XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Break wear indicator
      01-04-2012, 12:47 PM   #1
rd450
Drives: bmw x3
Hey, just put my x3 in for first oil change at 14000 miles. When the dealer scanned the key he said it was also showing rear brake pad replacement required in 700 miles time !
Told him I found this really strange as my last Audi had done 45000 when I sold it and still had the original pads. He said he would ask techs to check it out
Anyone else had this warning coming up on the vehicle diagnostics in idrive ?
rd450 is offline
      01-04-2012, 01:03 PM   #2
Steve30dMSport
Steve30dMSport's Avatar
Drives: 2011 X3 30D M Sport
If it is correct then it is because of the active cruise control. All cars with active cruise control experience accelerated rear brake usage because the rear brakes are used to prevent the vehicle from going over the set speed, such as when traveling down a hill with the cruise on. The rear brakes will be applied to maintain the correct speed instead of gradually creeping over which is the case with non-active cruise control. And 15,000 km's is about right and consistent with other cars such as the VW Passat etc with that feature.
Steve30dMSport is offline   Australia
      01-04-2012, 01:59 PM   #3
n55x3
Drives: n55 x3
These X3s use a break force distribution that really drags the rear brakes. It makes the brakes much more rear biased in easy braking situations. When you hit it hard you'll still send most braking power to the front but in normal driving it seems to rely more on the rear brakes versus the fronts.
n55x3 is offline   Reply With Quote
Forum Jump
