FORUMS
- 5
| XBimmers | BMW X3 Forum » Wind Noise and Traffic Noise |
| 11-16-2011, 03:57 AM | #67 | |
First time I brought mine to the dealer for the wind noise, they made me drive their test car too, and that one also had the same noise from 50 mph, only a little less. However I am not accepting that it is normal . At this point the TSB on the mirror gaskets shows that neither is BMW . It may be the gaskets or seals or something else or all of them , I will continue pursuing. Mine will be in again on Friday . Parts they had ordered according to the TSB arrived last week from Germany. We'll see. |
| 11-16-2011, 04:06 AM | #68 |
The rattle is back already.......
The wind noise is unacceptable and unmistakable, those saying they have no wind noise cannot have the noise I have. I will try the dealers demo car, if this has it too they'll say it's normal. What I do after that I don't know, probably write to BMW UK.
F25 3.0D | M Sport | Black Sapphire | Oyster | Fineline Wave Wood | Heated Front Seats | Panoramic Roof | Matt Aluminium Roof Rails & Window Trim
Sept 2011 |
| 11-16-2011, 04:29 AM | #69 |
If they continue saying that it's normal then ask them to call an expert from BMW Germany. Luckily my dealer is approaching to me positively until now, and working with me to solve this .
I have been trying out any SUV I have a chance to to compare the noise, and to date my X3 is the noisiest for wind and traffic. I am not buying that this should be considered normal for BMW . Apart from this problem, after 6,000 miles I have absolutely nothing to complain about the car, just minor rattles- every car has some- , and I think it's a very good car in general. That's why I cannot accept such a flaw even much worse vehicles in the market don't have. |
| 11-16-2011, 04:41 AM | #70 |
I agree on traffic noise too, it's like going back to when I had a soft top 330i.
Sept 2011 |
| 11-25-2011, 08:48 AM | #71 |
Mirror gaskets have been replaced last week as per the TSB. In the first meters after picking up the X3 I noticed that traffic noise at slower speeds have lessened to a more acceptable level . These first meters are very important to me because that route was where we had tested my car with the technicians a couple of times and also their test car once for the same issue.
On the other hand the wind noise starting at 50 mph seems to have moved to around 65-75 mph and up now, and more like the classic wind noise obviously coming inside through the windows /seals and/or B pillars . Although not totally sure yet, I think replacing those gaskets would worth trying for those suffering from wind noise like me particularly at lower speeds. Having said that , I still think the insulation on the car needs improvement at door panels, window/door seals ,and B pillars as well as readjustment of the front doors on the tighter side is necessary. |
| 11-25-2011, 09:28 AM | #72 |
WOW Interesting reading...
I have a 2012 28i, it is 2 1/2 weeks old with over 2,000 miles. It rides VERY quiet, and does not have one single rattle! Perhaps they resolved this for 2012? I hope so! BTW, removing the cargo shade from the back can resolve many rattles! Since the windows are tinted, do you need the shade, anyway? |
| 11-25-2011, 10:10 AM | #73 | |
On the other hand, BMW's TSB on replacing the mirror gaskets to eliminate a certain wind noise inside the cabin is for vehicles manufactured before 7-15-2011 , and I understand from this they used right gaskets after that date, so disregarding your model year you should check your month of manufacturing . I cannot know if after a certain date factory also used different seals or more insulation in door/window-mirror areas or basicly cared more about QC . Anyway, good for BMW if they took action so fast based on customer complaints and enhanced the model before waiting for the facelift. |
| 11-25-2011, 12:40 PM | #74 | |
Drives: Deep Sea Blue 328i Convertible Join Date: Oct 2011
2011 Deep Sea Blue 328i Convertible
2012 Vermillion Red X3 35i, Premium, SAP, Tech |
| 11-25-2011, 03:13 PM | #75 | |
Love All
I don't see gaskets on side mirrors, can you show me a picture of gaskets needing replacement? Thanks. |
| 11-28-2011, 03:34 AM | #76 | |
I believe it is valid for US x3s too , but only some owners complain about a wind noise, so it is most likely that not all vehicles are affected. Therefore if there is nothing bothering you at the moment you don't need to have anything replaced at all. If I am not mistaken, the gasket referred to is a small part inside the triangle area where side mirrors are attached to the body. I have not seen them being replaced nor the part itself but the service rep showed me the TSB printout with a scheme of the area. |
| 11-28-2011, 04:07 AM | #77 | |
Live for today tomorrow never comes
Live for now, life is too short.
