006 update, DVN-E83 GPS with reversing camera, Alpine SPS410 in doors, Earthquake SWS-8X (4ohm) under seat driven by Alpine PXE-650 and Pioneer GM-D9500F amp, Superchip ECU remap.
x3oiler is offline   Reply With Quote
Forum Jump
