FORUMS
- 5
| XBimmers | BMW X3 Forum » It arrived! |
| 10-12-2011, 01:45 PM | #89 | |
X3 Owner/Driver
Drives: 2011 X3 Xdrive35i Join Date: Dec 2007
So... your BMW Dealer should tell you what your build week is - you are on the east coast so there is no reason you won't be driving your new X3 within a week or so after. I ordered 8/13 for a 1st week sept build slot - delivered to the dealer 9/8 or 9/9 I took delivery 9/13.
2011 X3 XDrive35i F25 l Deep Sea Blue l Mojave Leather l Alum Brush Trim l Packages = Sport, DHP, Premium, Nav/Technology, Cold Weather, Convenience | Premuim Audio + Sirius
2008 328XI E91 Sportwagon l Sparkling Graphite l Gray Dakota Leather l Dark Burl Walnut | Steptronic 6SP l Premium l Heated Seats [traded in for the X3 above] |
| 10-12-2011, 04:21 PM | #90 |
Cool, thank you sir.
My X3 is scheduled for build week 42 - meaning the week of 10/16. I'm just antsy because I have to turn in my 335 no later than 10/28, and I don't want to extend my lease any longer. |
| 10-12-2011, 04:24 PM | #91 | |
| 10-12-2011, 05:58 PM | #92 | |
![]() Good luck with yours. Don't forget to post photos!
2012 X3 35i | Mineral Silver | Oyster | Wave Wood
Packages | Sports | Cold Weather | Dynamic Handling | Premium | Technology | Premium Sound |
| 10-13-2011, 01:56 AM | #93 | |
I'm using it for a couple of months, the cool thing is that it allowes you to check your milage compaired to other drives with same engin. btw, Great looking X3 Dukat, I'm really jealous of the piano finish pieces, I hope to retro fit these in mine too ![]() |
| 10-13-2011, 04:58 PM | #94 |
Did my first commute today. 70 miles round-trip. 26.5 average mpg for the commute.
- 200 miles on the car. - Several spots in each direction had heavy traffic (15% of the time), otherwise 65mph. - Very light on the pedal the entire time. It was difficult being that light on the pedal. ![]()
| 10-14-2011, 03:06 AM | #95 | |
Live for today tomorrow never comes
Not bad for a petrol, the diesel would have you 40+ though.
Live for now, life is too short.
2013 M5 LCI on Order for October. |
| 10-14-2011, 03:48 AM | #96 |
At 65mph and driving like a nun I got 43mpg (UK). My E93 335i would do something like the 31.8mpg cruising at 80mph. The F25 is just 60kg heavier but a lot less slippery.
F25 3.0D | M Sport | Black Sapphire | Oyster | Fineline Wave Wood | Heated Front Seats | Panoramic Roof | Matt Aluminium Roof Rails & Window Trim
Sept 2011 |
| 10-14-2011, 07:46 AM | #97 |
First major rainstorm last night. No visible water intrusion anywhere. While washing it with the hose a few days ago I saw condensation inside one of the fog lights but no water after the storm.
I've had it 6 days, starting to get the feel of the handling/engine response. Manual shifting is amazing. The gear changes happen so much faster than my previous car which had a noticeable lag between issuing the shift and it happening. I do wish they'd update the software and remove the throttle lag in normal mode. It's annoying after driving in sports+ and not having that lag when you first press the pedal going back to normal mode. Otherwise I'm very impressed with everything.
Packages | Sports | Cold Weather | Dynamic Handling | Premium | Technology | Premium Sound Last edited by Dukat; 10-14-2011 at 07:53 AM. |
| 10-14-2011, 08:33 AM | #98 |
Dukat, thanks, glad for you! At the same time I still don't know (and probably no way to tell yet, until we have more people posting comments about their 2012 X3 experiences) whether the BMW fixed it for all 2012 X3s, or is that again a gamble like with the pre-2012 model (where a number of people reported the noise problem, but an almost equal number said they didn't have it...). In a separate thread (see October 10 one from Ural) people said that BMW was only now (potentially) starting to realize the noise issue... So probably this topic will continue on the forum :-)
| 10-14-2011, 09:31 AM | #99 | |
I haven't noticed any rpm fluctuations on start-up idle in the last week, so unless it's temperature dependent (only happens in very cold temps which we haven't had yet) I think that has been addressed. Someone mentioned that BMW is about to release a software update to address this so I'm assuming the 2012's include this update. My biggest concern was getting flooding or having the window/sunroof controllers fail which have been reported a lot. So far so good. The forums also mentioned the car sounding louder than it should due to missing or improperly installed plugs in the torque converter. No issues there. The car runs a little on the louder side for the first minute and then quiets down a lot. The exhaust system has 2 paths for exhaust to take. The direct path is louder. I'm assuming it is going direct during start-up and once the system warms up it switches to the quieter path, switching back to direct only under heavy throttle. I still haven't detected any excess wind noise. A little wind noise at high speeds that I think is coming from the roof rails, otherwise no problems. Initially