XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Help..Just bought a new X3 on Saturday and it is going back to the shop for the secon
      09-01-2011, 11:18 PM   #1
dd123
Drives: X3 28I
Just bought a new X3 Saturday. Sunday it would not unlock and had to use key. Then alarm goes off and stops when you start the car. Then it blows hot air and shows windshield wiper failure. Then after shutting off car windshield wipers remain on for 10 min. WOW.. My first BMW. Drove it to BMW sales rep pushed a button and problems went away. Took it home same problem above 4 times. Took it to be repaired and they said they replaced the modular and all was well on Wednesday. Today is Thursday and I could not get in my car and same problems as above with same message. Kinda scarred I got a lemon and I'm taking it in tomorrow. The new car experience should not feel like this. I have been back twice and tomorrow will be 3 times. I can not lock my doors now. Any feedback would be appreciated. I'm curious if they even replaced anything because it was working when I dropped it off. Now I loved this X3 the 3 days i had it. This is my first BMW and I hope this problem goes away.
dd123 is offline
      09-02-2011, 12:17 AM   #2
dd123
Drives: X3 28I
someone please post a reply on what they think
dd123 is offline   Reply With Quote
      09-02-2011, 02:37 AM   #3
Lotus7
Drives: xxxx
"Been there - Done that"
Obviously, the vehicle has a problem with some electronics module, a communications bus or "who knows what".
If you haven't already done so, document everything that has happened - write down each failure or malfunction, and be sure that your dealer documents what they claim to be doing to correct the problem. They should be willing to give you a copy of the service report for each time you bring it in for repair. Insist that your dealer does not give the car back to you until they have thoroughly tested it. They should be willing to give you a free loaner while they keep your car.
If they return it again and you again have problems, it's time to phone BMW NA and talk to a customer service rep. Request that they investigate your recurring problems.
Again it's essential to have the service sheets and your notes on what failed, when it happened, and what was done as an attempted repair.
It sounds like your dealer's service dept has only tried simple fixes or system resets. Some of the failures should have set "codes" in the computer. Try to get a copy of the error codes. On the X3, major error codes are also stored in the "Key Remote" (the key Fob) and can be read out immediately by the Service Dept computer. However, because some of your problems are related to the remote locking system that may not be working correctly.
Hopefully, it will not come to that, but you should be aware of the details of the Arizona Lemon Law (Arizona Lemon Law 44-1261).
see: http://www.carlemon.com/lemon/AZ_law.html
The Arizona statutes allow for vehicle replacement or refund of purchase costs if the vehicle is in for service for THE SAME PROBLEM a total of (4) times, OR if the vehicle is in for service for (30) days or more. The Arizona statute is valid for the first 24 months of ownership. That's why it's essential to keep full records from "day-1".
There is a good chance that you service dept. will find the real problem and correct it once they start taking you seriously. There seems to be a widespread tendency among BMW service departments to try to take the fastest, easiest fix, and not to completely check that their "fix" really has corrected the problem. It often takes several trips back and/or some pressure (and possibly help) from BMW NA to get them to seriously concentrate on the problem and find the real solution.
Good luck and remember, "Document everything!"
Lotus7 is offline   United_States
      09-02-2011, 10:50 AM   #4
darksilkx1
Drives: F30
Good advice there. Probably would not hurt to take photos or video of the problem as its happening for documentation sake.
darksilkx1 is offline   Reply With Quote
      09-02-2011, 10:51 AM   #5
darksilkx1
Drives: F30
Sorry about your troubles, you must feel really awful. My wife's 2011 MB GL350 started dropping bits of trim a week after delivery. Needless to say I was exceedingly disgusted.
      09-02-2011, 04:19 PM   #6
Lotus7
Drives: xxxx
Absolutely! Taking photos or video is an excellent suggestion. If you have a "time/date stamp" function on your camera, turn it on. Usually, you will have to turn off any auto flash to get decent pics of the display screen(s).
      09-02-2011, 09:41 PM   #7
dd123
Drives: X3 28I
Thanks all and back in shop till tuesday
O.K..they were very nice at the BMW service today and all error codes showed up on the key. Car was working this morning but they could tell i had the error codes. They called me later today and said that they got the show. That is the show of the alarm, locks, error codes and the blowing of hot air. They think they have to replace some other box on Tuesday but need to speak with BMW NA about it first. I know this is not normal but I just want a different X3 now. From what I read, everybody loves theirs as I did the 2 days I had mine. This may sound weird, but I think during all this, extra miles showed up. I know I only drove 85 to 90 miles, since the last drop at service but it shows I drove 130 more. They are checking into this too. Maybe I'm just sleep driving? Should I ask for an extended warranty?
