XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Probing the X3 (F-25) OBD-II port
      06-08-2011, 07:05 PM   #1
Lotus7
Drives: xxxx
POST DELETED
Lotus7 is offline   United_States
      06-08-2011, 07:36 PM   #2
LEDZEP
LEDZEP's Avatar
Drives: 2009 E70 & 2011 F25
Well, your method is all techy and impressive and stuff, but I usually just stick my head out the window and measure by how fast my lips are flapping (BPM, beats per minute as they slap together).
Yeah, maybe your way is more accurate now that I think about it. Plus you probably don't have numb lips when you get home.
I think it is bad luck to be superstitious
LEDZEP is offline   Reply With Quote
      06-08-2011, 07:49 PM   #3
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
Maybe you should change your name to "Aerosmith".
Radioactive is offline   United_States
      06-08-2011, 08:15 PM   #4
Want the thrill
Drives: X3 35i
2011 X3 35i  [4.00]
You're on a roll LedZep
Want the thrill is offline   Reply With Quote
      06-08-2011, 08:43 PM   #5
jlr_1304
jlr_1304's Avatar
Drives: none
Did you tried the hidden menu ? maybe there is something about the turbo.
You have to push the start button and the trip reset button simultaneously for a couple seconds(not pushing brake pedal)then ad the sum of the five last digits in the vin (like 5 if if you have 11111) and enter the sum in the right sub-menu.
I didnt try it.
jlr_1304 is offline   Canada
      06-08-2011, 09:58 PM   #6
Radioactive
I didnt try it.
Does anybody know how this works.
The only things that come up are:
Main Menu
01 ID
02 System Test
03 Test End
04 Unlock
I can cycle through with the trip button, but nothing else changes anything.
      06-09-2011, 03:57 PM   #7
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
Main Menu
01 ID
02 System Test
03 Test End
04 Unlock
Yes, see this post for instructions. I've followed these and it works
http://x3.xbimmers.com/forums/showth...nu#post9399627
      06-09-2011, 03:58 PM   #8
sfax
sfax's Avatar
BTW, to enter the sum of the last 5 digits, you have to use the trip button and press it x times
      06-09-2011, 04:40 PM   #9
Radioactive
As you see I get the Main Menu. Do I then use the trip reset button x times(x=addition of VIN #'s)? If so do I have to be on any particular menu selection?
      06-09-2011, 04:56 PM   #10
sfax
sfax's Avatar
yes, press x times on any selection
      06-09-2011, 05:36 PM   #11
pault
Drives: 2011 F25 35i
2011 BMW X3 35i  [0.00]
For me I did:
1. Press and hold trip and start until "main menu" appeared
2. Press trip 4 times until '04 unlock' highlighted
3. Press and hold while on '04 unlock' until next menu shows
4. Next menu asks for a code
5. Press trip as many times as x (code will count up)
6 When you get to the right number do another press and hold on trip and multiple more menus appeared
Might have the words/description a little off, perhaps I should video it...
2011 F25 35i Space Gray with Black Leather
Cold Weather | Convenience | Dynamic Handling | Premium | Sport Activity | Technology | Dynamic Damper Control | Head-up Display | Smartphone | BMW Apps | Premium hi-fi | Satellite radio | Automatic high beams
pault is offline   Reply With Quote
      06-09-2011, 05:46 PM   #12
Radioactive
Originally Posted by pault View Post
For me I did:
Now this works!!! Thanks
I did manage to add the "Service Menu" for CIC settings to the "Setting Menu" on the iDrive for Navigation, Telephone and Gracenote.
      10-21-2011, 02:49 AM   #13
Rodion
Drives: X3 (F25)
Now that some time has passed, what all things have you find in the secret menu and have you used it?
I mean, could you have some nice info on iDrive screen, such as oil temp etc.?
Rodion is offline   Finland
      10-21-2011, 04:02 PM   #14
GQX3
Drives: 2011 X3 28i
Originally Posted by Lotus7 View Post
One thing that I really miss having on the X3 35i is a turbo boost gauge. Every turbo-engine car I’ve owned has either had a factory-installed gauge or I’ve installed an Autometer electronic boost/vacuum gauge myself. Getting the required wiring harness for the Autometer gauge installed is not a trivial job, since it means running a cable through the firewall.
Anyway, I thought a way around having to do that on the X3 might be to see if the boost pressure value was available through the OBD-II port. The pressure reading is certainly something the engine control CPU monitors, and many vehicles do allow it to be read out via the OBD-II port. Usually the reading is accessed by checking the MAP (manifold absolute pressure) value. Unfortunately, the X3’s port does not respond to a query for a return of the MAP value. It may not be there at all, or BMW may supply it only under a special (secret) query request.
Anyway, as long as I was connected to the OBD-II system, I decided to see what WAS available on the X3.
The X3 uses the CAN 11-bit protocol.
Here is a list of the digital values that can be read in real time on a X3 35i using standard CAN queries:
% engine load
engine coolant temperature (deg. F.)
short term fuel trim
long term fuel trim
RPM (resolution on X3 = 1rpm)
MPH (resolution on X3 0.1 MPH)
timing advance
intake air temperature (resolution 0.1 deg. F.)
mass air flow sensor (g/s)
absolute throttle position (%)
oxygen sensor voltage
run time since last start
distance traveled with check engine light on
fuel pressure
evaporative purge (%)
fuel level (% of full)
number of warm ups since engine check light cleared
distance traveled since engine check light cleared
barometric pressure (ambient only – not MAP)
catalytic converter temperature (deg. F.)
battery voltage
accelerator pedal position (i.e.: more than 1%)
mass air flow (calculated)
instanianeous MPG
average MPG
average gallons per hour
run time (general)
distance (miles)
fuel level (reads to 0.1 gal.)
distance to empty (DTE miles)
time to empty (TTE hours:min)
average MPH (current trip)
average MPG (current trip)
fuel used (current trip)
average gallons/hour
run time (trip)
distance (trip)
distance on oil change
distance to service
There probably are others, but they likely require special BMW coding.
It is interesting and fun to drive around with a monitor connected showing some of those readings in real time. I just wish that the manifold pressure (turbo boost) reading was available.
....let me guess UI Engineering alumni..........
GQX3 is offline   Reply With Quote
      10-21-2011, 05:59 PM   #15
GQX3
Drives: 2011 X3 28i
Dead on...how did you ever guess? U. of I. (EE) and U. of C. (Physics)-
Blue/Orange and Maroon/White (mix them all together and you get mud).
.....just knew from your writing...really...Oskee Wow Wow....I've been working at NASA too long.....
Tags
can tool, digital, obd-ii, readout
Forum Jump
