FORUMS
- 5
| XBimmers | BMW X3 Forum » alignment - drifts to the right |
| 09-08-2011, 06:38 PM | #23 | |
| 09-08-2011, 06:52 PM | #24 | |
Mine doesnt pull, but follows the crown a bit more than my previous generation X3, so if were feeling the same thing that would mean that on some roads it will drift TOWARDS oncoming traffic. |
| 09-17-2011, 05:40 PM | #25 |
Rider and driver
Drives: 2011 Black X35i Rides: K1300GT Join Date: Feb 2011
The somewhat complex method of the front panel pulling the second panel from storage ended up with some of the parts breaking and the track getting fouled. New parts were ordered, then the technician that usually deals with sunroof issues was sent down to Los Angeles to learn about the new repair process for X3 sunroofs. He came back, ordered more parts, got the parts, ordered a couple of different parts (color was wrong) and re-assembled the sunroof. Probably took a bit longer (2 weeks) than usual due to getting parts, the different repair process and it being his first fix with the new method(s). Seems to be working fine now, but I haven't had a really hot day since, and I think it was a combination of heat and opening/closing the sun roof that day.
2011 X3 35i
Black Saphire - Nevada Mojave - Y Spoke 308 - Premium Sound - Navigation I work for Keyser Söze |
| 09-17-2011, 06:51 PM | #26 |
I'm afraid to use my sunroof. haha.
Reading the many window failure threads, I'm also afraid to use the windows. Glad you're problem is fixed now.
2012 X3 35i | Mineral Silver | Oyster | Wave Wood
Packages | Sports | Cold Weather | Dynamic Handling | Premium | Technology | Premium Sound |
| 09-27-2011, 01:54 PM | #27 |
![]() ![]() ![]() Drives: 2013 F10 BMW 535i M-sport Join Date: Jun 2005
Bump
2013 F10 BMW 535i Alpine White / Oyster Dakota Leather / Anthracite Wood Trim / Steptronic transmission / M Sport Package / Premium Package / Technology Package / Rear-view camera / Park Distance Control
| 09-28-2011, 07:26 PM | #28 |
Bump
| 10-04-2011, 04:24 PM | #29 | |
| 10-04-2011, 05:06 PM | #30 |
The pulling (or drifting) that I've seen on my rig has subsided considerably. I now have 3000 on my rig. I'd say it took until about 1200-1500 for things to settle.
The car does seem to have a more balanced setting to road crown. Depending on the slope, it'll drift right or left, or drive as straight as an arrow. my other two cars, that seem to be adjusted for road crown seem to drift hard to the left in the left lane. I've been more cognizant of things lately. for what it's worth.......... |
| 10-04-2011, 05:59 PM | #31 | |
The RSM is coming out tomorrow to look at it, they've taken pictures and acknowledged the issue which i find to be a relief. I'll keep you posted. |
| 10-04-2011, 11:01 PM | #32 |
I had my car in yesterday for an with the car drifting to the right with 300 mi on it. They tried swapping tires front to rear & then checked alignment, neither worked. They then said they tried swapping tires on the right side front to back and the drift is now gone. Make me a little nervous about an issue with the tires but it's all documented so if I have a problem later, they should cover it.
| 10-05-2011, 02:03 PM | #33 | |
Rider and driver
Went in today. Towing package was ordered today, but won't arrive until next week. No work done, but the shop foreman did another test drive and confirmed that it's still not right. After they did the alignment a couple of weeks ago, the sheet that was attached to the work order showed the before/after settings of the alignment. Unfortunately, the shop tech didn't save the initial settings before any adjustment was made, so the report shows the left front and right rear adjustments being within spec, that is to say, both before and after settings were within spec. If any of you get the alignment done, take a look at that sheet and if it doesn't show any real correction, ask about that.
2011 X3 35i
| 10-05-2011, 03:52 PM | #34 | |
Did you or anyone at the dealership check the tire pressures? Did the service tech adjust the tire pressures when they exchanged the front and rear tires? For most of the X3 OEM tire configurations (except the 225/60R17 tires), the pressures should be higher for the rear tires. Most dealerships don't seem to pay any attention to that and have been known to typically deliver X3s with tire pressures all over the map. For the 245/50R18s, 35F and 38R work pretty well. It's such an easy thing to check, and is often completely overlooked. A left/right difference could certainly create a steering bias. |
| 10-06-2011, 12:28 PM | #35 | |
This is my first BMW; my first german car for that matter. I've been partial to Lexus and Infiniti because every experience has been so positive. Everybody in my family is shocked that I am having this experience because this is not the BMW experience they have. Another concern I shared with my SA and I urge you to do the same, is how this innate misalignment has worn your tires. Lets not forget that after 3,000 miles of making a left turn I've probably worn my tires wrong and expect BMW to make good on this expendable item as well. They are waiting for parts, so I am still driving my car. Next week, they expect the new parts to come in. I just want my car to drive straight. For $52,000; i expect it to drive straight. |
| 10-06-2011, 12:30 PM | #36 | |
| 10-06-2011, 01:14 PM | #37 | |
F25 3.0D | M Sport | Black Sapphire | Oyster | Fineline Wave Wood | Heated Front Seats | Panoramic Roof | Matt Aluminium Roof Rails & Window Trim
Sept 2011 |
| 10-06-2011, 01:15 PM | #38 | |
Rider and driver
First one is 32F/35R - Normal operation Second is 38F/44R - When expected sustained speeds exceed 100MPH. I would go with the door sticker(s). Different tire/wheel combinations are available that would make a generic pressure listing questionable. Mine are 3lbs different, front to rear.
2011 X3 35i
| 10-07-2011, 04:08 PM | #39 |
it's charlie K with up date!!! junk,junk,junk. As you can tell my problem has gotten much worse. My right wheel now sticks out 3" past the body. I can no longer drive the car.milage now 9.ooo Bmw just runs you around. They dont care. Thay want you to give up and dump the car for a loss( not going to happen ). see them in court first!!!. This is my first BMW list price 58.000 No more BMW for me.This is just one issue with this car. too many to address each one. Oh ! Yes .my turn signels wont turn off now. I hope that you people have better luck than me.
| 10-20-2011, 01:48 PM | #41 |
Rider and driver
They worked on the alignment issue yesterday. They swapped the front tires (left-to-right and right-to-left) and it's not happening with the same "intensity". Doesn't pull all time, but it's still there. I'm waiting to let the tires wear in a bit and see if it doesn't come back to the stronger pull.
About 40 years ago my dad bought a Bavaria (E35?) and it had the same issue, but also had asymmetrical tires, and the pull to the right went away for good with that tire swap. Dad was incredulous over that fix when they told him, but turned out it was what it took. So, while I'm skeptical that the tire-swap is the fix, I'll let it pan out a bit.
2011 X3 35i
| 10-22-2011, 04:23 PM | #42 |
car being towed. yes it's true.the wheel sticks out. this car is in lemon law for past 4 months. BMW says out side forces has caused the right wheel sup. to be bent .not a mark under the car. just dust. go figure this has been a problem since day one. hope you have better luck !!
| Bookmarks |