      09-02-2011, 11:33 PM   #8
Lotus7
Drives: xxxx
You can ask for a different car, but considering that yours has only been in for service for a few days, it's very unlikely the dealer will approve it.
Even though the problems are apparently with different parts of the car, they probably are all related to a single electronic module or other system component and MAY actually be fairly simple to repair by replacing that single component. Although virtually any BMW dealer's service advisor will always be "very nice", what you want is competent service not just "nice". Ask them point blank if they have consulted BMW NA for help with the problems your car has, and if not WHY?
It’s possible to be polite, but also to stand your ground and be firm.
      09-07-2011, 01:39 AM   #9
dd123
Drives: X3 28I
O.K.. I got the car on Saturday and brought it in on Sunday and it seemed fine. I brought it back on Monday and they replaced a modular and got it back to me on Wednesday. I had problems again on Thursday night and brought it in on Friday. Today which is Tuesday they called BMW NA and they think a junction box needs to be replaced and it needs to come from Germany. They will try to get it in faster. Should I at least ask for an extended warranty since it seems to have major problems. I have had it a total of 3 days in a week and a half. Thanks for all your help and I'm sure 99.9 % of the X3's would never have this problem but since it affected the AC, alarm, door locks, and it also locked me in while blowing hot air, window wipers and no lights at night I will not feel safe driving it if it happens again. IT WAS NEW and I hope BMW NA gets involved and makes it right. I am a single mom who drives around her daughter and I freak out when I don't feel safe. I think this is a great SAV and would still stick with the new X3. Since it feels like it has a mind of its own I don't want to take chances with my safety. FYI..It really helped in my decision when buying this car that this model has brought jobs to the U.S.A
      09-07-2011, 05:38 AM   #10
Drnelly
Drives: X3
I feel your pain as I find myself in a similar situation with different technical issues on my x3. I will post my case shortly as I would like some input from the forum.
Good luck in getting your car fixed and feeling like you own a brand new BMW
Cheers.
X3 28i titanium silver - premium pckg - sport activity pckg - technology pckg - cold weather pckg - power tailgate - black nevada & Sienna wood trim
Drnelly is offline   United_States
      09-07-2011, 08:39 AM   #11
Lotus7
Drives: xxxx
Although problems like yours should never happen, they can, and do.
It sounds like your dealer is at least trying to find the solution. If it were me, I'd at least phone BMW NA Customer service (800-831-1117) and have them open a case on your car. It never hurts to let the dealer know you're not just talking to them.
Regarding asking for compensation (an extended warrantee). You’re probably better off waiting until the car is properly fixed. Once you’re satisfied that it’s working correctly make your case with the dealer AND with BMW NA. I personally know of several instances involving 2011 X3’s where BMW NA approved cash payments to owners to compensate them for their troubles.
It’s often a good idea to keep a detailed log of what functions failed on the car and when. Mention the full list and the number of times you had to return to the dealership for service that obviously DIDN’T correct the problem in a detailed letter to BMW NA. The real failure here is apparently that you dealer didn’t keep and drive the car enough to insure that your issues were properly resolved.
Good Luck – we do feel your pain and share your concerns about your family’s safety.
      09-21-2011, 10:04 PM   #12
Dukat
Dukat's Avatar
Drives: 2012 X3 35i
Hey DD123,
Did you ever get a resolution?
2012 X3 35i | Mineral Silver | Oyster | Wave Wood
Packages | Sports | Cold Weather | Dynamic Handling | Premium | Technology | Premium Sound
Dukat is offline   United_States
      10-21-2011, 09:29 AM   #13
drdeacon
Drives: '03 330i, x3 28i
dd123-
I feel your pain…I have same exact symptoms in my X3 only mine waited 3 months to appear…In the shop for 3 days and no word yet…what happened in your case???
drdeacon is offline   Reply With Quote
      10-21-2011, 10:22 AM   #14
xDrive35i
Drives: 2011 X3 35i
Don't be scared you got a lemon. Just be calm but also firm. Demand but be reasonable. Call your lawyer. Ask him what you can do.
2001 Audi A6 Allroad 2.7T (C5); 2005 Audi A6 4.2 Quattro (C6); 2005 BMW X5 4.4i (E53); 2008 BMW 535xi Sports Wagon (E61); 2011 BMW X3 xDrive35i (F25); 2009 Audi A4 3.2 Quattro Prestige (B8)
xDrive35i is offline   United_States
      10-23-2011, 09:44 PM   #15
caz681
Drives: 2011 X3 Xdrive35i
The first model-year of a complete re-design is most likely going to have more issues than other years. German cars are likely to have more issues (on average) than Japanese cars. (Bugatti doesn't build many Veyrons. You think those things are trouble-free?) In the ideal world, the more you pay for a car, the fewer problems you'll have. In the real world, this is often not the case.