2013 M5 LCI on Order for October. |
| 11-30-2011, 05:50 AM | #78 |
I've been into the dealer today, we did a back-to-back comparison with their demo car. 1st off was mine, the buffeting wind noise was easily heard. The I drove their 35D, it was considerably worse.
The dealer is ordering new door and window seals. They know the 35D for sure has the latest spec door seals, not sure about my car. It was interesting though that they've modified the door seals.... The dealer was careful set expectations that they will try to reduce the noise but won't promise anything (good BMW training!). The idea is to set the new seals to pull the doors in about an extra mm to create a better seal. If that doesn't help then they'll try window seals. My driver's door rattle maybe the window flexing in the window seal. They are also getting me yet another seat cover (the replacement is saggy too) plus new foam.
Sept 2011 Last edited by clivem2; 11-30-2011 at 07:24 AM. |
| 11-30-2011, 07:21 AM | #79 |
You mean your X3 was considerably worse than their 35d I assume? That sounds like a real pain in the ass. I hope they get it sorted for you.
![]() BMW X3 (F25) xDrive20d SE . . titanium silver . . titanium front grille . . 309s . . xline . . xenons . . black leather . . alu trim . . professional multimedia package . . dynamic package . . climate package . . electric seats . . folding mirrors . . servotronic steering . . DAB radio . . business speakers . . sun protection glass . . split rear seats . . |
| 11-30-2011, 07:24 AM | #80 |
No! The brand new 35D had even more wind noise.
Sept 2011 |
| 12-03-2011, 06:08 PM | #82 |
Drives: BMW X-3 28i Join Date: Aug 2011
I got my 28i x3 in late August so it looks like we both have cars from the same production line. I have the wind noise and HAD the tailgate noise as well. The windnoise as explained by the dealer is normal due to the larger mirrors. But it took two visits to the dealer to correct the tailgate noise. Happy it was fixed but no explanation was given.
| 12-05-2011, 11:28 AM | #83 | |
I agree . It is very interesting that they already modified the door seals of a model launched just about a year ago. So, are the new seals to pull the doors in an extra mm by design or will they assemble them so that doors will close more tightly? If latter is the case, should we then also try readjusting the doors to a tighter position with the existing door seals? |
| 12-05-2011, 11:39 AM | #84 | |
If wind noise you have starts at 45-50 mph like most of us , then with all due respect, your dealer is wrong. Wind noise starting at those speeds is not normal at any car no matter how large the side mirrors are. On the other hand check your car's date of production , if it is before 7/15 you are eligible for the mirror gasket TSB. Your dealer should have mentioned that to you already when you told him about the wind noise. |
| 12-05-2011, 11:55 AM | #85 |
They must have a "PUP' then mine is all but silent.![]() I have had it up too 90+ MPH and still no noise at all, it's every bit as quiet as the 550i M Sport I just sold. ![]()
| 12-05-2011, 01:24 PM | #86 | |
To add to my woe, the TPM has just triggered, one tyre is down 10 lbs. That wheel slipped down a kerb a couple of days ago, hopefully that's the cause, not a puncture. The alloy didn't scrape.
Sept 2011 Last edited by clivem2; 12-05-2011 at 01:39 PM. |
| 12-06-2011, 04:29 AM | #87 | |
I too had a slight rattle from the driver side window when the car was new but disappeared in time. Still, source of your rattle may be the same as the wind noise issue. I believe, in some of the X3s if not all , there is a problem with parts or assembling or both in the entire front door areas causing abnormal wind-traffic noises, rattles, whistles and God knows potentially what else. I also believe that BMW is well aware of the situation: They launched a TSB real quick on the mirror gaskets to address the wind noise-whistling from side mirrors; they are obviously using redesigned seals on cars produced after a certain date ; and possibly they have reinforced the insulation inside door panels and pillars too (just my opinion - if they haven't they should) My concern is, you have to be persuasive to your dealer and not just accept their technicians' initial classic "all is normal" approach to make them do the research and start applying all or any of these solution alternatives. |
| 12-13-2011, 01:00 PM | #88 |
My car goes in again on Thursday. This time I have something to show the dealer. My car is filthy due to the recent weather. The sill under the doors, right under the doors - not on the outside, ie inside the seals, this area is very dirty. If water and muck can get past the seals then I'm sure air can!!!
Sept 2011 |
| Bookmarks |
