FORUMS
- 5
| XBimmers | BMW X3 Forum » Braking Smoothly |
| 12-30-2011, 09:12 PM | #1 |
Braking Smoothly
I was wondering if anyone else have this minor issue of not braking the x3 smoothly to a complete halt.
When I am coming to a stop, I can never manage to brake the x3 smoothly. There is a slight "jerk" before coming to a complete stop. I never had this issue with braking smoothly on my other cars (Ford, Honda, etc). Just wondering if anyone else experiences this. Is it an issue with the brakes? or transmission? |
| 12-30-2011, 10:24 PM | #2 | |
![]() ![]() Drives: 2011 X3 xDrive 28i Join Date: Mar 2011
| 12-30-2011, 11:41 PM | #3 |
I think it is a common problem in many new BMW cars with the 8-speed automatic transmission and brake energy regeneration. My 2011 535i had the same problem. But you will get used to it and learn how to brake smoothly accordingly. (Hint: gradually reduce your braking force prior to a complete stop.)
| 01-03-2012, 08:54 AM | #4 |
I agree with iwinit that a lot of the jerkiness can be attributed to the transmission. One thing to keep in mind is that the ZF transmission constantly downshifts as your speed decreases. This can attribute to a slight jerky sensation when slowing. The advice about gradually decreasing braking force prior to coming to a stop is helpful too. Definitely takes some getting used to.
While on the brake topic, has anyone noticed the difference in initial brake bite when you lazily move your foot from gas to brake pedal versus when you rapidly move foot from gas to brake? As they described it to us at the PCD experience, if you move your foot quick enough the brakes 'pre-tense' in anticipation for an emergency stop situation, which in my opinion is a very cool feature and works really really well on our X3. The thing is, if you go fast enough from gas to brake, in a non emergency situation you can still trigger this initial aggressive bite and the results can be startling. |
| 01-03-2012, 04:46 PM | #5 |
While on the topic of braking, anybody else feel like the brakes are underwhelming on this car. I feel like they don't have enough bite and I often start braking gradually only to have to add more pressure than I'm used to in order to actually stop. Maybe it's the weight of the car, or just that I'm comparing it to my M3's stock brakes, but I'm still not used to them especially when switching back and forth between cars.
![]() 2012 X3 35i - DSB/Black 2004 M3 - JB/Cin |
| 01-03-2012, 04:51 PM | #6 | |
Captain Unsensible
| 01-03-2012, 08:36 PM | #9 | |
![]() Drives: F25 35i Mineral Silver/Black Join Date: May 2008
| 01-04-2012, 12:43 AM | #10 |
I have similar experiences as Nahoa and believe it's more so the distance one needs to travel when pushing the brake pedal more so then the brakes not being up to the job.
One thing that I really like about the X3 compared to previous cars that I've owned is that so far I haven't experience esp kicking or the anti-lock brakes pumping when braking hard even when raining. |
| 05-16-2013, 04:08 AM | #12 |
a slight "jerk" before coming to a complete stop..... the problem you are experiencing is caused by the unbalance between the engine to the transmission lubrication, and this problem is resulting in the high oil temperature. Your ATF oil temperature must be over 100 degrees (normally the oil temperature is 85 to 100 degrees) I used ATF LUKE G-7 excluded my problem and have received excellent improvement. I shear to you for reference.
| 05-16-2013, 08:00 AM | #13 |
No noticed any issue - the brakes perform fine, more concerned about the car behind not being as quick to stop! Had need for one "quick" stop and it felt very good and under control all the time.
Never had a "performance" car so cant really compare it.
Dont
and ![]() BMW X3 (F25) xDrive20d SE . . Alpine White. . Oyster Leather . . 8 Speed Servotronic. .RFTs. . High Beam Assist. . Electric Seats . . DAB Radio. .USB/Bluetooth |
| Bookmarks |
