XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » dimensions and specs of the factory wheels?
      10-06-2011, 11:07 AM   #1
XenaBimmer
///M equipped
XenaBimmer's Avatar
Drives: '11 X3 xdrive28i, '12 128iconv
Anyone know where I could locate the specs of the factory wheels (width, offset, center bore, bolt pattern)? I have the 18" M sport wheels
Thanks!
2011 BMW X3 xDrive28i--Space Gray Metallic/Nevada Chestnut, ///M Sport Package, Premium & Conv. Packages, Navigation, tinted windows, 20" ///M6 style wheels
2012 BMW 128i convertible--Crimson Red/Coral Red, Premium and Conv. Packages, tinted windows, LED ae, shorty antenna
2011 Porsche Cayman S
XenaBimmer is offline   United_States
      10-06-2011, 11:48 AM   #2
Lotus7
Drives: xxxx
POST DELETED
Lotus7 is offline   United_States
      10-06-2011, 12:53 PM   #3
XenaBimmer
///M equipped
XenaBimmer's Avatar
Originally Posted by Lotus7 View Post
All X3 wheels use a 5X120 mm B.C. and a 72.5mm centerbore. They are borecentric mounted wheels and need the correct centerbore diameter. All (F25) X3s use 14X1.25mm bolts (unlike the F83 chassis that uses 14X1.5mm bolts).
Width and offset vary with the model:
M Double Spoke Type 369 Staggered
8.5X19 ET=38mm
9.5X19 ET = 48 mm
Star Spoke Type 368
8X18 ET = 43mm
Double Spoke Type 309
8.5X19 ET= 38mm
“Y” Spoke Type 308
8X18 ET=43mm
“V”spoke Type 307
8X18 ET=43mm
Thank you for the info! As long as the centerbore is atleast 72.5mm the wheel would work correct? (with the use of hubcentric rings)
Do you know where to locate the width and offset for the 28i 18" M sport wheels?
I'm looking at a 20" set of wheels that should mount up OK, however, they are offered in 8.5" and 9.5" widths w/ +35mm offset, so I'm trying to decide what option to go for (one width all around or staggered). I wouldn't mind the wheels moving further outward then the 28i M sport has from the factory, but I don't want to much offset where rubbing would be an issue
      10-06-2011, 01:55 PM   #4
XenaBimmer
///M equipped
XenaBimmer's Avatar
Thanks, I'm looking at a set from **********s, and they said the factory lugs will work. They didn't mention hubcentric rings, but I'm going to make sure on that when I order. I'll probably go with the 8.5" width all around, because I believe the 18" M sport wheels I have are either 8 or 8.5 wide w/ a +35 offset
Take a look at the TireRack selection of 20 inch wheels. They list what will work as far as offsets that will clear. The inner fender clearance, especially at the front appears to be the limiting factor. Don't think 9.5's will fit at the front.
You do need hub centering rings if the wheel bore is more than 72.5. Some dealers like TireRack will supply them automatically, while some will leave it up to you to find. Also, wheel mounting area thicknesses vary. The bolt length is critical. You must have at least 9.5 turns of lug bolt engagement. If the hub is thicker than stock, the OEM 23 to 25 mm bolts will be too short. Reputable dealers will know this, but not all dealers selling wheels are reputable.
Bolts are available in 25, 30, 35 and 40 mm lengths. The stock wheels (and most, but not all aftermarket wheels) use conical taper lug bolts. Some aftermarket wheels use spherical taper bolts. It's very important to have the bolts match the wheels, both in length and seat taper.
      10-06-2011, 02:10 PM   #5
XenaBimmer
///M equipped
XenaBimmer's Avatar
Don't have the width spec. for the 18 inch M-Sport wheels. However if they're 8 inches the offset is probably 43mm and if they're 8.5 inches it's probably 38 mm to match all the other 18 inch (F25) wheels.
Gotcha thanks
Tirerack shows some 20" wheels for the F25 w/ 8.5" widths and +35 offset, so that's what I'm going to go with (tire size 245/40-20)
      10-06-2011, 03:05 PM   #6
johnbmw6
Live for today tomorrow never comes
johnbmw6's Avatar
Drives: 2014 LCI M5 coming October
My winter wheels are 8.5"*18" with ET35 all round fit perfect.
Live for now, life is too short.
2013 M5 LCI on Order for October.
johnbmw6 is offline   United Kingdom
      10-06-2011, 03:35 PM   #7
Looker.
Drives: 2011 X3
Gotcha thanks
XenaBimmer, I think the staggered setup should work without any rubbing for the M6 replica. for the official 20" BMW M Double spoke 310 wheels, the setup is 8.5 for the front with +38 offset and 10 for the rear with +51 as I found this information for Realoem.com .
I am also looking at after market wheels for my 35i M sport and very interested in the M6 replica from **********. However, it is almost winter in Canada now and there is no reason for me to get it this year.
I agree with you to use higher profile tires which will be my choice as well.~ lol
If you will place an order and have the M6 replica mounted on your M sport X3, please share some photos and I believe it will look awesome.
Thanks.
Looker. is offline   Reply With Quote
      10-06-2011, 03:39 PM   #8
XenaBimmer
///M equipped
XenaBimmer's Avatar
Thanks.
Thanks for that info. If the 310 wheels have 10" rears w/ +51 offset, how far out would the 9.5" +35 offset sit compared?
      01-02-2012, 09:26 AM   #9
renderfarmer
Drives: 2012 X3 xDrive35i M
0.5" difference in width = -12.7mm
Offset difference = +16mm
If I'm not mistaken, the 9.5" wheel would sit 3.3mm further out than the 310.
renderfarmer is offline   United_States
Forum Jump
