XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Tow Eyelet... just one?
      10-23-2011, 12:57 PM   #1
GenX3
Drives: 2012 X3 35i
I've had a couple BMW's before the x3 and each of them has only come with 1 tow eyelet... and the same for the x3. The pouch looks like it is supposed to hold two, but only one in the bag... Anyone else get just one, or better yet, anyone actually get two?
2012 X3 35i | Space Gray | Sand Beige | Sienna
Packages | M-Sport | Cold I & II | Tech | Premium | Sound | BMW Apps, HUD, Net
GenX3 is offline
      10-23-2011, 02:24 PM   #2
married w/X3
1st time BMW owner
married w/X3's Avatar
Drives: 2011 Space Grey X3 28i
Only one for me as well.
married w/X3 is offline   United_States
      10-23-2011, 02:31 PM   #3
Bustofa
Drives: F25 X3 XDrive20D SE
Why would more than one be needed?
Bustofa is offline   United Kingdom
      10-23-2011, 02:52 PM   #4
married w/X3
1st time BMW owner
Asymmetry?
      10-23-2011, 05:17 PM   #5
LEDZEP
LEDZEP's Avatar
Drives: 2009 E70 & 2011 F25
They are actually not intended for towing, once the vehicle is sold to you. Those are there for towing them during manufacturing and delivery, particularly if shipped over the ocean. Most flatbed operators will hook on elsewhere.
I think it is bad luck to be superstitious
LEDZEP is offline   Reply With Quote
      10-23-2011, 10:25 PM   #6
Lotus7
Drives: xxxx
BMW recommends that only the tow fitting is used to tow the vehicle on to a flat bed, or if the X3 is used to tow another vehicle. They do not recommend connecting to any other part of the car.
In fact, there are no other parts of the car visible (to connect to) because of the full bottom cover except the lower suspension control arms. Towing the car with a strap attached to a control arm will almost certainly cause serious damage., and should be avoided unless it is a dire emergency. If an X3 must be towed, it should be on a flat bed ONLY. Towing with only two wheels elevated and two on the road will cause serious damage.
All X3's come with (1) tow eye-bolt. It is of a different size (longer and larger-diameter - coarser thread) than has been used on previous BMW's. The "new" X3 tow eye-bolt uses a tapered seat as opposed to the flat seat of the older version. It should be fully seated (fairly tight) before any use.
The widely available BMW, "race-type" hinged tow rings will not fit.
Lotus7 is offline   United_States
      10-24-2011, 07:16 AM   #7
LEDZEP
LEDZEP's Avatar
Now that I've been under the car, I would agree.
      10-24-2011, 07:45 PM   #8
GenX3
Drives: 2012 X3 35i
Thanks
Yeah, that's kind of what I figured... but there's a part of me that likes things symmetrical even if pulling it onto a flatbed. But I can also see where it wouldn't matter given such a small distance.
The other symmetrical part of me says, "why create a pouch that clearly is made for two eye-bolts"?
Meh...
GenX3 is offline   Reply With Quote
      10-24-2011, 11:51 PM   #9
Lotus7
Drives: xxxx
Meh...
So you can purchase a second one from BMW to use in the (2) rear sockets.
(BMW p/n 72157184971 "Towing Hinge" US$ 23.87 each)
I'll answer your question with another: Why does the English translation (published) become "Towing Hinge"?
Forum Jump
