XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - 2016) > Second Generation BMW X3 General Forum » Rattles & Clunks
      05-07-2012, 10:34 AM   #23
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
Originally Posted by X3andZ4owner
I hear and feel a clunk from the front suspension when I drive over a small hump with great angle on the frontwheels. It sounds like something is loose in the steeringcolumn or the suspension..
Car is in the shop for the seventh time for this issue. No end in sight.
      05-07-2012, 11:16 AM   #24
X3andZ4owner
Drives: X3 Z4 630iC
Jeezz... good we have 5 years warranty on the car here in Norway..
Keep us up to date on what they find..
      08-20-2012, 01:09 PM   #25
jxterma
Drives: 2012 x3 35i
Originally Posted by ILuvMy335i View Post
I managed to fix the rear rattle over bumps. It drove me insane to the point that I asked a friend to sit in the trunk and identify the source...it was the tailgate! The noise was tin / metal like knocking every time I drove over a hard enough bump. Especially loud when there was a bit of body flex. I tried everything prior to the fix below including stripping and removing tools, covers etc. The fix is as follows:
If you open the tailgate you will notice that there are 2 black rubber stoppers on the body just above the tail lights. These stoppers are adjustable. I've noticed that if the differential adjustment is such that one side of the tailgate is slightly higher than the other, that the weight of the tailgate causes the clunk when the body moves in just the right way. I experiement by adjusting the stoppers a few times and voila - after 3 or 4 times, noise was gone.
The only noise - now have is a light bizz/ rattle when I take off and sometimes at speed. Seems to be centre speaker or somewhere around that area.
Thanks for the info. I noticed height difference between the two rubber stoppers, and the higher one has obvious mark probably because the strut metal knot on that side always presses it first. But could you tell me how to adjust it?
      08-20-2012, 02:45 PM   #26
clivem2
Drives: F25 35D MSport
Sounds like the same as I have. From the driver's seat it seems to come from the centre speaker. From the passenger seat it seems to come from the driver's side A-pillar. Moving my head to the centre when it happens has it shift to the A-pillar too. Somewhat confusing and hard to track down!
F25 35D | MSport | Space Grey | Saddle | Burr Walnut | VDC | Reversing Camera | Xenons | Panoramic Roof | Matt Aluminium Roof Rails & Window Trim
Dec 2014
      08-21-2012, 02:20 AM   #27
ReturnZero
Drives: 2013 X3 35i M-Sport
Oh man, I have that terrible rear clunk too. Good to hear that it can be fixed.
Any more details on how to adjust the rear tailgate so it's quiet?
      08-23-2012, 01:20 AM   #28
jxterma
Drives: 2012 x3 35i
I finally managed to adjust the bump-stops to the right height. Now the problem is gone. Let's see if I can explain this without pictures.
You need to remove the two panels at the back interior of the trunk(now you can see the wires of taillights). Reach with your hands from inside of the trunk. It is a bit hard for the left side, and you need to pull down the liner a bit and reach further in. Then you can feel the adjustment screws for the rubber bump-stops. The screws have plastic torx covers and they are removable. If you have driver bit with right size(T50) you can use that to adjust directly without removing anything, but the torx sockets are very shallow. I don't have a torx bit that can fit, so I take off those plastic covers(They are mounted by two tiny clipps to the adjustment screws, so prepare for some damage on your finger nails). Also be extra careful not to drop them. Then the torx drivers heads are exposed and I used a hex socket wrench to turn them, and you can see the rubber bump-stops from outside turning with them.
I had to try 2/3 times to completely get rid of the noise. I may not have necessarily set the stops the same height relative to the car body as the body on both sides may not be perfectly leveled to begin with, so I may have one stop slightly higher than the other. I'm happy with that as long as the tailgate stops clunking when car leans over to either side.
Hope that is clear enough with my limited English.
      08-23-2012, 09:04 AM   #29
Mingstar88
Drives: BMW X3 35i
post pics please
      08-24-2012, 08:39 AM   #30
pantong
Drives: 2013 X3
I'm having the same problem, please post some pictures. Thank you!!!
      09-13-2012, 11:10 PM   #31
flash3
Drives: X3 28i
Please post pics. The rattling is driving me crwzy
      09-15-2012, 11:10 PM   #32
flash3
Drives: X3 28i
Can someone who has experienced such issues and found a fix please post pics of how to solve the rattle noise that comes from the trunk area? It's driving me nuts!
      09-15-2012, 11:16 PM   #33
flash3
Drives: X3 28i
Please post pics or add'l details. Sounds like my issue
      09-16-2012, 12:26 AM   #34
Mingstar88
Drives: BMW X3 35i
BUMP!!!!!!
      09-16-2012, 07:07 PM   #35
flash3
Drives: X3 28i
BUMP!!!!!!
Anyone else?
      09-18-2012, 08:51 AM   #36
pantong
Drives: 2013 X3
Check out this post, it might help you:
http://x3.xbimmers.com/forums/showthread.php?t=687509
      09-18-2012, 11:05 PM   #37
flash3
Drives: X3 28i
That link wasn't much help. I still have the noise!!! :/
      09-19-2012, 12:01 AM   #38
cj168
Drives: 2013 X3 M Sport
You need to remove the two panels at the back interior of the trunk(now you can see the wires of taillights). Reach with your hands from inside of the trunk. It is a bit hard for the left side, and you need to pull down the liner a bit and reach further in. Then you can feel the adjustment screws for the rubber bump-stops. The screws have plastic torx covers and they are removable. If you have driver bit with right size(T50) you can use that to adjust directly without removing anything, but the torx sockets are very shallow. I don't have a torx bit that can fit, so I take off those plastic covers(They are mounted by two tiny clipps to the adjustment screws, so prepare for some damage on your finger nails). Also be extra careful not to drop them. Then the torx drivers heads are exposed and I used a hex socket wrench to turn them, and you can see the rubber bump-stops from outside turning with them...
Thank you for the info. I'll ping my dealer as part of upcoming service visit then.
      09-20-2012, 07:50 AM   #39
flash3
Drives: X3 28i
^ can someone include pics of that fix? I wanna try it before going to bmw
      10-22-2012, 01:26 AM   #40
biglare
Bulldog
biglare's Avatar
Drives: BMW & Porsche
My wife has a 2012 X3 3.5is and thanks for the tips in this thread fellas!
We had the rattling in the tailgate area and it seems that the little stops on both sides of the tailgate needed to be adjusted to make the tailgate tighter and more snug when closed. This was a 2 minute fix and the rattle is now GONE! Thank you to all!
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS
      10-23-2012, 12:53 PM   #41
gareth12468
Drives: 2011 X3 xDrive 28i
2011 BMW X3  [0.00]
I've tried that..... It didn't help.....
      10-23-2012, 12:54 PM   #42
gareth12468
2011 BMW X3  [0.00]
Would you mind showing some pics please?
      10-23-2012, 12:55 PM   #43
gareth12468
2011 BMW X3  [0.00]
I still have the noise too..... Service guys keep saying they cannot reproduce the noise.....
      10-23-2012, 02:27 PM   #44
biglare
Bulldog
biglare's Avatar
Yes, please see the red arrows in picture below that shows the black plastic stoppers that needed to be adjusted. Just give them a half turn (counter clockwise) and check to see if tailgate is more secure. Only a half turn has solved our tailgate rattle issues!
*Note: the picture is not of my X3, but the same parts are on the X3.
I hope this helps for your tailgate rattle issue as it helped me!
GTS
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
