XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Motor trend long term review: Throttle lag
      04-16-2012, 04:33 PM   #1
Fryguy29
Drives: 2011 BMW X3 35i
http://www.trucktrend.com/roadtests/...e_8/index.html
Pretty useless if you ask me. They are telling me things I already know.
Fryguy29 is offline   United_States
      04-16-2012, 05:36 PM   #2
Want the thrill
Drives: X3 35i
2011 X3 35i  [4.00]
2 oil changes in 10 months. They are really racking up the miles fast on that thing and it must not be highway miles!
Want the thrill is offline   Reply With Quote
      04-16-2012, 06:24 PM   #3
FX3OK
FX3OK's Avatar
Drives: 2012 X3 28i
Good to know/read... Maybe one day bmw will acknowledge this issue!
FX3OK is offline   Reply With Quote
      04-16-2012, 09:06 PM   #4
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
I wonder in starting in 2nd gear while at the same time bringing the engine up to 1500rpm against the brakes would result in a smooth acceleration?
lbjgh is online now   Canada
      04-16-2012, 10:44 PM   #5
JoeyO
Drives: silver car
Someone should write him and say "Thanks Captain Obvious."
JoeyO is offline   United_States
      04-17-2012, 07:15 AM   #6
n55x3
Drives: n55 x3
Wow, I sure hope BMW acknowledges this throttle lag. It's so obvious and such a smear on an otherwise nearly perfect little SUV. It's ashame really.
Next month we are doing a little BMW sponsored event where we pit the F30 against a lexus, mercedes, and audi. Will be interesting to see if the ZF in the F30 mimics the lag of the X3.
Also, one of my employees showed up yesterday with a 2012 X3 N55 rental. I'm hoping to drive it to lunch one day this wek and see if it's lag is as aweful as my wife's x3.
n55x3 is offline   Reply With Quote
      04-17-2012, 08:59 AM   #7
rchaas
Drives: 2009 Z4 SDrive3.5i
2009 Z4 35i  [0.00]
2011 BMW X3  [0.00]
Recent TSB for the throttle lag acknowledges "faulty DME calibration" and suggests a software update. I had the reprogram done and it seems to have improved the lag significantly.
There was also a TSB for brief rough idle when cold, which I was also experiencing. Same software reprogramming for DME was recommended. Seems to have helped with my cold rough idle as well.
rchaas is offline   United_States
      04-17-2012, 09:30 AM   #8
CaliRubicon
Drives: 2012 BMW X3 35i
Do you have any numbers associated with those tsb's?
CaliRubicon is offline   Reply With Quote
      04-17-2012, 04:58 PM   #9
rchaas
2009 Z4 35i  [0.00]
2011 BMW X3  [0.00]
SI B24 02 12 Delay in Engine Response
SI B24 04 12 Idle Fluctuation after a Cold Engine Start
Hope this helps. I took the printed PDF files with me to the service center and they went ahead and did the reprogramming, but the technician still felt the need to add the comment on the bill that "idle was smooth" (of course it was, it wasn't cold!!).
      04-17-2012, 05:09 PM   #10
roundtree
roundtree's Avatar
Drives: '12 F25 28i SB
2013 BMW 328i  [5.00]
2012 BMW X3  [5.00]
From the looks of the TSBs, this should apply to MY 2011 and 2012. Maybe there's hope yet. Time to call my guy and see when I can get it looked at.
roundtree is offline   United_States
      04-18-2012, 05:40 AM   #11
dudley07726
Drives: 2012 X3
2006 LEXUS SC 430  [0.00]
2012 X3  [0.00]
I have a 2.8 Feb 2012 build and is not included. I have not noticed any throttle lag.
dudley07726 is offline   Reply With Quote
      04-18-2012, 07:02 AM   #12
tank531
Deckhand
tank531's Avatar
Drives: F25 2.0D SE xDrive (Sep 11)
I would say my 2.0D engine F25 has the same experience of throttle delay, although annoying I can drive smoothly around town.
For those F25 owners with VDC or VSS when you select 'sport' mode does the trottle repsonse improve? Is this lag there intentionally to provide an 'improvement' with the technology options? If you switch to 'sport' auto mode does the throttle response improve? (I can try that one myself but I don't have VDC/VSS
tank531 is offline   United Kingdom
      04-18-2012, 07:24 AM   #13
n55x3
Drives: n55 x3
Wow, thanks for sharing rchaas!! This could be huge for our X3. I'm going to look into making an apointment very soon.
      04-18-2012, 06:10 PM   #14
FX3OK
FX3OK's Avatar
Drives: 2012 X3 28i
I have the same month build as u.. 28i and have the lag... Strange
      04-18-2012, 09:14 PM   #15
Nahoa
The throttle is lagging. Nothing to do with the foot, the throttle lags . . . lags behind what?
Nahoa is offline   United_States
      04-18-2012, 09:47 PM   #16
lbjgh
lbjgh's Avatar
Your foot calls for 20% acceleration and the 'car' gives you 15% acceleration.
I'm just glad the brakes don't work the same way.
      04-18-2012, 10:16 PM   #17
Nahoa
If the press isn't giving you enough, press more and remember it for next time. No rocket science here.
      04-18-2012, 10:51 PM   #18
Le Chef
Drives: BMW X3 35i
What's the problem?
I don't get lag - I just nail it. If you pussy around you;re going to get lag. Buy a Precious if you worry about saving gas. Just use the weight of your right foot and get driving that thing!
Le Chef is offline   United_States
      04-18-2012, 11:04 PM   #19
lbjgh
lbjgh's Avatar
hehe, I suppose you are right. Same would hold true if it were the brakes or perhaps the steering.
Now if the radio volume control was not linear I'm sure we'd hear about it.
      04-18-2012, 11:19 PM   #20
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
Unfortunately, the road is not always straight with no traffic.
Sometimes you keep pushing and pushing with "nothing". You start praying the car coming in the next lane is not going to hit you as you try pulling out.
Almost 18,000 miles in 11 months the lag still happens once in a while. In fact for almost a year my wife has been telling me the same thing as the above posts. She drove the car the other day and experienced the lag for the first time. Well the good thing is I have one less "Your Crazy" subject box checked.
Radioactive is offline   United_States
      04-19-2012, 02:12 AM   #21
Bill S
Drives: F25 X3 30d N57 + E60 535d M57
Am a little concerned that this tsb does not seem to cover the N57 engine.
This occasional but annoying lag also occurs on the 3.0d engine - or are BM only concerned with US sales?
Bill S is offline   Reply With Quote
      04-19-2012, 09:21 AM   #22
n55x3
Drives: n55 x3
The comments around 'just press the pedal harder' simply does not apply in our specific situation.
If we press the gas petal the car sits there for maybe a second or a little less before it goes, regardless of the amount of throttle being asked for. If you feather the throttle or floor it the lag is always present. If I floor it (100% throttle), it will sit there for a second or so then go. It will chirp all 4 tires and this isn't very comfortable in every day stop and go traffic (plus on occasion the tires have chirped and the traction control kicks in and then you really have an OH Crap moment as cars approach). This creates dangerous situations when turning into traffic as the delay is not consistant and many times when you are trying to quickly make a turn from a stop it will lag for a second then go and in turn the on-coming traffic gets a little close for comfort.
Forum Jump
