XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » reversing sensors prob?
      10-24-2011, 02:57 PM   #1
cooldude00
Drives: x3 2.0d
hi... i've got the reversing sensors with camera (not the top down) and am wondering if i've got a prob... when the sensors are engaged and i'm moving fwd... i can see the sensors moving from green to yellow to red but the beeping doesn't come on until the yellow to red? is this normal?
the sensors seem to be more sensitive reversing...
it's here!!!
cooldude00 is offline
      10-24-2011, 04:49 PM   #2
acgator
Drives: 2011 X3
Mine does the same thing... and I've often wondered why. I'm guessing it's by design since you can naturally see more of what's in front of you rather than behind you? But it does seem strange that you don't hear an audible beep until you are within a foot of the front bumper. I would actually prefer it staying consistent with the rear so I can judge distance just by listening rather than having to shift my eyes to the screen! Anyone have audible beeps starting during the green zone in the front?!?
acgator is offline   United_States
      01-01-2012, 12:51 PM   #3
cooldude00
Drives: x3 2.0d
going from bad to worse now, past wk or so, once i put the gear into reverse, a pdc error comes on....get the camera but not much else, no sensors.. seems to come and go...
guess i better take it to the dealers...
it's here!!!
cooldude00 is offline   Reply With Quote
      01-01-2012, 12:59 PM   #4
acgator
Drives: 2011 X3
Yikes! I'll be interested to hear how it behaves after they fix it! Still haven't quite figured out what "normal" should be...
      01-01-2012, 04:27 PM   #5
Le Chef
Drives: BMW X3 35i
Have you cleaned the sensors? If not start there first.
Le Chef is offline   United_States
      01-01-2012, 04:29 PM   #6
cooldude00
Drives: x3 2.0d
just cleaned the car recently...and no signs of dirt on the sensors..
it's here!!!
      01-01-2012, 04:37 PM   #7
LEDZEP
LEDZEP's Avatar
Drives: 2009 E70 & 2011 F25
You should have beeping as soon as the sensors detect something. As you get closer, the beeping becomes more rapid. You should have this checked by your dealer.
I think it is bad luck to be superstitious
LEDZEP is offline   Reply With Quote
      01-04-2012, 09:33 AM   #8
cooldude00
Drives: x3 2.0d
just heard back from the dealer - looks like they are changing the sensors... hopefully this will solve the probs
it's here!!!
      01-04-2012, 09:40 AM   #9
Ural
Ural's Avatar
Drives: 2011 X3 20d
By me the sensors usually respond delayed , that's why I always have to do the parking maneuvers slower than I am used to. It is safer though in every aspect to do that slowly, but still I don't get it . Even $100 worth aftermarket sensors are more responsive.
Ural is offline   Reply With Quote
      01-05-2012, 03:08 PM   #10
cooldude00
Drives: x3 2.0d
got the car back today and noticed that the passenger door mirror tilts down when reversing? it never did that before! have i found another fault with the car?
it's here!!!
      01-05-2012, 03:18 PM   #11
bren
user
bren's Avatar
Drives: German Camaro
So, pretty much nobody reads the manual around here huh?
Flip the mirror switch (by the adjuster) to the pass. side.
bren is offline   Reply With Quote
      01-05-2012, 07:31 PM   #12
acgator
Drives: 2011 X3
So do your sensors still work the same way they did in your first post (i.e. not beeping until the front goes from yellow to red)? Or do they now start beeping in the green zone (in front)?
      01-06-2012, 04:58 AM   #13
cooldude00
Drives: x3 2.0d
still the same as before, dealer is saying that it's set up this way as visibility is better up front... not sure i follow but without another x3 to test, hard to say.... not had much probs with it so will see how i get on... 3 yr warranty anyways...
it's here!!!
Forum Jump