Nonetheless, after decades of buying reliable Japanese cars, I wouldn't trade my Audi A4 or BMW X3 for any of them. I have seen the light. The Germans know how to make exciting cars, model-after-model, year-after-year. Some more exciting than others? Sure, but the Japanese struggle to make a vehicle which doesn't bore me to death. (There are some...just not many.)
I may be fortunate in that the only problem I've had with m X3 is the occasional RPM surging at startup (and I expect they'll come out with a fix for that soon). Regardless, I'm prepared to have more problems than I've had with Japanese cars. I'm also constantly having more fun.
caz681 is offline   Reply With Quote
      10-24-2011, 03:16 AM   #16
johnbmw6
Live for today tomorrow never comes
johnbmw6's Avatar
Drives: 2014 LCI M5 coming October
Exclamation
I have had so many new BMW's and NONE have given one minutes problems
There must be a build difference in European and US cars.
No one I know sees these problems I see constantly reported on these forums.
Live for now, life is too short.
2013 M5 LCI on Order for October.
johnbmw6 is offline   United Kingdom
      10-24-2011, 06:04 AM   #17
clivem2
Drives: F25 3.0D MSport
Likewise, I've had 8 new BMW's, I've had a few problems over the years (5 series thermostat and 335i HPFP) but nothing like you see reported on the forums where you get the impression there are loads of problems, it's just the nature of the internet.
I do have 3 niggly things to get fixed but they are not spoiling what's a great car. I was in my friend's Range Rover Sport over the weekend, the first time I've been in it since I got my X3. It's surprising how much tighter the RR Sport is inside (especially the rear) and sunroof really mullahs the headroom.
F25 3.0D | M Sport | Black Sapphire | Oyster | Fineline Wave Wood | Heated Front Seats | Panoramic Roof | Matt Aluminium Roof Rails & Window Trim
Sept 2011
clivem2 is offline   Reply With Quote
      10-24-2011, 06:49 AM   #18
LEDZEP
LEDZEP's Avatar
Drives: 2009 E70 & 2011 F25
Definately sounds like a module problem. Which one though? That's the tricky part. Amazingly, BMW techs don't seem to have sophisticatd equipment to diagnose these types of problems to the degree that I feel they should. Our X5 recently had to have the footwell module replaced (one of the primary lobes of the 'brain'), and it took them several tries to finally determine that.
Good luck. I see this thread is over a month old - hopefully by now you're all sorted out.
I think it is bad luck to be superstitious
LEDZEP is offline   Reply With Quote
      10-24-2011, 07:07 AM   #19
johnbmw6
johnbmw6's Avatar
Originally Posted by clivem2 View Post
Likewise, I was in my friend's Range Rover Sport over the weekend, the first time I've been in it since I got my X3. It's surprising how much tighter the RR Sport is inside (especially the rear) and sunroof really mullahs the headroom.
I test drove one of these thinking I would buy one!!!!! No Chance they are so much behind BMW technology wise and "Powerless" they are so slow, this coupled with the ancient
Power train (6 speed) put me right off, thats not counting terrible residuals and reliability.
My mate bought the Top of the range, Range Rover and it was worthless in 3 months, no one would even bid on it.
BMW all the way.
      10-24-2011, 07:17 AM   #20
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
But that's the nature of forums. Most people post with a problem that they would like help or advice with. For each problem reported there are 100s of other X3s with no problems to report - mine included, after 8 months.
People that aren't regular forum users don't suddenly decide to post about how wonderful their cars are. Look at almost any product that has been reviewed by 20+ people. You'll invariably find some bad reviews.
Unless there are statistics on number of faults and there is a marked increase based purely on where the car was built, it's impossible to say that's the cause. And even then, it could be components or machines used that were built elsewhere that are to blame.
One negative point is some of the things that have managed to get through quality controls like obvious paintwork bubbling. Some of these should never have left the factory.
      10-24-2011, 07:39 AM   #21
LEDZEP
LEDZEP's Avatar
Completely agree. Most people will be more likely to express an opinion when it is negative. Also agree on the paint quality. I have a few 'fish eye' spots that are usually an indication of contaminants on the substrate before painting.
      10-24-2011, 07:50 AM   #22
clivem2
BMW all the way.
My mate has the 5.0 V8 Supercharged, it has about the same performance as the 3.0D X3 only I don't need to have a fuel tanker constantly filling me up! Grossly inefficient and as you say, unreliable. I've not looked in on a Range Rover forum, I can only guess what topics they discuss.....all those toys to go wrong.
Sept 2011
Forum Jump
