FORUMS
- 5
| XBimmers | BMW X3 Forum » Temp msg |
| 11-03-2011, 07:50 AM | #1 |
Temp msg
This morning I received an alert in the spot where you get those triangle vehicle alert messages that said, \"Outside temp 37F\" in large lettering taking up the entire space beneath the regenerative braking graphic.
It beeped, triangle appeared with that msg and the disappeared within a few seconds. Anyone know what that was? Why would it appear and then vanish? The vehicle info screen has no record of the alert. Thanks
2012 X3 35i | Mineral Silver | Oyster | Wave Wood
Packages | Sports | Cold Weather | Dynamic Handling | Premium | Technology | Premium Sound |
| 11-03-2011, 07:54 AM | #3 |
It just a warning that temp is getting to the point where frost or ice can occur. Probably your heated mirrors have been turned on too....
F25 3.0D | M Sport | Black Sapphire | Oyster | Fineline Wave Wood | Heated Front Seats | Panoramic Roof | Matt Aluminium Roof Rails & Window Trim
Sept 2011 |
| 11-03-2011, 08:25 AM | #5 |
Good to know. I was nervous the computer was acting up,
![]() Thanks
| 11-03-2011, 09:12 AM | #6 |
X3 Owner/Driver
Drives: 2011 X3 Xdrive35i Join Date: Dec 2007
it means winter is almost here, time to crank the seat heaters.
my e91 did it as well - my VW Passat before that did it as well, but the temperature was 39 not 37 on that....
2011 X3 XDrive35i F25 l Deep Sea Blue l Mojave Leather l Alum Brush Trim l Packages = Sport, DHP, Premium, Nav/Technology, Cold Weather, Convenience | Premuim Audio + Sirius
2008 328XI E91 Sportwagon l Sparkling Graphite l Gray Dakota Leather l Dark Burl Walnut | Steptronic 6SP l Premium l Heated Seats [traded in for the X3 above] |
| 11-03-2011, 12:24 PM | #8 |
Yep...page 62 in the OM....
"External temperature warning If the display drops to 37 ℉/3 ℃, a signal sounds and a warning lamp lights up. There is the increased danger of ice. Ice on roads Even at temperatures above +37 ℉/+3 ℃, there can be a risk of ice on roads."
2011 Z4 sDrive 30i; Space Grey, Coral Red Kansas, 6MT; Fully optioned & 2011 28i X3 Loaded
| 11-03-2011, 03:28 PM | #9 |
![]() ![]() ![]() Drives: 2009 E70 & 2011 F25 Join Date: Jun 2005
... was wondering when we'd see the first of these. Every year, just like clockwork!At 37 degrees F, water freezes just enough to have a layer of liquid at the top (much more slippery than just solid ice). Also, with the condensation that occurs in fall, there is a real potential for "black ice". That is what the warning is for. Also, to remind you that you should be wearing your sweater.
![]() I think it is bad luck to be superstitious |
| 11-03-2011, 11:03 PM | #11 |
Rider and driver
Drives: 2011 Black X35i Rides: K1300GT Join Date: Feb 2011
I get the same warning on the K1300GT. Snowflake in the display.
2011 X3 35i
Black Saphire - Nevada Mojave - Y Spoke 308 - Premium Sound - Navigation I work for Keyser Söze |
| 11-04-2011, 05:35 AM | #12 | |
![]() Drives: F25 35i Mineral Silver/Black Join Date: May 2008
| 11-04-2011, 06:00 AM | #13 | |
Live for today tomorrow never comes
Live for now, life is too short.
2013 M5 LCI on Order for October. |
| 11-04-2011, 09:49 AM | #15 | |
| 11-04-2011, 10:11 AM | #16 |
Air temp vs road temp? 3C air temp is generally thought of as being the point at which you should think about ice. Also you might be at 3C then drive down a dip where it's cooler.
Sept 2011 |
| 11-06-2011, 03:17 AM | #17 | |
37 deg. F. (2.7 Deg. C.) seems to be the informally agreed upon value that every manufacturer uses. Our old, 1999 A4 chimed at 37 F. as does our 2005 Subaru Legacy and almost every new car that has an outside temp. readout. Finally, It's a warning. Most drivers would rather have a warning before something potentially dangerous was going to possibly happen, rather than later. ![]() |
| 11-06-2011, 06:53 PM | #19 |
How true....Philo of Byzantium, an ancient Greek engineer, made crude thermometers, or "thermoscopes" in the second century B.C. In 1592, Italian mathematician and astronomer Galileo invented the first “modern thermometer”. Both men were far ahead of their times fully anticipating the need for automobile ice warning systems. Neither one collects any royalties from the use of their inventions. Very sad.
| 11-10-2011, 11:35 AM | #20 | |
Drives: Ex's: 83 320i 85 325e 02 325e Join Date: Nov 2011
![]() 20 years or 2000, its just decimal points. |
| 11-10-2011, 03:42 PM | #21 | |
Funny thing about water is that it is not purely a liquid at 33 degrees and purely a solid at 32 degrees. Freezing is a process of crystalization and slowing of the molecules, which happens somewhat gradually. There isn't a "head molecule" with a thermometer watching for 32 and hollering "okay, everybody... STOP!" The most slippery ice is the kind that is "warm" and has a very thin layer of liquid water on top. Ask the manager of your local ice rink. 37 degrees is the point at which there is sufficient crystalization of the water to form a solid with a very thin liquid layer on top.
| 11-10-2011, 03:49 PM | #22 |
Just brilliant.....
2012 135i E82 MSport DCT LeMans Blue
Previous BMWs - 2011 X3 35i MSport VR (sold), 2009 M3 Sedan AW (sold), 2008 535xi MSport AW (sold), 2007 328xiT Barbera (sold), plus 11 others in the 70s & 80s. |
| Bookmarks |