the doors required a lot of pressure to shut. The gaskets/seals have been loosening up. The front doors now shut without requiring much force. The left rear door has improved while the right remains tight. If anyone else gets theirs and thinks the doors need too much force to shut, give it several weeks, seems to get better on it's own. My current issues/wishes are: - Improved/smoother throttle response in normal mode - Some rattles. I think most of the rattles are the window shade & slide-out cargo cover. The only one I can't identify is coming from the sunroof control section in the headliner. I plan to apply another layer of sealant when the weather improves. Two more layers should provide the depth/gloss I'm looking for. Detailing Supplies General Supplies - Microfiber cloths (for buffing) - Foam applicator pads (Blue & White) (for applying polish/sealants) - Waffle Weave cloth (for drying) - Wheel brush - Tire gel applicator Wash - Chemical Guys Citrus Wash (For initial wash to remove oils/contaminants - Meguiars Gold Class Car Wash Shampoo & Conditioner (General washing) Tires - Optimum Opti-Bond Tire Gel (Flat black, no high gloss) Wheels - Optimum Opti-Seal (Sealant to make it easier to clean brake dust) Body - Klasse All In One (AIO) (Light chemical polish/seal) - Klasse High Gloss Sealant Glaze (HGSG) (3 layers, 24 hour cure time between each coat) - Optimum Opti-Seal (Used on black body panels) - Wolfgang Deep Gloss Spritz Sealant (2 final coats of sealant. Probably won't do much as the Klasse sealant has been applied, but I was anxious to try it out to see the difference in gloss/depth over other products. I think Klasse will last longer but Wolfgang is very easy to apply/remove and leaves a slicker finish) - Collinite Fleet Wax (Final coat after the sealants) Windows - Klasse All In One (AIO) (To remove water spots & light sealing) - Optimum Opti-Seal (2nd layer of seal) - RainX (Works great but doesn't last long) Leather Care - Leatherique Pristine Clean - Leather agitation brush Dash - Sonax Dashboard Cleaner Carpeting - 303 Fabric Guard Quick Detailer - Optimum No-Rinse
Packages | Sports | Cold Weather | Dynamic Handling | Premium | Technology | Premium Sound Last edited by Dukat; 10-16-2011 at 01:28 PM. |
| 10-14-2011, 10:34 AM | #100 |
It's good to hear you haven't had any wind or water issues so far. I am picking up my 2012 X3 in about two more weeks at the PDC. I will have about 1000 miles on it by the time I get it home so I should have a good feel for the car and any wind noise or rattles.
| 10-14-2011, 10:38 AM | #101 |
![]() Drives: X3 35i Join Date: Mar 2011
Dukat, run your AC right when you start up the car to see if you RPM's bounce. Try it a couple different times during the course of the day when you start the car. This seems to be one of the biggest triggers for the "bouncing RPM" issue.
| 10-14-2011, 11:55 AM | #102 |
Wow, that's quite the drive for PDC. Best of luck!
| 10-14-2011, 04:44 PM | #103 |
Tried it twice today. So far so good, no crazy rpm revs!
| 10-14-2011, 07:38 PM | #104 |
X3 Owner/Driver
I hit 1 month yesterday so far the only real issue is the occasional RPM revs but its not a big deal, i'll wait for the fix. I will try turning ac on and off see if it matters.
I drove my X3 home in a torrential downpour rain yesterday had about a 25 mile highway drive and the X3 held its own no problems at the speed limit. Really well mannered in heavy rain. I do have some minor wind noise at high speeds, but its barely noticeable and not of concern to me - i think its just the mirrors. definitely no leak w/ all the rain we've had. one last thing, forget washing the car myself or going to the dealer or car wash, i'm just going to Dukat's house to use his supply of cleaning and sealants, etc ![]()
| 10-14-2011, 08:23 PM | #105 |
haha. I'm with you. My new mantra, "If it's good enough for Dukat, it's good enough for me."
2012 X3 35i: Alpine White | Leather Nevada Mojave | Fineline Wave Wood Trim
Cold Weather Pkg | Premium Sound Pkg | Sport Activity Pkg | Technology Pkg | Premium Pkg |
| 10-14-2011, 09:26 PM | #106 |
| 10-14-2011, 10:26 PM | #108 | |
![]() Congrats on your 1 month anniversary. Glad you haven't had any issues.
| 10-14-2011, 10:30 PM | #109 |
X3 Owner/Driver
one little thing in the rain last night - maybe it was just raining so hard it didn't matter, but i wish the front wipers, on their top setting, were faster. i kept hitting the lever up thinking there should be 1 setting faster. maybe it was just me - i wish i could compare to my 328... hmmm, a coworker has a e90 328i stickshift maybe i can compare to his next week.
| 10-16-2011, 12:30 PM | #110 |
Is there a button in the cockpit to pop-open the gas cap? The manual shows you press the back of the lid to pop it open, but gas station attendants are used to the driver pressing a button to pop it open. They all stand around or knock on the window telling me to open it and I have to explain, "Press the back of the lid" every time.
| Bookmarks |
