02-11-2012, 08:59 PM | #1 |
Rep 56
Ride quality of the X3
I have a 2012 BMW X3 with the M package and I have recently noticed while driving on certain roads you will feel like a bouncing sensation not thru the steering it feels like the whole car. Does anyone else feel this or could it be something wrong with the car. Run flats? Bent rim? Maybe tire pressure or is the suspension just that sensitive that it just picks up the road defects or not being perfectly smooth.
02-11-2012, 09:42 PM | #2 |
Rep 1,560
Those Pittsburgh roads will kill ya! Grew up there and still visit regularly To answer you question though, I have a 2011 35i and have not felt what you are describing.
02-11-2012, 09:47 PM | #3 |
Rep 1,876
I've come to believe it's just the nature of this particular sport suspension. I thought something was wrong with mine. Had people drive it. Got the head technician to drive it. At the end of it all, I think it's the suspension and one particular stretch of freeway here (that I drive a lot) has a pattern to the pavement that makes it quite noticeable at one particular speed.
To me it felt like a "light chop". A bouncy, vibration feel. Felt like if I let hands off the steering wheel it should vibrate, but it didn't.
02-11-2012, 09:51 PM | #4 |
Rep 128
Drives: 2012 X3 XDrive 35i
Do you mean floaty like a boat or like it was hugging the road so much that you feel every bump? My 35i with DHP does not feel floaty at all, but I do feel road imperfections. The higher centre of gravity also seems to exaggerate this feeling of the chassis moving in different angles. At least from my perspective.
02-11-2012, 10:35 PM | #5 |
Rep 32
I thought I was imagining subtle bouncing. Feels like the tires have a flat spot. I'd feel it leaving work on a relatively smooth road, feel the vibrating, but then it would disappear. Still might be in my head, but sounds like what you're describing. Or could be the stupid RFTs...
02-11-2012, 10:41 PM | #6 |
Rep 1,876
I think I've noticed both flat spots on cold RFTs on smooth roads in the morning and this other thing. The flat spots go away quickly. This other thing is consistent at any temp.
02-11-2012, 11:10 PM | #7 |
Rep 412
The big question is do you have DHP? My wife's truck has DHP and I've not felt what you;re describing in "sport" which is what I drive it in regardless of wheel size or type of tire. I put 18" and winter tires on my wife's truck 3 months ago and have not had that sensation. Even with 19" and a staggered summer tire setup before this wasn't an issue.
02-12-2012, 07:12 AM | #9 |
Rep 56
I have the DHP package as well, not a floating sensation more of a bouncing. I tend to notice it more at higher speeds and certain roads that I drive. I think that it is the suspension being so sensitive to the road surface I will try different modes sport and sport+ and see if that makes a difference my concern was that I hit a pot hole about two weeks ago and wasn't sure if I dinged a rim or not. The rim does not look bent and if it was I think I would feel this sensation all the time and feel it in the steering wheel not the whole car. To give you an example I was driving yesterday with my wife and she asked why am I bouncing? If I looked over at her I could actually see her moving up and down as well as the seat. Went on a different road way and it went away not sure if it was speed or the road leaning towards it being the road.
02-12-2012, 07:50 AM | #10 |
Rep 32
No DHP and I only notice the flat spot sensation for the first few minutes of driving after leaving the parking garage at work. Funny thing is I don't notice it in the morning, although it could be that the local roads are rougher and mask it or my imagination is still asleep :-)
02-13-2012, 09:42 AM | #11 |
Two more till my intervention
9
Rep 144
02-13-2012, 10:21 AM | #12 |
Rep 79
I think bouncing is unfortunately a carryover of some of the previous generation suspension's quality. Bounces and you really feel it in your behind on bad pavement. RFTs make it even worse. Must be jarring if you have to drive on cobblestone paved streets.
02-13-2012, 10:28 AM | #13 |
Rep 2,527
On a basic X3 x28 with 18s I get the bouncing sensation as well. It's probably the combination of both the ride height, stiff suspension, and the harder RFTs. The motions do make it a bit disconcerting, but I don't ride our X3 enough to get used to it.
This is still a whole lot more compliant than the E90 though. Last edited by pokerface; 02-13-2012 at 05:20 PM.. |
02-13-2012, 04:36 PM | #14 |
Rep 3
I just test drove the X3 35 with M package, although I didn't drive it on the highway, I thought the car drove well. I do however have a lot of experience with R/F tires, which I now like a lot (earlier tires were not great) tire pressure is very important, do not over inflate. I am concerned about comfort, how are the sport seats? Would love to hear from an owner.
02-13-2012, 05:04 PM | #16 |
Rep 2,292
I have a 35i with MSport. I love the sport seats, superior to the regular seats.
I have no "bouncing" at speed, and I have put over 4000kms on it in last month, mostly hiway. I have about 13000kms total, and have zero issues with the ride of the vehicle.
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
02-13-2012, 05:40 PM | #17 |
Rep 95
Yes the side bolsters are adjustable. I love the sports seats.
Jim D.
2015 X3 xdrive28d Black Sapphire Metallic/Black Nevada/xLine, Cold Weather, DHP, DA, DA+ w/ACC, Lighting, Premium, NAV, HK Audio, Parking Assistant, Enhanced BT Previous BMWs: 2000 528i, 2003 540i, 2007 335i Sedan, 2009 335i Sedan, 2012 X3 xDrive35i |
02-13-2012, 06:40 PM | #19 | |
Rep 51
I even had my dealer to test my car in case it was something else - He said that the RFT's give this feeling.. It's a shame the car cannot be delivered with non-RFT's. |
09-01-2013, 11:17 AM | #20 | |
DHS
229
Rep 4,043
Drives: 2023 M4, 2020 Land Rover
I was very disappointed with the X3 line as the X1 line.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
09-01-2013, 01:20 PM | #21 | |
Rep 1,560
09-01-2013, 02:49 PM | #22 | |
Nuclear Chief of the Watch
120
Rep 637
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats Canon 70D 500mm, 85mm, 40mm, 24mm Sony QX10 & GoPro Hero 3 |
