XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Which oil?
      01-03-2012, 06:32 AM   #1
Nahoa
Which oil?
Anyone know what oil the BMW dealerships use in the US? BMW recommends Castrol, so I'm assuming they use that, yes? What weight? Will they use 0w30 on request?
Nahoa is offline   United_States
      01-03-2012, 10:39 AM   #2
n55x3
Drives: n55 x3
FWIW, for our first oil change I ordered the oil change kit from here:
http://www.trademotion.com/partlocat...catalogid=4462
Fast shipping and a reasonable price so I'll probably order from then again in the future when it's time to change the oil again.
n55x3 is offline   Reply With Quote
      01-03-2012, 12:04 PM   #3
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
Drives: E90 330i, E86 Z4 3.0si
You most likely will want to stick with the BMW brand oil at this time. They put tracers in the oil and will be the first thing they check if you have any engine issues. If they don't find the tracers, they'll void your engine warranty.
2006 330i, TSM, Black, Sport, JIC Cross Coil-Overs, UUC Sways, 18" Advan RS, Mich PSS 255/265, Custom Alcantara M-tech steering wheel, VAC pedals, Rogue shifter, M-Tech front, CF emblems, Dinan TB, Intake, exhaust, strut bar, Stoptech BBK, LSD, M3 susp., LUX 5, CF Hood and CSL, Sparco Seats, AA tune, CF Roof
TSM330i is offline   United_States
      01-03-2012, 12:28 PM   #4
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
This looks like it could be a real sticky issue. No pun intented. On page 221 of the manual it states "Only use approved BMW High Performance oil". Then it states you can use up to a quart of another oil. Then it recommends Castrol. Does that mean any Castrol oil or only BMW-Castrol oil? According to the Magnuson-Moss Warranty Act, BMW can only require you to use their oil if it is free under warranty. Since we get free oil changes I guess we are require to use only BMW oil. But does this mean that if we need a quart of oil, the parts department should be require to give it to us free?
Radioactive is offline   United_States
      01-03-2012, 12:45 PM   #5
bren
user
bren's Avatar
Drives: German Camaro
Originally Posted by Radioactive View Post
...does this mean that if we need a quart of oil, the parts department should be require to give it to us free?
A low oil condition should certainly fall under (free) maintenance, no?
bren is offline   Reply With Quote
      01-03-2012, 01:26 PM   #6
jsplayin
Drives: 04 M3, 12 X3
that's really strange that the Castrol 5w30 is not approved but 0w30 is.
2012 X3 35i - DSB/Black
2004 M3 - JB/Cin
jsplayin is offline   United_States
      01-03-2012, 01:42 PM   #7
Radioactive
While out walking the dogs and my after Christmas bloat I was pondering not only global warming, it was 85F yesterday, 81F today, and 85F tomorrow, but this oil question. I'm not a lawyer and I didn't stay at a Holiday Inn, but for what it's worth it, here's my take on it.
1. While under warranty you must only use approved BMW High Performance Oil since they do free oil changes to your car.
2. The "approved" refers to the viscosity.
3. If you must add oil and BMW oil is not available; the oil from the list that Lotus 7 listed above can be used.
4. Of that list, BMW recommends that you buy the Castrol brand.
My guess is that the only difference between the Castrol and the BMW label is a "high performance" tracer that the OP refers too.
If your engines has a problem related to "oil", good luck if you have changed your oil and didn't use BMW oils!
Here the BMW website http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
      01-03-2012, 01:47 PM   #8
jdmass
Drives: 2012 X3 xDrive35i
Absolutely. With my previous BMWs, I've gone into the dealer when any fluids were low and my dealer would refill them. No appointment needed, they just add the fluids at the drive-in area where cars are typically dropped off for service. So you can just pull-in, get topped off, and go.
Jim D.
2012 X3 xdrive35i
Deep Sea Blue/Mojave/Fineline Sienna, Premium, SAP, DHP, Cold Weather I&II, Technology, Premium Audio, BMW Apps
Previous BMWs: 2000 528i, 2003 540i, 2007 335i Sedan, 2009 335i Sedan
jdmass is offline   Reply With Quote
      01-03-2012, 02:07 PM   #9
MattUK
Captain Unsensible
Drives: 2011 X3 3.0D MSport
Thanks for this.. I had purchased service plus with mine and hadnt realised they would also take care of top ups! pays to read what you buy
MattUK is offline   United Kingdom
Forum Jump
